AMS explores the Gen Coupe exhaust. - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 03-24-2009, 04:54 PM   #1
I make cars FAST!!!
GenX's Avatar
Default AMS explores the Gen Coupe exhaust.
We had a chance to get the Coupe up on the lift today to explore designs for the AMS Gen Coupe exhaust. The factory exhaust leaves a bit to be desired. The exhaust is approximately 2 3/8" OD (60mm) and is even crushed down to 1 3/4" to clear the factory body brace in one spot.
But anyway.... a quick description of the factory exhaust system.
Starting at the turbo, there is a cast O2 housing / catalitic converter / down pipe. This is something that we will work on very soon.The down pipe attaches to the mid pipe which is stainless steel and has a very nice flex section in it.
The mid pipe attaches to a secondary cat. This secondary cat is post O2 sensor so deleting this will not throw a check engine light. The pipe between the secondary cat and muffler is also stainless steel and has a bullet style resonator in it. I suspect that the ID of the resonator is smaller than the rest of the exhaust system. The muffler section appears to be mild steel. It is large and looks heavy.
I got a chance to weigh the exhaust yesterday and here are the weights.
Mid pipe 6.4 lbs
Secondary catalytic converter 6 lbs
Cat back 44.4 (pipe with resonator 11.8 lbs muffler section 32.6 lbs)
Total exhaust system from down pipe back 56.8 lbs
The good news is that there is room for improvement. We did some careful measuring and feel that a 3" system will fit very well and still be routed cleanly. The muffler(s) will need to be positioned in the rear of the vehicle or ground clearance will suffer. The factory system is already slightly below the level of the pinch welds in several places so any muffler positioned forward of the rear differential will be a speed bump scraper for sure (worse on lowered cars).
We are going to explore several possibilities including a side entrance dual end outlet like we are using for our BMW 335i exhaust, a dual muffler straight shot setup, and possibly a tunable exhaust like we are producing for the Evo X.
As with all exhausts we produce, the AMS Gen Coupe exhaust will use 100% stainless steel and mandrel bent tubing. Our exhausts always use stainless steel flanges and not slip joints which are known to leak and blow apart. We also only use 100% stainless steel high flow mufflers so you are ensured years and years of rust free use.
Ivan
AMS Special Projects Technician
amsperformance.com
GenX is offline   Reply With Quote
Old 03-24-2009, 05:35 PM   #2
el chupacabra
NeverNZ's Avatar
3" would be sufficient. any new dyno info with the exhaust off?
NeverNZ is offline   Reply With Quote
Old 03-24-2009, 05:45 PM   #3
merlin2111's Avatar
side exit could be sexy. i just did a horrible chop and i didnt mind it.
merlin2111 is offline   Reply With Quote
Old 03-24-2009, 05:47 PM   #4
I make cars FAST!!!
GenX's Avatar
Still working on burning the 87 octane out of it. I should get it back on the dyno by this weekend with 93 octane and may play around with exhaust or lack there of.
Ivan
amsperformance.com
Old 03-24-2009, 05:53 PM   #5
el chupacabra
NeverNZ's Avatar
<---- Waiting patiently
Old 03-24-2009, 07:44 PM   #6
How much louder do you expect your exhausts to get? I know 3" exhausts can get pretty loud on boosted cars, but I saw an SS/TC with a full 3" magnaflow I think and it sounded barely louder than stock. I'm looking for minimal noise, but something still above stock.
Also, dual tips FTW! You should definitely do dual tip no matter what. I think it fills the gaps perfectly. Don't disappoint us!
ibanez37 is offline   Reply With Quote
Old 03-24-2009, 07:58 PM   #7
I make cars FAST!!!
GenX's Avatar
Dual tip on each side or total?
Ivan
amsperformance.com
Old 03-24-2009, 08:02 PM   #8
traction control off =]
cant_stop_spinning's Avatar
dual tip on each side for sure seems to be the most popular option. But thanks for the info!! I'm so glad you guys are working on this car
"I downshift next to hybrids so they can hear me killing the enviroment "
-Beyond Redline Stage 3
cant_stop_spinning is offline   Reply With Quote
Old 03-24-2009, 08:09 PM   #9
I vote for dual tips total, 1 on each side. Just looks much cleaner in this application imho. the quad tips look abit overbearing on a 20k car.. just my .02
RCSG_Gen is offline   Reply With Quote
Old 03-24-2009, 08:24 PM   #10
I appreciate these write-ups, GenX. Great job.
Anybody think trapezoidal tips would look good?
MP-Omnis is offline   Reply With Quote
Old 03-24-2009, 09:01 PM   #11
i'm back
chris@vtengineering's Avatar
hey ivan, most people want the dual tips per side. and it does look pretty darn good. we're going with that method too
V/T Engineering
I miss my BK. You will be RESURRECTED!
Official Supplier of Frixa Brake Pads
Manufacturer of VB/VI Carbon, DriCarbon, and Dry Carbon Products
Blog--> MotorsportsAndMusings.com updated 12/27
chris@vtengineering is offline   Reply With Quote
Old 03-24-2009, 10:16 PM   #12
Master Member #518
McFly's Avatar
More good info. subscribed.
For Sale: Brand New Injen Cold Air Intake for 3.8 V6, never opened, $280picked up, pm me.
"...this isnt a tib. the 3.8 will always be a better engine in stock form, and with boltons, and with a turbo/bigger turbo..." 4TGEN
"My [blah blah blah] was a beast, but I don't live in the past..." Hank
McFly is offline   Reply With Quote
Old 03-24-2009, 11:05 PM   #13
AdR
Topless = More Fun 4 Me!
AdR's Avatar
Hey GenX a quick question. With the choked section where the frame brace is do you forsee the need to remove/modify/replace that brace or is there enough room to fit the exhaust in there without rubbing issues? Thanks.
Currently own: 2003 Eclipse Spyder GTS - Chrome Blue Pearl
Next car: Genesis Coupe 2.0T Track - Bathurst Black
AdR is offline   Reply With Quote
Old 03-24-2009, 11:34 PM   #14
econorocket's Avatar
+1
'00 Focus ZX3 turbo - 13.38@104 - sure do miss ya buddy
'02 Focus SVT - bunch of crap, still slow
'08 EVO GSR - Perrin drop-in filter, HKS catback
econorocket is offline   Reply With Quote
Old 03-25-2009, 04:40 AM   #15
Jabberwocky's Avatar
I saw a photochop of a GC with vertical stacked quads like the IS-F - that looked awesome, but only if the diffuser is shaped accordingly.
Jabberwocky is offline   Reply With Quote
Old 03-25-2009, 06:02 AM   #16
quicksilver's Avatar
I hope there is an option for a 3" or higher for the 3.8 V6. I plan on going forced induction at some point.
quicksilver is offline   Reply With Quote
Old 03-25-2009, 06:16 AM   #17
2 tips total...1 on left one on right...none of this 4 tip garbage....my 2 cents
EDIT: Important that it has a deep growl not a whining type motorcycle sound.....its a car with a beefy v6 not a scooter. Tin cans prohibited
minik2 is offline   Reply With Quote
Old 03-25-2009, 06:34 AM   #18
merlin2111's Avatar
here is my quick chop of a side exit exhaust. i would like to see a better rendering of a nicer rear bumper with a difusor or something, but you can at least see where i was going with this. i think it looks slick.
Old 03-25-2009, 06:50 AM   #19
YUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-25-2009, 07:01 AM   #20
el chupacabra
NeverNZ's Avatar
3" exhaust doesnt need to be loud.
On my supra i had an 85mm(~3.3") GReddy Super Dragger exhaust, and it was quiet compared to most other 3" exhausts. It was straight through, made plenty of power, but sounded great. Only slightly louder than a stock 350Z
Genesis Forum: GenCoupe Hyundai Genesis Forums > Genesis Coupe Tech > Engine 2.0T > 2.0T Discussion 2008-2012
