Tomei M7960 Bolt on Turbo *pictures* - Page 2 - Hyundai Genesis Forum
post #21 of 712 Old 03-05-2014, 04:59 PM
Next year its my turn
DaGr8WoN is offline
post #22 of 712 Old 03-05-2014, 07:06 PM
nyangineer's Avatar
Quoted: 175 Post(s)
No. I highly recommend you do much much much more research before you spend any $$$ and post your results to be scrutinized and learn from it.
nyangineer is offline
post #23 of 712 Old 03-05-2014, 07:51 PM
Yes
DaGr8WoN is offline
post #24 of 712 Old 03-05-2014, 09:29 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Here are some pics of my ACT clutch and Fidanza flywheel that will be going in this weekend
D!RTYLOUD is offline
post #25 of 712 Old 03-05-2014, 09:40 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Let's not forget these bad boys
post #26 of 712 Old 03-09-2014, 01:50 PM
LM
Lynam's Avatar
Quoted: 13 Post(s)
I want/need this set up! Might go with the ACT flywheel though since it has more weight to it.
2010 Black 2.0T
Rspec
Lynam is offline
post #27 of 712 Old 03-09-2014, 09:58 PM
dew
팥빙수
dew's Avatar
sub'd. I also will probably do this setup next year.
2012 2.0T Base Nordschleife Grey
-Brembo calipers -Brembo sport drilled rotors -Hawk HPS pads (front) -EBC Yellowstuff (rear) -ATE super blue
-cp-e intake -TurboXS steathback (heat wrapped) -TurboXS GT catback -TurboXS FMIC -ISC coils -Varrstoen es2 19X9.5/10.5 - Michelin Pilot Super Sports -OEM LSD -SFR Custom tune!!!
-Alpine type-s speakers all around -JBL 8" sub -Custom backup camera
http://goo.gl/tMQM7 Some pics
dew is offline
post #28 of 712 Old 03-09-2014, 11:04 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Got the flywheel, clutch installed, and new OEM slave installed today! And boy can I say the clutch feels SOOOOO awesome! The pedal feel is say is probably 10-20% stiffer than stock but nothing intense. It grabs perfectly and fast. It honestly feels like in learning to drive stick over again. I do get loud "chatter" "shudder" from the transmission due to the SMF. I really only hear it at low RPMs (700-2500); it wil def take some getting use to but it's either no noise no power or power with some noise. Oh, I had to run to harbor freight for a pilot bearing removal tool ($17.99); was very simple to remove the pilot bearing from the OEM flywheel and press it into the new flywheel.
post #29 of 712 Old 03-10-2014, 12:39 PM
Finally Boosted
edman24's Avatar
Quoted: 12 Post(s)
AHH, so here we have the real info a lot of us were looking for, the Fidanza flywheel does make noise as well. From what other people were saying the Fidanza ACT combo was supposed to be quiet and not much stiffer than stock. At least I know now I didnt totally waste my money on the CC setup, I like my stage 3 ceramic, going on 2 years and almost 30k miles strong. I will say though I do baby my clutch and tranny. I am probably nicer to my car than anyone else. I dont want to break anything lol... Cant wait to hear about the turbo, been considering going this route as well, good luck DIRTY
'10 Genesis Coupe base 2.0t
I wasn't asking you.
edman24 is offline
post #30 of 712 Old 03-10-2014, 01:43 PM
nyangineer's Avatar
Quoted: 175 Post(s)
Do you have the braided clutch line? You can ask BTR to tune your idle to remove the trans noise.
post #31 of 712 Old 03-10-2014, 02:37 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
It's MUCH MUCH quieter than the CC clutch/flywheel combo. The stock pedal feels honestly isn't that much different but it does catch very fast (which is great for me). I will def keep you all posted and update this thread with turbo install pics.
I have absolutely no noise when at idle. No complaints there at all. The only time I hear noise is when driving in low RPMS or when in gear but off the gas slowing down. It sounds like a disele. I will try to get a video but it's hard to hear. I do not have a braided line, I used stock line but replaced the slave cylinder, flywheel, clutch, and did a tranny fluid flush.
post #32 of 712 Old 03-10-2014, 02:42 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Here is a video I made at night. You can hear it right off the get go. Sorry for the wind noise lol, best I can do. Only happens at low RPMS.
Click the pic to watch the video lol.
post #33 of 712 Old 03-11-2014, 10:19 AM
squid
chazzyfie5's Avatar
Mmmm sexy
chazzyfie5 is offline
post #34 of 712 Old 03-11-2014, 11:12 AM
nyangineer's Avatar
Quoted: 175 Post(s)
Thought you said the flywheel chattered at idle RPM?
post #35 of 712 Old 03-11-2014, 12:20 PM
Need more power !
Valenz's Avatar
Quoted: 69 Post(s)
Wow, I am going to end up going with this setup!!!
What setting on the MBC is suggested with the BTR tune?
2014 2.0 R-SPEC - SFR Tune and other goodies !
Valenz is offline
post #36 of 712 Old 03-11-2014, 12:21 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
No it does NOT chatter at idle. The only time I hear it is when I'm driving in low RPMs or while in gear but off the gas slowing down coming to a stop. Absolutely no noise when at idle.
post #37 of 712 Old 03-11-2014, 12:23 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
18psi for stock turbo manifold or 20psi for aftermarket manifold. I am going with ported and polished stock manifold so I'll have to see if I can bump mine to 20psi. For now I'll be running 18psi.
post #38 of 712 Old 03-11-2014, 01:11 PM
nyangineer's Avatar
Quoted: 175 Post(s)
So you're driving around in gear at less than 1000 RPM?
post #39 of 712 Old 03-11-2014, 03:24 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Sure? Everyone does, especially when they take off from a stop.
It's mostly there at and around 2k RPM. I like to change gears at about 3k. I'm not in any rush to get where I'm going and usually drive very conservative.
For anyone reading this, it's not bad at all. It will take some time getting use to but well worth it. Clutch and engagement feels superb.
post #40 of 712 Old 03-11-2014, 06:56 PM
squid
chazzyfie5's Avatar
subscribed!!
when are you thinking about putting it together?
[BTRcc] Tomei M7960 ARMS Turbo Full review BTRcc 2.0T Discussion 2008-2012 16 02-19-2014 10:25 AM
Tomei M7960 Turbo Questions rva_cmk 2.0T Discussion 2008-2012 36 01-25-2014 10:56 PM
ENJUKU RACING|Tomei Arms M7960 Bolt-On Turbo Kit - Rated 400+hp Enjuku Racing Engine 0 05-29-2013 06:03 AM
