Tomei M7960 Bolt on Turbo *pictures* - Page 5 - Hyundai Genesis Forum
post #81 of 712 Old 03-30-2014, 06:53 PM
Huge member
shift_2.slowT's Avatar
Sub'd for results. This is what I plan on getting, but I'll be going with an aftermarket manifold. Question though, is there any reason you had the shop mill down the turbo inlet flange to be flat on the stock manifold?
-Danny
'12 Bathurst Black 2.0T R-Spec
Xentec 5000k lo beam HID's
M&S Type D grill
K&N Typhoon
Kinugawa BOV
TurboXS FMIC
Exceladyne offroad catless downpipe
DC Sports quad-tip catback
PRW Stg 2
Denso 550cc inj
Depo Racing boost gauge & wideband
Hallman Pro mbc
CC stg4 clutch/fw
Dynojet 265whp/316wtq @ 20lbs
Originally Posted by Carbon View Post
A red light depicting a man with an airbag in his face may be due to an airbag issue. That or he is motor boating tits. You may need more tits.
shift_2.slowT is offline
post #82 of 712 Old 03-30-2014, 07:30 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
They put it on the mill to open the hole more. In doing so, it removes that raised little ring that use to be the flange opening. I suppose the reason was to just to open up the exhaust manifold more.
D!RTYLOUD is offline
post #83 of 712 Old 04-01-2014, 08:45 PM
Ecu
Hello all I have been following this thread as I have ordered the same kit. Question for Dirtyloud. I just recieved my ECU from Korea. It looks like its sealed OEM from Hyundai. Am I too assume this thing is tuned for the 7960? There is no paper saying anything in that regard? Also other question. Are people melting things with the new turbo's and manifold DD or or they racing?Am I going to melt stuff hauling on it for a gear or two? Thanks for you input.
2010 2.0T, Tomei 7960 with BTR canned tune, Deatsch 750 injectors, Synapse exhaust manifold, Kamak intercooler, Synapse BOV, CPE turbo back exhaust with HFC, CPE intake. CC stage 2 clutch, AEM Failsafe gauge, GFB MBC.
endersroc is offline
post #84 of 712 Old 04-01-2014, 08:57 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
The plastic that the ECU came in had a slit in it correct? I too was thinking the same thing as you but seeing as though it was cut open and the ECU was removed, I'm assuming it has the tune loaded on it ; now with the correct options, that I DONT know yet, won't know till it's time to rock and roll.
What is this melting you speak of?
post #85 of 712 Old 04-01-2014, 09:06 PM
Duh, pulled the bag fully apart and I see that it has been cut open. Thanks for the quick response. The melting I am talking about is melting of the fusebox, O2 sensor cables and hoses above the downpipe and the plastic valve cover. I saw that people were either putting shields on to protect these parts or DEI heat reflective tape. I can't put my OEM manifold shield back on cause I went with the synapse manifold. I just wasn't sure if meltage was happening only with aggressive driving or if the stuff was melting period.
post #86 of 712 Old 04-01-2014, 09:12 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Oh, can't say I know the answer. I've never even seen this problem lol. I'm guessing it's due to the manifold tho. A nice hear wrap on the mani would help out.
post #87 of 712 Old 04-01-2014, 10:41 PM
Function Over Form
1320drift's Avatar
Sick turbo. Makes me want one to. I don't know a great deal about it but I think those washers are not a good idea because of the heat. Those washers could even melt. Also certain metals will expand at different rates which could cause them to loosen up.
Parts Shop Max Level Up
SFR tuned
1320drift is offline
post #88 of 712 Old 04-01-2014, 10:48 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
It's possible, but I think it will be fine. Only one way to find out right? Haha
post #89 of 712 Old 04-02-2014, 01:50 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Received my OEM intake manifold gaskets, 1 step colder NGK plugs, and my AEM wideband today.
post #90 of 712 Old 04-02-2014, 02:42 PM
Very nice looking set up. But that's not how you safety wire bolts together. Either example hehe.
12whitecoupe is offline
post #91 of 712 Old 04-02-2014, 02:59 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Just found a nice tutorial on how to do it! Thanks for lettimg me know. Looks like I have to drill another hole in each bolt to properly do it.
post #92 of 712 Old 04-02-2014, 03:15 PM
Yeah I was going to but was curious to see if I got flammed lol.
Basically, you want to create a figure 8 between each bolt wired together. So knowing lefty loosey, righty tighty. The idea is to use one length of wire, loop it through the first bolt and then loop it through again. Then pull it tightly towards the other bolt head and double wrap it the opposite way through bolt head number two. Then meet each end in the middle, cut most of the excess wire and then tightly coil each end together. This way if either bolt tries to walk out it can't move since the figure 8 prevents any way for the bolts to back out. They are always working against each other to keep them seated.
There is actually a specific wire tying tool and aircraft grade wire available in contained spooled lengths. Google 'wire tying pliers'
What you have will work but there is a precedure for it. We tie bolts together quite often for many different applications at work.
post #93 of 712 Old 04-02-2014, 03:33 PM
nyangineer's Avatar
Quoted: 175 Post(s)
nyangineer is offline
post #94 of 712 Old 04-02-2014, 03:42 PM
Yep. So for two bolts you can imagine the figure 8
post #95 of 712 Old 04-02-2014, 04:31 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
http://youtube.com/watch?v=XktwpWPFvHs
post #96 of 712 Old 04-02-2014, 04:47 PM
Or there's all those ways lol. I'll stick to what I know. More then one way to skin a cat haha.
post #97 of 712 Old 04-02-2014, 05:04 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
I'll have to drill new holes in the head of the bolts tonight if i get a chance. I'll probably try the method in the video and report back lol. May also install the wideband.
post #98 of 712 Old 04-02-2014, 07:51 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Ok so had a little free time tonight.
post #99 of 712 Old 04-03-2014, 06:13 AM
nyangineer's Avatar
Quoted: 175 Post(s)
Bolt on the right seems ok, left one might get loose
post #100 of 712 Old 04-03-2014, 06:21 AM
Why so serious, Bro?
GenCoupeGeek's Avatar
Quoted: 1199 Post(s)
Yep, negative safety on the one on the left.
BTRcc Custom Tuned
~Albert Einstein
GenCoupeGeek is offline
[BTRcc] Tomei M7960 ARMS Turbo Full review BTRcc 2.0T Discussion 2008-2012 16 02-19-2014 11:25 AM
Tomei M7960 Turbo Questions rva_cmk 2.0T Discussion 2008-2012 36 01-25-2014 11:56 PM
ENJUKU RACING|Tomei Arms M7960 Bolt-On Turbo Kit - Rated 400+hp Enjuku Racing Engine 0 05-29-2013 07:03 AM
