Joe-Shmoe
I'm having repetitive coil packs & spark plugs failure.
I memory serves me right in the last +/- 3.5years I had to change (warranty): - 1 ignition fuse - Coil-pack wiring - Spark plugs (3 different occasion) - 3 different coil-pack. I think the problem is not always on the same cylinder. Searched quickly and it does not seem to be a recurrent problem. The failure is typically slow and eventually leads to the car driving on 3 cylinders and going in total limp mode (no acceleration possible). I've hence had to drive the car on 3 cylinder on 2 two occasions. Not reassuring for the health of the engine. Tips/suggestion/thoughs anyone??
Karussell White 2.0GT Coupe
#3 | ||
I reject to reality
sounds like a larger issue if you are having repetitive failures. I'm not sure what it could be though...
BUY MY PARTS HERE http://www.GenCoupe.com/private-classifieds-engine/107775-2012-r-spec-part-out-lots-mods.html |
#4 | ||
Joe-Shmoe
Wiring could be the issue. As of now, I'm still under warranty so it's not to bad of an issue but I need to have the dealer fix this issue fully before it expires or before my crank bearings go bonkers on me...
#6 | ||
Gray hair senior member
Multiple coil failures could be caused by incorrect dwell settings. Perhaps something is wrong with your PA reflash. You could simply scope the drive line one one of your coils, then compare with the stock flash reinstalled.
DIY built motor with haltech new 19t v2 fs "Information is not knowledge. The only source of knowledge is experience." Albert Einstein |
| Jun B.L Exhaust Systems & More - INCREDIBLE PRICING & FREE SHIPPING! | Mike@ImportShark | Engine | 172 | 05-14-2013 12:57 PM |
| FS: Alpine PDX 5 & 4.100, Pioneer In-dash, Component & Coaxial Speakers, & Sub | raybuck | Interior | 18 | 01-31-2013 02:22 PM |
| M&s carart grill problem | Frank13 | Exterior 2008-2012 | 42 | 09-17-2011 04:55 AM |
| m&s lip kit install problem | project jayden | Exterior 2008-2012 | 10 | 06-22-2010 07:28 PM |
| * Problem with M&S type A or any type of Korean aftermarket grille* | Jay@SFR | Exterior 2008-2012 | 3 | 04-14-2009 04:52 AM |
