Site Sponsor
![]() Join Date: Feb 2009
So in our never ending quest to find free mods, Hyundai has yet again kicked butt and deciced to give us an adjustable wastegate actuator. What this does is allow us to change the preload on the wastegate itself, which will allow the car to hold more boost. I was a bit doubtful that it would work on our cars because of the more sophisticated ECUs...i was worried it would still do whatever it needed to do to maintain target boost and thus net no gain. So far so good though, car immediately held more boost and gained torque. Unfortunately the dyno guys didnt have the boost sensor hooked up so we could see the actual before and after psi difference, but the dyno definitely speaks. There is definitely a spike in there but i think that is just from us not resetting the ECU and not giving the car anytime to learn. Hopefully once it learns it will smooth it out.
On to the HowTo 1. Remove Turbo heat shield (3) 10mm Bolts 2. Loosen the 10mm Nut that locks the end of the wastegate actuator arm. Back it up to about the end of the threads. 3. Take off the "C-Clip" with a pliers. Be careful and this will like to fly off while you are taking it off and you dont want to lose this. 4. Lift the "swivel bracket" off of the wastegate flapper door bracket. This is the part that we will be turning to shorten the overall length of the wastegate actuator arm. 5. Turn the "swivel bracket" clockwise, as if you were sitting behind the turbo looking at the front of the car. We turned it 2.5 complete turns but i would suggest turning 1.5 times or so and see how the car responds. 6. Place "Swivel bracket" back on wastegate flapper door bracket. 7. Replace "C-Clip". 8. Tighten 10mm Nut. 9. Replace turbo heat sheild (3) 10mm Bolts. ![]() And on to the results. This is OEM vs. OEM w/ wastegate arm adjustment. Literally taken 10 minutes apart. ![]() Video of the pulls. Make sure to watch the 3rd pull. Justin Last edited by GrimmSpeed; 06-03-2009 at 09:29 AM. |
#2 | ||
475whp 93/545whp Q16 SAE
Nice, I gave mine a few turns myself a few days after I got it. Between this adjustment, the mbc, and the intake silencer delete the car feels much better IMO. Glad to see some numbers for changing the preload, did you guys log the boost at all to see if that held any better?
2010 Nordschliefe Gray 2.0t Track - featuring Beyond Redline, PowerAXEL, Cp-e, Mishimoto - FOR SALE $22,500 FIRM |
#3 | ||
Ballin on a Budget
will be trying this tongiht as soon as i get home
2010 Nord Grey 2.0T track 234whp 260lbs on my way to 260whp! Featuring PowerAxel Custom Veo Com Tuned, AEM CAI, RRM Crank Pulley, RRM Shift knob, CXRacing FMIC, MXP TBE, LoveFab Turbo Manifold, HKS SSQV, BuddyClub Coilovers, Progress rear sway bar, Tanabe front sway bar, Tanabe strut bar, Tanabe chassis brace, Carbonfiber H, Custom Fog light Grill (dremel + paint), Sarona Grill, XXR 522 19" Chromium & tint. |
#4 | ||
Added to the [HowTo] sticky
..: J e s s e :.. Easy like Hyundai morning. http://www.pshift-stormrage.com/jess...es/wow/syl.png Sylani <Paradigm Shift> Stormrage-US |
#5 | ||
Site Sponsor
thanks Fleshy!
Justin |
#6 | |||
But good to know. |
#7 | ||
Not pointless actually, especially considering that the stock WG with the stock solenoid attached will still attempt to act stock. The computer in this car WILL try to compensate for what it sees as "unpredicted" conditions, you can be sure of that. We have yet to be told what the release pressure of the stock WG even is but I will bet that it's somewhere in the neighborhood of 8-9psi unregulated. A few turns on the adjustment arm should increase the boost by a few psi but more importantly should help the WG flapper hold longer under exhaust load. It's especially not pointless if you plan on upgrading the turbo later on (which IMO a good number of people will).
#10 | ||
My other ride has 4000hp
I did 2 fulls turns, and it got my boost to 18psi. There is a bit of a parallax effect and I am trying to stay in my lane so as not to stare at the gauge, but it was very close to 18 and the ECU never cut off the boost. That kind of makes me think, it was 17.5? But it was just short of 15 from the dealership, and well past 16 after 2 turns on WG. That was all 1st through 3rd gear.
4-6th gear, the gauge never went past 14, and fell much quicker, I am assuming the ECU did this? |
#13 | ||
So I'm guessing with the 1.5 turn recommendation for the swivel joint that it's ok to rotate the actuator arm itself?
Sorry for the noob question, don't want to break anything.
#14 | |||
It takes a small flathead and about 5 seconds to pop the clip off. Break the 10mm jam nut loose before removing the clip. This whole process takes about 3 minutes start to finish on a cool engine. |
#16 | |||
#18 | ||
Site Sponsor
a half of a turn will not make the swivel joint vertical, did you mean 1/4 of a turn? you can either do a full turn or a half turn(ie 360 or 180 degrees), you cant do quarter turns.
Justin |
#19 | ||
Ahhhh. I was thinking a turn was 180 not 360. I'll give it a shot tomorrow now that I won't break anything.
