Tomei M7960 Bolt on Turbo *pictures* - Page 6 - Hyundai Genesis Forum
post #101 of 712 Old 04-03-2014, 05:28 AM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Crap lol! I've never had to safety wire anything. I feel so n00b.
D!RTYLOUD is offline
post #102 of 712 Old 04-03-2014, 05:34 AM
Why so serious, Bro?
GenCoupeGeek's Avatar
Quoted: 1205 Post(s)
Always pull in a clockwise direction. 21 years of working on helicopters with every bolt safetied and sometimes I get it backwards too.
Also, take the pigtail and loop it in on itself rather than trying to squish it inline with the wire. Stray safety wire ends tend to cut hands really bad.
BTRcc Custom Tuned
~Albert Einstein
GenCoupeGeek is online now
post #103 of 712 Old 04-03-2014, 05:54 AM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
RIGHT ON! Thanks man, I appreciate it. I need to find some better wire. I'm using galvanized steel at the moment. Doesn't seem to bed in a good shape really, it's like it's almost impossible to pull tight.
post #104 of 712 Old 04-03-2014, 06:37 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
So I had some free time today after work, so I decided to mounnt my WB and get it all wired up. I didn't connect the sensor since the stock o2 is still connected, however the wiring is all ran and connected.
I used a 2" hole saw to cut into the dashboard. TAKE YOUR TIME.
I decided to feed the sensor wires from the engine bay through the firewall. There is a tiny small opening between the firewall and the heater motor inside the the car on the passenger side. I pulled the wire down and ran it behind the dashboard.
post #105 of 712 Old 04-06-2014, 02:20 PM
Huge member
shift_2.slowT's Avatar
Originally Posted by D!RTYLOUD View Post
They put it on the mill to open the hole more. In doing so, it removes that raised little ring that use to be the flange opening. I suppose the reason was to just to open up the exhaust manifold more.
Gotcha, makes sense. Looking forward to your results
-Danny
'12 Bathurst Black 2.0T R-Spec
Xentec 5000k lo beam HID's
M&S Type D grill
K&N Typhoon
Kinugawa BOV
TurboXS FMIC
Exceladyne offroad catless downpipe
DC Sports quad-tip catback
PRW Stg 2
Denso 550cc inj
Depo Racing boost gauge & wideband
Hallman Pro mbc
CC stg4 clutch/fw
Dynojet 265whp/316wtq @ 20lbs
Originally Posted by Carbon View Post
A red light depicting a man with an airbag in his face may be due to an airbag issue. That or he is motor boating tits. You may need more tits.
shift_2.slowT is offline
post #106 of 712 Old 04-07-2014, 05:31 AM
mpuente55's Avatar
Subd for some future dyno results!!
[COLOR="Blue"]2012 Genesis 2.0T M/T
AEM Cold Air Intake System,
TurboXS RFL BOV
SFR 1.5 Canned Tune
ISR Race Exhaust
ISR Test pipe
CNT 02 Housing
CNT downpipe
TURBOXS FMIC
2006 LS2 Pontiac GTO
Longtube pacesetter headers
Tsunami Cam
1 chamber flowmasters
600+ RWHP
fish tail going 80mph
mpuente55 is offline
post #107 of 712 Old 04-07-2014, 12:50 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Grimmspeed exhauat mani gasket came in today! I officially have everything needed to install my setup! Woohoo!
post #108 of 712 Old 04-07-2014, 02:18 PM
nyangineer's Avatar
Quoted: 175 Post(s)
I'm jelly.
nyangineer is offline
post #109 of 712 Old 04-07-2014, 08:49 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
@itslikeanegg
So the actuator comes preset from the factory at 12.8psi.
post #110 of 712 Old 04-07-2014, 09:40 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Also, finally got the safety wire tying the right way lol.
Sorry for such SLOW progress guys. Just trying to take my time; also I'm having my front end painted in a week and don't want to leave my ride at the shop with an upgraded turbo.
post #111 of 712 Old 04-08-2014, 03:16 AM
mpuente55's Avatar
Stupid question but if the actuator is set at 12.8, if you have a canned tune that is running 20 pounds of boost then are we going to need to use the boost controller to then adjust that until a custom tune takes place?
Like I said sorry for the dumb question I'm the kind of person who didn't buy my gauges just because I haven't decided what route to take but I'm leaning towards this turbo as well as a meth kit, etc. (So I want to make sure I buy the gauges I need)
TurboXS RFL BOV
SFR 1.5 Canned Tune
ISR Race Exhaust
ISR Test pipe
CNT 02 Housing
CNT downpipe
TURBOXS FMIC
Tsunami Cam
600+ RWHP
post #112 of 712 Old 04-08-2014, 03:37 AM
Cost of build?
DaGr8WoN is offline
post #113 of 712 Old 04-08-2014, 06:35 AM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
You can still run the turbo at 12.8 psi it just won't be as responsive or make as much power. Yes you need a boost control. A manual or electronic work
post #114 of 712 Old 04-08-2014, 06:45 AM
mpuente55's Avatar
Okay, so having a canned tune by sfr running at 20psi on stock turbo won't mess up when running the bolt on Tomei that is set to run at 12.8 psi? Know What i mean lol? Sounds like I'll need to adjust to the boost that ecu is reading once I bolt it on. But that didn't sound right to me. Little confused so learning about these cars. And alright will do.
TurboXS RFL BOV
SFR 1.5 Canned Tune
ISR Race Exhaust
ISR Test pipe
CNT 02 Housing
CNT downpipe
TURBOXS FMIC
Tsunami Cam
600+ RWHP
post #115 of 712 Old 04-08-2014, 07:11 AM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
It will not work. You need a tune for the Tomei turbo. You can't buy their bolt on tune and the expect it to work once you get the new Tomei turbo, not gonna happen. You also need larger injectors which won't be accommodated for with the SFR tune since it's only a bolt on tune. Also, save your $ and go with the BTR tune.
post #116 of 712 Old 04-08-2014, 07:16 AM
itslikeanegg's Avatar
Quoted: 11 Post(s)
A tune is generally made for specific mods (with canned tunes offering some room for small variances). If you currently don't have a Tomei turbo and have a tune that works well for your car then it will not work with a drastically different set of mods (like an upgraded turbo or injectors).
SOLD - 2011 Tsukuba Red Genesis Coupe 2.0T RSPEC
CURRENT - 2010 White Satin Pearl Genesis Sedan 4.6 with Tech Package
-Dynomax VT Mufflers
-MSA Secondary Cat Deletes
-R2C Intake
-Uniq Rigid Collars
-2013 RSPEC Suspension
-Remote ESC Disable
itslikeanegg is offline
post #117 of 712 Old 04-08-2014, 07:23 AM
mpuente55's Avatar
OK makes sense, I was just making sure on that part but yes I have a set of 750cc injectors already. I was planning to do a custome tune. Was going to go with btr but sfr had came here before btr so yeah. Couldn't wait Idk why lol.
TurboXS RFL BOV
SFR 1.5 Canned Tune
ISR Race Exhaust
ISR Test pipe
CNT 02 Housing
CNT downpipe
TURBOXS FMIC
Tsunami Cam
600+ RWHP
post #118 of 712 Old 04-08-2014, 07:27 AM
Careful... don't confuse pressure with flow volume. Larger turbos have much more flow volume than the little stock one does. Although you can hit 20 PSI on the stock turbo, you can't hold it... bigger turbos can and do. The SFR tune accounts for the tapering effect on the stock turbo but does not account for the volume of air being pushed by a much bigger turbo.
In any case, the 12.8 psi wastegate setting is the failsafe in the event that your boost controller goes wonky and fails closed. In other words, you would not be able to manually set your boost lower than 12.8 psi, but with a manual or electronic boost controller you can raise it.
BTRcc Custom Tuned
~Albert Einstein
post #119 of 712 Old 04-08-2014, 07:31 AM
mpuente55's Avatar
Thanks, I appreciate the feedback. I will be buying this kit. Post up some dyno numbers when your done with this kit.
TurboXS RFL BOV
SFR 1.5 Canned Tune
ISR Race Exhaust
ISR Test pipe
CNT 02 Housing
CNT downpipe
TURBOXS FMIC
Tsunami Cam
600+ RWHP
post #120 of 712 Old 04-08-2014, 07:39 AM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Will do! Hopefully it won't be too much longer. I'm also curious to see what itslikeanegg's numbers will be also.
@DaGr8Won,
I got the turbo, Tune, injectors, and MBC for $2,100. But you also need full bolt ons (FMIC, intake, CBE, o2 housing).
[BTRcc] Tomei M7960 ARMS Turbo Full review BTRcc 2.0T Discussion 2008-2012 16 02-19-2014 10:25 AM
Tomei M7960 Turbo Questions rva_cmk 2.0T Discussion 2008-2012 36 01-25-2014 10:56 PM
ENJUKU RACING|Tomei Arms M7960 Bolt-On Turbo Kit - Rated 400+hp Enjuku Racing Engine 0 05-29-2013 06:03 AM
