Wet nitrous setup
kgmdawg84,
Did you ever give the wet shot setup a try this winter? I'm looking into it myself as a way to put some serious increase in power until the turbo route is available for us 2013's.
I've been talking with Matt at Comp Cams, and he said the Zex wet nitrous universal system (Part#82023) would be appropriate and is very popular with the modern GDi guys, and on the 75 shot jet I don't see any reason why it would cause any problems.
Since I'm not at the house right now, I don't have a chance to pull my intake again and examine the arrangement of the intake manifold to try to come up with any potential issues with location of the jet nozzle.
With only a 75 shot, I don't think there should be any problem with timing, either. Even in the chance you go higher, since the '13 has the knock sensors and automatically pulls timing if knock is detected, it shouldn't cause an issue unless it over corrected and pulled too much.
The only issues I can think might be an issue are I don't know what the rating of our stock fuel pump are, will it handle the added demand for the enrichment fuel, and where to tap into the fuel lines at (although this might be solved, since I saw a new aluminum fuel rail being advertised here the other day). Does anyone have the specs of the fuel pump, and an idea of what kind of demand increase this might generate?
I'm very highly considering putting in this order to have it installed when I send off my intake to GS for P/P and coating next month, so it will be ready for the custom tune in June.
What does everyone think about this? Can anyone see any problems with this arrangement? I would love to go the noble, all-engine route ByzKing is taking with his build, but without sponsorship or discounts, I'm looking for cost effective methods of getting good gains while keeping daily drive-ability. At an average retail cost of $540 for the kit, that's cheaper than the tune, and only activates at WOT, which means daily driving will remain stock and not cost anything extra in fuel or nitrous.
Opinions?
