BoV vent to atmosphere Q's - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 06-10-2013, 09:11 PM   #1
unce unce unce
D!RTYLOUD's Avatar
Default BoV vent to atmosphere Q's
Hey all,
I'm new to MAP sensor type engines so I have a few questions regarding venting to atmosphere BOV & AFRs. With older style MAF equipped engines the sensor is on the turbo inlet so venting to atmosphere on a MAF would produce a super rich AFR mixture, so what's the deal with MAP sensor since the sensor is right before the TB? Will it produce rich AFRs when venting also? It doesn't seem like it would because its not expelling accounted air since it hasn't been metered yet.
I plan on getting the AGP bov adapter for stock location and I have an HKS bov. I want to know this because rich AFRs = poor gas mileage.
Thanks for your input.
- 13' Front End Conversion
D!RTYLOUD is offline   Reply With Quote Quick reply to this message
Old 06-10-2013, 09:49 PM   #2
ragchaos's Avatar
I am pretty sure when i let off the throttle it goes rich for a split second. But I stopped paying any attention to it a long time ago. Three years ago when I added the BOV I have currently on the car it didn't make any difference to the gas mileage. Its always dependent on if you are in constant boost going from light to light during city driving. Even with the stuff I have now if I granny shift and stay out of boost I make 21-23 MPG in the city. The first MAP sensor is on the cold side piping right before the TB. I have my BOV right after the first MAP sensor but before the TB.
2010 Genesis Coupe 2.0T Track Edition
PERFORMANCE MODS
Road Race Motorsports Short Ram Intake
Agency Steel Braided Brake Line
Stoptech Slotted Rotors
Hawk HPS Pads
CP-E TurboBack Exhaust (Catted)
HKS SSQ III BOV
Haltech Pro Plugin
Turbo XS FMIC
AGP Catch Can
Garrett Boost Gauge
Innovate AFR Gauge
ragchaos is offline   Reply With Quote Quick reply to this message
Old 06-10-2013, 09:58 PM   #3
unce unce unce
D!RTYLOUD's Avatar
Thanks for your quick response! I'm glad it will not affect gas mileage. I am going the route I am because I want to keep the stock IC pipes even when I do purchase an aftermarket FMIC core.
My car is completely stock and Im not even seeing 21-23MPG city driving and I drive like a granny shifting at around 2700-3000 RPM. I can only manage 300 miles per FULL TANK when the gas light comes on.
Old 06-10-2013, 10:17 PM   #4
ragchaos's Avatar
I stopped caring about gas mileage a while ago. Only when I go on 2+ hours of driving do I feather the throttle and super granny style shift. Do you have a AFR Gauge and a Boost Gauge in your car?
PERFORMANCE MODS
Hawk HPS Pads
HKS SSQ III BOV
Haltech Pro Plugin
Turbo XS FMIC
AGP Catch Can
Garrett Boost Gauge
Innovate AFR Gauge
Old 06-10-2013, 10:46 PM   #5
unce unce unce
D!RTYLOUD's Avatar
I do not have a wideband installed due to the fact that I'm completely stock. If I do start modding and upping the boost I most certainly will get one. I will be connecting torque to my 7" tablet very soon as well so I can have a digital readout of my psi/vac as I'm not a fan of gauges in this clean new interior. Lol I'm coming from a 1995 Nissan 240sx Kouki that had an RB25 in it so all this is super neat and up to date for me and I'm not willing to do things to it yet ha!
Do you recommend a certain spark plug? If so what heat range and what gap is usually best ?
Old 06-11-2013, 04:27 AM   #6
Stock you won't find a better plug than the OEM Denso. Only after adding +100 HP should you look for a different heat range.
(R=D)<TPTB
Red Raspberry is offline   Reply With Quote Quick reply to this message
Old 06-11-2013, 06:38 AM   #7
ragchaos's Avatar
+1 I haven't had to change my plugs yet. Just the gap. Although I do have a set of NGK 1 step colder than stock for later on.
PERFORMANCE MODS
Hawk HPS Pads
HKS SSQ III BOV
Haltech Pro Plugin
Turbo XS FMIC
AGP Catch Can
Garrett Boost Gauge
Innovate AFR Gauge
Old 06-11-2013, 10:29 AM   #8
unce unce unce
D!RTYLOUD's Avatar
Awesome that is great info, thank you for that.
I'm going to sound like a n00b here but do you have a part # on those spark plugs? Are they only able to be acquired from the dealer?
EDIT:
Found them lol sorry for that.
FK20HQR8
Old 06-11-2013, 11:54 AM   #9
240SX turned GC
s3t0_S13's Avatar
hey check out socal genesis on facebook, everyones local on there
Competition Clutch
HKS
K
&N
M&S
ABS Dynamic
ARK
AGP
Superlux
Btrcc
PowerAXEL
Magnaflow
s3t0_S13 is offline   Reply With Quote Quick reply to this message
Old 06-11-2013, 08:48 PM   #10
unce unce unce
D!RTYLOUD's Avatar
Cool man will do!
Old 06-12-2013, 06:20 AM   #11
Tyr
Captain Awesomesauce
Tyr's Avatar
Why would you keep the stock flex pipes even after upgrading the core? Rubber and mesh isn't that great for trying to build boost.
Done:
AEM CAI
Synapse Synchronic DV
WeirTech EVOLVE Al. TBE
PA 91 Stage-1
Dynojet CMD+WB2
StopTech SS Lines w/ RBF600
Saikou Michi DC-3 Catch Cans
OEM GT Strut Bar
Eibach Sway Bar Kit
Solar Gard 20% Everything
Tyr is offline   Reply With Quote Quick reply to this message
Old 06-12-2013, 08:45 AM   #12
unce unce unce
D!RTYLOUD's Avatar
I'm not going to be boosting crazy #s or upping the boost at all. a FMIC is all I will be doing engine wise
Old 06-12-2013, 01:08 PM   #13
Robot Over-Lord of Pangea
andy-man 3139's Avatar
Tyr is right. Every time you boost those flex hoses expand. That is robbing you engine of boost. Switch to hard pipes and you will most likely find your boost rising much quicker = more power / better response = more shits and giggles
K&N Typhoon Intake, Vibrant IC, Forge BOV, SFR Custom Tune, Custom Exhaust ( Secondary CAT deleted, 2 1/2" no resonator - vibrant muffler), Lowered on Tein Springs, Prosport Gauges with JCS A pod, Killer-Glass Rad pipe for Rice effect.
andy-man 3139 is offline   Reply With Quote Quick reply to this message
Old 06-12-2013, 08:03 PM   #14
unce unce unce
D!RTYLOUD's Avatar
I want a stock look.
Again, I'm not going for more boost or more power at all. For me the FMIC is just for better cooling as the stock one sucks fat weenie. I didn't want to spend $300 for a pipe kit.
Old 06-13-2013, 04:26 PM   #15
Fair enough. Mod money does not grow on trees. Do you drive your car very hard? If so a oil cooler might be a good next mod in the scal heat.
Old 06-13-2013, 04:55 PM   #16
White 2.0T A/T
ozonegc's Avatar
its up to you but i believe my hard piping made a much bigger difference than changing my fmic to a precision/garrett core. I felt a very nice throttle response and overall power boost.
2012 Karussell White 2.0T A/T
HP - 183 TQ - 205 on stock tune
Mods: Eibach Sportlines, and some stuff ;D pm me if you wanna know how i got to these numbers.......
ozonegc is offline   Reply With Quote Quick reply to this message
Old 06-13-2013, 09:31 PM   #17
unce unce unce
D!RTYLOUD's Avatar
Honestly not at all ! I drive it like a granny and never rev over 3k RPM's.
Old 06-14-2013, 03:49 AM   #18
If you never break 3k you didn't need an upgraded FMIC. the stock one is actually very good. The problem is that its so far back. If you spend a lot of time idling it will heat soak, but as soon as you get the car moving the IAT will drop to normal temps. A bigger FMIC won't buy you any more cooling while the car is stationary. It will only make a difference under hard turbo use.
Old 06-14-2013, 05:24 AM   #19
Ex-DSMer
LandoAWD's Avatar
With all due respect...why buy a turbo 4cyl if this is the case?
2012 Genesis 2.0T Nord Gray A/T
Got some stuff bolted onto it
Chapter 11 Section 42
LandoAWD is offline   Reply With Quote Quick reply to this message
Old 06-14-2013, 05:45 AM   #20
On a MAP sensor equipped engine venting to atmosphere has no bearing on A/F mixture. If the A/F ratio goes up, it does this on a recirculating setup as well.
Keep in mind that depending where you mount your bov (hot side/cold side) will affect how quickly you will build boost.
-Bart
dj_sunrise is offline   Reply With Quote Quick reply to this message
Selling forge bov (atmosphere) RWDcoupe Engine 7 09-25-2012 01:14 PM
FS: Forge Atmosphere BOV $100 Shipped Phat Korean Engine 4 05-22-2012 03:26 PM
Noisy right panel vent/ dealer claims mouse vent inside. epcortek General Discussion 14 07-03-2011 10:57 AM
Need to vent KEgcYYC General Discussion 23 02-04-2010 04:39 PM
Powered by vBulletin® Copyright ©2000 - 2014, vBulletin Solutions, Inc.
