New thread the other timed out and would not let me edit. Thanks to all that have installed my kit, I think its the best kit made. If you really want to run a Garrett core my pipe kit fits great with it. If you have a CX or Mishi kit and want to just upgrade with my core but keep that pipe kit, that also has been done by members.
"The MAP sensor does not rub anymore , stop asking,lol"
Specs on Intercooler:
- Does not interfere with stock Crash Bar
- HUGE 24" x 7.5" x 3.5" wide Bar and Plate Core - 30" overall length
- Rolled pipe ends
- Aluminum Construction
- Pressure checked at 45 psi
- 200% more flow space then stock
- straight through flow design
-2.5" inlet and outlet
- This same core type has broke 500whp many times on EvoXforums.
Pipe Kit Specs:
- 2.5 inch OD
- 2mm OEM grade aluminum - Thin pipes bend and crush when using t-bolts, it happens a lot, then you are stuck with pipes that restrict flow and are worthless when you want to sell. Most companies use <1mm thick cheap piping, not to save weight to save money.
- This kit is made with more aluminum tubing and less couplers then other kits.
- KIT COMES WITH ALL COUPLERS - 4 ply Silicone
- T-Bolts INCLUDED (10x 2.5" tbolt, 1x 2.0", 1x 2.75")
- Comes in Polished Only - ask about satin black
- Rolled pipe ends
Pipe Kit Specs:
- 2.5 inch OD
