Throttle position sensor calibration - Hyundai Genesis Forum
post #1 of 5 Old 05-23-2015, 01:56 PM Thread Starter
I replaced my throttle body. I have my obd2 reader plugged in and noticed that the throttle never registers more than 86.3% open regardless of rpm or length of time at WOT. The TB is clean. Is there a procedure to perform which allows it to open 100%? I manually opened it as far as it would go and it read 93% on the obd2 reader.
NomadTrash is offline
post #2 of 5 Old 05-23-2015, 02:34 PM
inertiamonster's Avatar
Quoted: 601 Post(s)
~85% is all the way open on the coupes. See this thread: When is 85%=100% TPS sensor
2013 3.8 Track Pearl White
inertiamonster is offline
post #3 of 5 Old 05-23-2015, 03:12 PM Thread Starter
My wideband also shows that it starts out around 13.5 under full boost and gradually goes down to 11.2 as rpm rises.
post #4 of 5 Old 05-23-2015, 10:54 PM
Quoted: 134 Post(s)
i never see more than 85% either so seem's all right
genspec13 is offline
post #5 of 5 Old 05-28-2015, 09:24 PM
lokiinlove's Avatar
Quoted: 78 Post(s)
You do realise that 13.5 is lean? Normally people are running 11.5, sometimes 12.4 (on AT bbb claimed 12.4 works best), on unported IM.
EFR 7670 2.0T BK1 A/T build -> http://www.gencoupe.com/gencoupe-build-projects/582313-lokiinlove-s-2-0t-t-build-thread.html
lokiinlove is offline
Problems with Revs going up between shifts. Throttle position sensor? Ecreps 2.0T Discussion 2013 and up 6 05-09-2015 04:31 PM
hm throttle position sensor? throttle cable? throttle body stuck? hajimah 2.0T Discussion 2008-2012 9 02-22-2015 03:16 PM
Throttle position sensor output voltage lead? YellowGC 3.8 V6 Discussion 2008-2012 20 07-14-2010 01:31 AM
Throttle Position vs HP Floorit 2.0T Discussion 2008-2012 7 01-05-2010 09:37 AM
electronic throttle and gear position sensor; are we getting ****ed? mr_desmo Engine 46 03-10-2009 03:20 PM
