Burning Oil/Blown Turbo...Suggestions or Ideas? - Hyundai Genesis Forum
  • 1 Post By JibbelSandwich
post #1 of 12 Old 05-18-2017, 11:09 AM Thread Starter
JibbelSandwich's Avatar
Quoted: 19 Post(s)
So for a little while I've been getting oil in the intake and intercooler piping but I've never burned oil out of the exhaust until a few days ago. I had a hit and run a couple of months ago so my car sat for a month getting the suspension fixed and then I drove it to another shop to have it sit for another month to get all of the body work done.
I get the car back and it drives perfectly fine but then I notice a whole bunch of white smoke behind me and smell oil. I took it to a shop today and they checked everything and did a compression test and everything internal was fine. So they said the turbo was blown and that they'd replace it for about $500 not including the turbo. I can find a used one for around $300-$400 and have them replace it or just replace it myself which I'm semi comfortable with since I've already had to take off the outlet housing and exhaust manifold to get broken studs out.
I'm just wondering if I should just get a new/bigger turbo or take my turbo and get it rebuilt at SocalPorting for around $300. I'm just conflicted on how to go about this and any input or suggestions would be much appreciated.
I'm also at 106,000 miles.
Thanks!
2010 Genesis 2.0T R-Spec
BR Canned Tune
K&N Intake
HKS BOV SSQV4 Cold Side
BR off-road down pipe
Isis Single Exit catback
Port and Polished Exhaust Manifold
Port and Polished Turbine outlet housing
Torque Solutions STS
Megan Transmission Mount
Corksport adjustable weighted shift knob
Megan coilovers
Enthuspec Subframe Washers
CC Stage 2 Clutch/Flywheel
JibbelSandwich is offline
post #2 of 12 Old 05-19-2017, 01:57 AM
Genna108's Avatar
Quoted: 13 Post(s)
I have a stock turbo laying around if you want get your car up and going
Genna108 is offline
post #3 of 12 Old 05-19-2017, 05:23 AM
The turbo comes off the manifold with a simple clamp.
post #4 of 12 Old 05-19-2017, 12:17 PM
Quoted: 287 Post(s)
To add what Red means,
there is a v-band holding the "core" of the turbo to the exhausting housing.
Undo the hoses, support bracket, then v-band, snake the turbo out and reverse process with other turbo.
Doing it this way, you don't have to worry about shearing exhaust studs, or if you were lucky to get them off without shearing, the studs possibly loosen later on.
post #5 of 12 Old 05-19-2017, 12:29 PM Thread Starter
Quoted: 19 Post(s)
How many miles are on it?
BR Canned Tune
K&N Intake
Megan coilovers
post #6 of 12 Old 05-19-2017, 12:33 PM Thread Starter
Quoted: 19 Post(s)
Are you talking about the studs that bolt to the downpipe?
BR Canned Tune
K&N Intake
Megan coilovers
post #7 of 12 Old 05-19-2017, 12:54 PM
Quoted: 287 Post(s)
manifold to turbo exhaust housing studs. Mine kept coming loose every week, until I got fed up and just safety wired it.
post #8 of 12 Old 05-19-2017, 12:57 PM Thread Starter
Quoted: 19 Post(s)
Oh really ever since I got my manifold ported my studs come loose all the time too. So in my case they're already out right now.
BR Canned Tune
K&N Intake
Megan coilovers
post #9 of 12 Old 05-19-2017, 07:35 PM Thread Starter
Quoted: 19 Post(s)
I got the turbo out today. I'm gonna take to SoCal Porting to get it rebuilt and maybe port n polished since it'll already be there.
BR Canned Tune
K&N Intake
Megan coilovers
post #10 of 12 Old 05-19-2017, 09:31 PM
Genna108's Avatar
Quoted: 13 Post(s)
I got 2 one with 40k miles one it 80k miles i still have the one with less miles on the car
Genna108 is offline
post #11 of 12 Old 05-20-2017, 03:43 PM
Quoted: 287 Post(s)
rebuilding a turbo is easier, just requires a lot of $$$$ for equipment to do it properly.
the equipment to do it properly is a high speed balancer.
I've rebuilt my blouch turbo ( hybrid clipped td04l-19t) once and have almost 60k miles on it, and didn't balance it. So I just got lucky. On the mitsubishi turbos (td0x turbos) the nut is reverse thread (righty loosey, lefty tighty)
Balance points where material is removed to balance are on the turbine nut and the compressor nut. I marked the placement of the compressor nut in relation to the shaft (there's a joke in here somewhere ) before rebuild, and torqued to that location rather than to spec.
Thats if you want to fix it cheap. Worse case, it will start to wear the bears out under a thousand miles in and will have to have it properly rebuilt.
post #12 of 12 Old 05-22-2017, 04:08 PM Thread Starter
Quoted: 19 Post(s)
Okay I took the turbo to SoCal Porting and he said my turbo doesn't need to be rebuilt. He showed me the oil seal compared to a new one and they have the same pressure but he went ahead and put the new one on just cause. He also said the bearing inside is spinning directly on the shaft instead of on oil which can cause play in the future.
So, he recommended using 5w-40 oil instead of 5w-30, getting a catch can, and to check my pcv valve.
Red Raspberry likes this.
BR Canned Tune
K&N Intake
Megan coilovers
Burning oil anyone? tripleblacksi Engine 41 05-23-2016 06:18 PM
Burning Oil shawncalt Engine 4 05-23-2016 08:37 AM
2010 3.8 Won't Start - Suggestions/Ideas? acgidley General Discussion 24 10-21-2014 03:58 AM
burning oil threw the turbo curtisb 2.0T Discussion 2008-2012 26 09-11-2012 06:12 PM
Grill Suggestions/Ideas Vigz Exterior 2008-2012 15 02-22-2011 06:47 PM
