D!RTYLOUDS SHEEPEY BUILT / 91&E85 / Precision 5862 top mount setup *PICTURES* - Hyundai Genesis Forum
 107Likes
post #1 of 434 Old 07-28-2014, 10:25 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Exclamation D!RTYLOUDS SHEEPEY BUILT / 91&E85 / Precision 5862 top mount setup *PICTURES*
Hey All!
I'm back at it again, and this time hopefully with a positive outcome! As some of you may know I previously had the Tomei kit from BTR which didn't turn out so great; long story short is that I sold it and with the cash I'm building/piecing together a new setup!
The parts I will be using.
2013 2.0T motor (of course with my 2010 IM & accessories)
2013 2.0T 6spd transmission
2013 OEM Valeo DMF
2013 Valeo HD clutch
TurboXS vband top mount manifold
TurboXS vband o2 housing for top mount
TurboXS FMIC hot pipe for top mount
Precision 5862 .64 AR vband Turbo
Tial MV-R 44mm vband external wastegate
Injector Dynamics 1000cc injectors
DW300 fuel pump
Haltech Double mapped tune for 91/E85
***** SO I'VE ACTUALLY CHANGED THE SETUP A BIT FROM PREVIOUSLY STATED.*****
Sheepey Built turbo maifold
Sheepey Built o2 housing
2013' 2.0T Fuel sending unit (85psi)
You will find these updates later on in the thread.
My goal is 450whp/400wtq
I know some of you may think I'm crazy for using the 13' DMF however there has not been one reported broken 13' DMF And some of these 13's are running 375wtq on stock DMF/clutch so I'm certain it'll hold, plus I won't have nasty SMF chatter.
Currently I have the TurboXS o2 housing and TurboXS top mount manifold. I've purchased the 5862 already just currently waiting for it to arrive (torture). I picked up the mani/o2 housing for an EXCELLLLLLENT price so couldn't pass on the deal. It has black thermal heat coating as well.
I WILL BE UPDATING THREAD AND POSTING PICTURES AS PARTS COME IN.
Thanks for viewing! Happy building.
Here is a full list of mods I can think of off the top of my head
2010 Nord Gray 2.0T Track
7" Tablet Install
AEM EUGO wideband
LCD Relocation
Black/Red Track Interior
13' Front end conversion
Custom headlights w/ halos done by El Stig Garage
DIY OEM hood vents
DIY front grill
DIY fog bezel grills
Suspension/Brakes:
PBM Comp Coilovers
Rear FRS PBM Shock Bodies
PBM Rear Upper Control Arms
Brembo Brake Calipers
Hawk Brake Pads
Wheels/Tires:
Zedd Performance SL5
19x9.5 +12 on Accelera 225/35/19
19x11 +10 on Accelera 255/35/19
Engine:
2013 2.0T Motor Swap
2013 6SPD M/T Swap
PNP/Powder Coated Intake Manifold
Grimmspeed Phenolic Spacer
TurboXS top mount o2 Housing
TurboXS FMIC
Precision 5862 CEA Turbo
Tial MV-R 44mm external wastegate
Powder Coated Matte black Compressor housing
Powder Coated Matte black FMIC pipes
Custom 3" Down Pipe
ISIS Street 3" CBE
ISIS 3" Test pipe
K2 Black Turbo Blanket
Beyond Redline Heat Shield
Custom turbo oil feed/drain lines
2013 Dual Mass Flywheel
2013 Valeo HD Clutch Kit
BrandonM likes this.
D!RTYLOUD is offline
post #2 of 434 Old 07-28-2014, 10:34 PM
lokiinlove's Avatar
Quoted: 78 Post(s)
subd for awesomeness
good luck with your build) Is motor built already or you do not plan to upgrade internals?
lokiinlove is offline
post #3 of 434 Old 07-28-2014, 10:48 PM
-3point8it-
MeThatsWho's Avatar
Quoted: 31 Post(s)
I'm in for the entertainment and to watch a sick set up in the making! .Good luck with the build!
2013 R-Spec 3.8L
*BtR*
*Bc Br*
*InJeN*
*NaMeLeSs*
*WiNg KiT*
*MaGnAflOw*
*SaIkOu MiChI*
Have you ever noticed.... Anybody going slower than you is an idiot, and anyone going faster than you is a maniac? -George Carlin
MeThatsWho is offline
post #4 of 434 Old 07-28-2014, 10:52 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Will not be touching the internals, they are strong enough to handle my power goals. A buddy of mine (KHARtunerz owner) is currently running the TurboXS GTX30 on his stock 13' motor making 466whp / 407wtq and not even a sign of knock or anything negative. He actually topped out due to his MAP sensor since he's using the 10-12 sensor. I plan on using the 13' sensor.
post #5 of 434 Old 07-29-2014, 04:47 AM
buy me some race gas!
whatever210's Avatar
Quoted: 15 Post(s)
Looking good man. Now you just need a 02 housing and your golden
Edit: I fail at reading lol
WANT A TOP MOUNT TURBO SETUP?
LOOK HERE!
All the info on fuel return setup can be found in here!
http://www.gencoupe.com/gencoupe-build-projects/67267-another-build-thread-whatever210.html
whatever210 is offline
post #6 of 434 Old 07-29-2014, 04:57 AM
RspecPremio's Avatar
Subd
2013 2.0t Rspec
Gran Premio Gray
SFR Custom
274hp 296tq (el paso tx)
RspecPremio is offline
post #7 of 434 Old 07-29-2014, 04:59 AM
that guy
kepone's Avatar
Quoted: 82 Post(s)
Subbed!
'12 2.0T 6SP - ???whp
USRT Genesis II 1200cc
Tuned by Dardan Tuning
Grimmspeed Ported Intake Mani
Haltech
GarageLine STS
ACT Fidanza Clutch/FW
Saikou Michi Catch Cans
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #8 of 434 Old 07-29-2014, 05:00 AM
that guy
kepone's Avatar
Quoted: 82 Post(s)
I'll just leave this right here
Haltech
GarageLine STS
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #9 of 434 Old 07-29-2014, 05:29 AM
Burger King Dildo Hammer
grilledcheez's Avatar
Quoted: 36 Post(s)
I wish I had this kind of time and money for two different turbo builds back to back...lol
Looking forward to seeing how this build goes!
2010 Bathurst Black 2.0T Premium M/T
Project - Ass To Mouth Annihilator (ATMA)
grilledcheez is offline
post #10 of 434 Old 07-29-2014, 07:13 AM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Hard work and DEDICATION. Trust me, it's not easy saving or holding onto money. I am married with a wife so it's stressful but I still manage and she understands I love cars.
I sold the Tomei kit so that's how I funded most of this "new" setup.
post #11 of 434 Old 07-29-2014, 07:13 AM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
OH! You baaaaaaaaad
post #12 of 434 Old 07-29-2014, 08:11 AM
Quoted: 15 Post(s)
lol that's what I do with everything. I bought a turbo kit years and years ago. I sold my 240 so I put the money into genesis. then I bought turbo kit. my wife sees it as I have extra money. I always explain to her that its not extra money. im selling my parts to transfer to something else. its like the circle of life. like the lion king lmao. so I never have to put much money into my next setup. I buy things that hold value pretty well lol. so she argues with me that we could use that money. I say hey. if it was still on my car it would be just sitting there anyway. I wouldn't have the money if it was still sitting there. she huffs and puffs but I just move my car money where ever I want. so I never using our regular money just transferred money. maybe you can relate.
LOOK HERE!
post #13 of 434 Old 07-29-2014, 10:18 AM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Hahaha it's seriously so funny you say that because I can relate 100%. Mine does the same thing once in a while and I simply explain "just pretend I don't have this money because really I don't, it's money I got from selling my other parts that will fund the new parts so I'm not just spending money we could have used". LOL.
post #14 of 434 Old 07-29-2014, 03:36 PM
GT30Rspec
TVONE2's Avatar
Go Go Gooooo.....
PowerAxel
TVONE2 is offline
post #15 of 434 Old 07-29-2014, 04:13 PM
Korean Asswhoopin
Thumb5's Avatar
Quoted: 100 Post(s)
Gonna need a bigger turbine housing to get over 400. We couldn't hit 450 with a Borg warner efr 7267. Fyi
2010 Grey Hyundai Genesis Coupe 2.0T Track - Beyond Redline - Haltech and BW EFR 7063 - 385 whp and 345 wtq - Crappy gas
2016 VW Tiguan S Daily
Thumb5 is offline
post #16 of 434 Old 07-29-2014, 05:03 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
I'll make over 400whp . Maybe not 450whp.
post #17 of 434 Old 07-29-2014, 05:18 PM
ragchaos's Avatar
Holy ****, this is interesting!!!!
2010 Genesis Coupe 2.0T Track Edition
PERFORMANCE MODS
Road Race Motorsports Short Ram Intake
Agency Steel Braided Brake Line
Stoptech Slotted Rotors
Hawk HPS Pads
CP-E TurboBack Exhaust (Catted)
HKS SSQ III BOV
Haltech Pro Plugin
Turbo XS FMIC
AGP Catch Can
Garrett Boost Gauge
Innovate AFR Gauge
ragchaos is offline
post #18 of 434 Old 07-29-2014, 07:28 PM Thread Starter
unce unce unce
D!RTYLOUD's Avatar
Quoted: 77 Post(s)
Decided to snap a few more pics of the manifold and o2 housing after I sprayed it down.
Here are some pics of my 10-12 intake manifold that I had powder coated matte black. This IM has also been ported and polished
Here you can see the 2 inner runners have been pnp
I also am using the Grimmspeed phenolic spacer
post #19 of 434 Old 07-29-2014, 08:54 PM
Subbed
n1ck is offline
post #20 of 434 Old 07-29-2014, 09:06 PM
What can the stock motor handle?? Just curious as i see so many guys swapping turbos. From a tib owner, the motor was pretty fragile in the 300+whp. Curious what a safe number is for the 2014 2.0T motor
solidandregt is offline
WTB: TurboXS hot pipe for top mount setup. D!RTYLOUD Want to Buy 0 07-27-2014 09:19 PM
FS:TurboXS top mount manifold ellis8944 Engine 0 06-23-2014 11:31 AM
fs: top mount, precision 6262, 46mm wastegate, COMPLETE KIT W/ HALTECH Saucy16 Ontario Classifieds 32 03-04-2014 08:06 PM
TurboXS top mount manifold Tim Engine 19 06-29-2013 10:13 AM
SFR top mount Turbo setup MuffinMan89 2.0T Discussion 2008-2012 6 02-15-2009 09:50 AM
