hm throttle position sensor? throttle cable? throttle body stuck? - Hyundai Genesis Forum
post #1 of 10 Old 03-15-2013, 12:36 PM Thread Starter
NOU!
i lost count how many times this happened (less than 10 for sure) but a good example would be....
going on freeway ~75 take exit ramp
as i brake, i disengage gear to neutral
instead of my rpm hanging & dropping like it always has, just climbs up as if i'm on the gas when in reality i'm on the brakes..
^ actually happened twice?3 times?
but today i was feeling iffy so i was driving ~55 *speed limit of street i was on is 55* and i dont see my speed dropping.. so i disengage 5th gear to neutral & what do you know.. my rpm gauge shows it revving up to 3-3500 & i can hear it underload and i'm not on the gas..
everytime this happened i just turn off the car waited about 5 seconds then restarted & its working as if nothing happened...
what could be cause? & has it happened to anyone else?
2010 Bathurst Black 2.0t
hajimah is offline
post #2 of 10 Old 03-15-2013, 12:40 PM
SUN★WORKS
SteveJohns29's Avatar
Quoted: 149 Post(s)
Please read this:
Self Reving in between shifts 2.0T M/T
Sponsored by:
475WHP/363wtq
SteveJohns29 is offline
post #3 of 10 Old 03-15-2013, 12:43 PM
SUN★WORKS
Quoted: 149 Post(s)
Originally Posted by Stevejohns29 View Post
Edit. Let me know if you find a solution
Im going to try replacing my pedal next..
Sponsored by:
475WHP/363wtq
post #4 of 10 Old 03-15-2013, 12:45 PM Thread Starter
NOU!
ty good sir *tried search never saw that post..*
but will do i'm gonna take a look at it tomorrow
hajimah is offline
post #5 of 10 Old 03-15-2013, 12:50 PM
SUN★WORKS
Quoted: 149 Post(s)
Surprisingly, there is only one thread that covers it. (not 10k like an aftermarket exhaust lol)
I took my intake manifold and throttle off, cleaned both. and it did nothing.
But at least they're clean now
Sponsored by:
475WHP/363wtq
post #6 of 10 Old 03-15-2013, 12:55 PM Thread Starter
NOU!
well as i was reading through that thread *after reading first page* figured i'd try to clean throttle body but.. after reading your post saying it iddnt help... well fml guess its time to play disassemble & reassemble etc etc -_-
hajimah is offline
post #7 of 10 Old 03-15-2013, 01:00 PM
GT30Rspec
TVONE2's Avatar
It does hang high.. I get this real bad at the drag strip...as I come past the finish line.. I am at the top of 4th gear @high 6K rpm range.. I instantly mash the clutch in shift to N and apply a lot of breaking power..The rpm's will stay at say ~7k for a second or 3... motor unloaded.. do not like it at all...
my story anyway..
PowerAxel
TVONE2 is offline
post #8 of 10 Old 02-20-2015, 06:55 PM
genesis owner
was a solution to this ever found? i am having the same issue... my engine is revving up when im not on the gas... like a lot. definetly not normal
Black 2013 Genesis Coupe 2.0t R-spec
bc br coilovers
injen short ram intake
synapse BOV
isis o2 housing
TurboXS racepipe
greddy single exit catback
isis hydro e brake
pbm RUCA
TooSicx is offline
post #9 of 10 Old 02-21-2015, 05:34 AM
You can temporarily plug the hose that goes to the steel line behind the engine that ends up at the pre turbo intake to see it it improves.
Only applies to the manual transmission cars.
post #10 of 10 Old 02-22-2015, 03:16 PM
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
@nellyville
D!RTYLOUD is offline
Throttle body genjuice Engine 2 01-23-2012 05:56 PM
Throttle position sensor output voltage lead? YellowGC 3.8 V6 Discussion 2008-2012 20 07-14-2010 01:31 AM
boost vs throttle position KEgcYYC 2.0T Discussion 2008-2012 4 05-04-2010 05:34 PM
Throttle Position vs HP Floorit 2.0T Discussion 2008-2012 7 01-05-2010 09:37 AM
electronic throttle and gear position sensor; are we getting ****ed? mr_desmo Engine 46 03-10-2009 03:20 PM
