Cooling Improvements...Scorching Hot Summer Is Coming - Hyundai Genesis Forum
  • 1 Post By Red Raspberry
post #1 of 5 Old 03-19-2017, 06:12 PM Thread Starter
115 degree days are normal during the summer where I live.
Mod wise, I only have an intake(w/ heat shield), and an exhaust.
I'm looking to help my engine run a bit cooler so everything generally runs nicer, for longer.
So here's what I'm thinking of so far:
-Throttle body spacer
-Intake manifold spacer
-New grille(I'm sure this doesn't matter at all, but more airflow isn't a bad thing)
-Possibly the Mishimoto oil cooler
-Throttlebody coolant bypass
What else can I do? Thoughts?
unsavinghalo is offline
post #2 of 5 Old 03-20-2017, 07:34 AM
Quoted: 293 Post(s)
30/70 mix of coolant to water.
water is a better heat transfer medium than coolant.
coolant is there to be an antifreeze, raise the boiling point and to be a corrosion inhibitor.
be sure to bleed the system properly or else you are likely to have overheating issues.
post #3 of 5 Old 03-20-2017, 09:38 AM
Quoted: 24 Post(s)
engine cooling im guessing; TB coolant bypass is a free mod that will keep it a few degrees cooler; TB spacer not that much unless you are planning on water/meth; grimmspeed phenolic spacer works good, if you are doing this i would suggest going for the "extended" studs and get thermal gaskets.
There are some more things to do, your best friend around forums is the search tool as mostly everything has been bashed about.
2014 Black 3.8 R-Spec
Stock+ DD 6K low HID and switchbacks | DD XML2 3K fogs | DD tail as turn with rear fog lights mod (using XM80 red led bulbs) | R2C intake | TS Short shifter + bushing kit | TS lightweight pulley kit | 80mm TB with TS spacer | Grimmspeed phenolic spacer | Ark GRiP exhaust | BC Coils
ekuapa is offline
post #4 of 5 Old 03-20-2017, 12:09 PM
Put in a bigger radiator.
mrjohnnyeven likes this.
post #5 of 5 Old 03-23-2017, 07:52 PM
MZ777's Avatar
Quoted: 151 Post(s)
Basically what red said. I have CSF + my lo speed fan is on at all times, so my temps don't ever go above 180* no matter how I drive or what I do. Just avoid mishimoto garbage.
Sent from my ZTE A2017U using Tapatalk
MZ777 is offline
Hotter Mercedes AMG GT R is Coming This Summer AutoGuide.com AutoGuide.Com News 0 01-14-2016 06:10 AM
WiFi-Enabled Buicks Coming this Summer AutoGuide.com AutoGuide.Com News 0 03-24-2014 07:50 AM
Hottest Summer in the Philippines FT. A Red genesis coupe with Super hot Girls! anthony_evo08 Media 6 04-14-2013 10:50 AM
