How catch PowerSteering Fluid Flush? - Hyundai Genesis Forum
post #1 of 5 Old 12-10-2015, 01:22 PM Thread Starter
Quoted: 24 Post(s)
Hi guys,
I am flushing my daily driver 2010 2.0t at 45k miles because their is a whine while idle/load and a fast paced click sound on a pulley at cold start. I've researched that to flush the PS fluid resevoir, I pull the bottom tube off the resevoir and catch the emptying fluid.
WTF do I catch this with? Theres no space to fit anything that will fit 1L+
Whatd you guys use?
solbert is offline
post #2 of 5 Old 12-10-2015, 01:44 PM
Advenio Pariter
TsukubaRed_PA's Avatar
Quoted: 354 Post(s)
There are some videos on Youtube which may help. You can remove a bulk of the fluid with a turkey baster. Underneath, pull a line with the car up and drain the rest by moving the steering wheel back and forth. Some people start their engine and use the pump. A pump without fluid...not good IMHO. I think a few people have replaced their fluid on this forum so search around here first as I recall a posting or two on how it was done. It might save you both time and money. If you can get 90% of the fluid out using an easy method outline on here that should be fine.
2011 Base 2.0T, 5AT
Trunk Lip Spoiler
Fog Lights
Uniq Rigid Collars
JEGS Oil Separator - Turbo
Dynamat Hoodliner
Warranty: New Tails
2013 Elantra GT, 6AT (hers)
-- previous rides --
Salsa Red 2004 Vibe GT 6MT
TsukubaRed_PA is offline
post #3 of 5 Old 12-11-2015, 08:10 AM
If you get to the cooler from underneath you can easily disconnect a hose and all the fluid will drain out gravity wise.
post #4 of 5 Old 12-14-2015, 12:21 AM
Quoted: 238 Post(s)
I would change the belt first since in your signature, it states you have a 2010.
it's about due for a belt change.
check to see if there are cracks or oil spots on the belt when you take it off first before you go out to buy a belt.
post #5 of 5 Old 12-14-2015, 05:44 AM
Advenio Pariter
Quoted: 354 Post(s)
+1
I change my serpentine belts every 60k miles on all my cars. It is like an oil change; cheap insurance. On this car it takes like 10 minutes or less. If your serpentine belt goes you lose everything...as in the water pump too.
2011 Base 2.0T, 5AT
Trunk Lip Spoiler
Fog Lights
Uniq Rigid Collars
Dynamat Hoodliner
Warranty: New Tails
Automatic Transmission Fluid Flush whiteninja89 Drivetrain 45 05-02-2016 05:38 PM
How many miles for power steering fluid flush and engine coolant flush? CHEJAMES1985 General Discussion 24 01-13-2015 03:26 PM
Fluid exchange/flush price reasonable? mrflow3r British Columbia 4 08-13-2014 10:13 AM
Need to do Transaxle flush with Transmission flush? taimysho0 Drivetrain 7 10-16-2012 05:00 PM
Sorta flush --> Hella Flush: The Ballad of KrAk3N vinknee Wheels, Tires and Brakes 2008-2012 7 05-16-2012 12:52 AM
