Depo Racing Genesis 3.8 V6 test-pipe set. These offroad pipes will remove your stock cats. You can replace your whole exhaust system and you still wont get any more power then installing these, this is where the power gets robbed. These would be installed day 2 of owning the car,lol.
- 2.5 inch Straight through design (test pipe) eliminates restricted cat section.
- Direct bolt on fitment
- Gaskets /bolts included
- 304 stainless steel
- 10 mm thick flange
I have these pipes in HFC Hi flow cat version
