#481 | |||
My other ride has 4000hp
#482 | ||
So how will this work having the WB2 and diode jump on the unit already if both ports are already taken.
#483 | ||
Site Sponsor
![]() Join Date: Aug 2009
Each additional module also has 2 CAN ports, so you can continue to daisy chain them together. For instance, the CMD has 2 CAN ports, as does the WB2. To connect the two, you would run the CAN to CAN cable from port 1 on the CMD to port 1 on the WB2. You would then install the CAN termination plug in either of the remaining open ports, which still leaves one port open for the next device. Since that device will also have two CAN ports, when you plug a CAN to CAN cable into one of those ports, you will still have one open port in the chain.
Dynojet Research Automotive Performance Parts Division |
#484 | ||
I see.. I doesn't have to be in a expecific order as long they are connected to a CAN?
Because all I have is one CAN connector open in the WB2. But u guys know how to make it work .. I just like to know how everything work.. Always being that way.. |
#485 | ||
Site Sponsor
That is correct. Location of the open port doesn't matter. Once it's on the bus, it's available.
#487 | |||
The AutoTune is said to work by the CMD reading the WB2 data and creating a closed loop logic based off of the AFR that you tell it (the CMD) you want. So yes, it will prabablyaffect your current setup (unless your current setup has ou running one constant AFR as of now), but it will pretty much do a better job than your current setup much faster than you can with much less runs. Last edited by whatnot; 12-14-2009 at 01:16 PM. |
#488 | ||
Site Sponsor
Nooner has it.
You set the Target AFR table with values of A/F ratio you want the car to achieve, based on RPM and throttle position. Once you start driving the car, the CMD will look at the WB2 data and compare it to what the target is, then create a "trim" for each cell. This is what populates the Trim table as you drive. The next time you connect to the software, you can view/edit/delete the trim table, or apply it to the base fuel map. That will then zero the trim table back to all zeros. Each successive drive cycle should result and smaller and smaller trim values.
#489 | ||
Master Member #518
Are there procedures that you recommend so that Autotune isn't overshooting the target AFR and creating a saw-tooth fuel map?
You make it sound very simple, but in reality no autotune is perfect, and still requires an experienced auto-tuner. Not saying that it will be difficult to learn, but it's not the end all to tuning, and won't be as simple as a click of a button. And this is only on the AFR, not including ignition, etc. Am I wrong?
For Sale: Brand New Injen Cold Air Intake for 3.8 V6, never opened, $280picked up, pm me. "...this isnt a tib. the 3.8 will always be a better engine in stock form, and with boltons, and with a turbo/bigger turbo..." 4TGEN "My [blah blah blah] was a beast, but I don't live in the past..." Hank |
#490 | |||
Current Car: 2007 NHBP Civic Si 4-door, i/h/e and 75shot of spray part out has begun, car has been assigned to DD duty Coming soon: 240SX with a XXXXDET motor ![]() |
#491 | ||
特味! 특미 special flavah!
WOW ..now i gotta start saving up some more add-ons ....T.T.....
well any new maps yet??? ( dynojetcmd.com have 0 map and 16psi maps...).....( i have old 16,20,24 & new 0 , 16 maps..)
Nord Grey 2.0T-> dead... Waiting for 2012 gencoupe..... |
#494 | ||
Master Member #518
^Correct, except that the autotune feature won't be out till late Dec/Early Jan from Dynojets estimate.
#495 | ||
I thought you would have to drive and AutoTune would give you a base of which to fine tune from, but this sounds way better! I didn't even think about smaller trimming each time, sweet.
#496 | |||||
Site Sponsor
The beauty of AutoTune is that it IS very simple. Create a table with the A/F values you wish to target and it does the rest as you drive. Quote:
For A/F ratio, yes.
#497 | |||
Master Member #518
#498 | |||
So the Auto tune is for open loop then? That would make sense. But if it is used in closed loop too that would not.
2010 Red 2.0L track Quote:
#499 | |||
I am assuming my reference above to closed loop threw you off? |
#500 | ||
Site Sponsor
The CMD should only be used to trim/AutoTune (go closed loop) in areas that the stock ECU is in open loop; however, the CMD is not limited to those areas - so if you did specify a target A/F ratio in areas where the stock ECU was still in closed loop, the CMD would still try to trim to achieve your specified target AFR.
This may be beneficial if you know the original closed loop targets and happen to run larger injectors. You can then tell the CMD to target the same A/F ratio as the stock computer, therefore keeping the stock trim values quite small.
