#162 | ||
#164 | ||
How is the egt measured? Is there a thermocouple somewhere? Or is it a calculation between the 2 o2 sensors?
#165 | |||
you can see it if you hook up a OBDII scanner that shows realtime data. What i'm assuming is the secondary is an EGT not a wideband and the primary is the wideband. |
#166 | ||
Both 02 sensors are narrowband sensors.Those values are commanded values .Both the sensors read egt. In the city close loop driving I see less then 20 degrees diff from the two.
#167 | ||
Where is this described? I went through the entire service manual, and could find nothing on EGT. From my past experience, those stock o2 narrowband sensors have no way to measure EGT. Of those 4 wires, 2 are for the heater circuit, 1 is o2 signal (0-1v), and one is ground. That is, IIRC...
#169 | |||
When my upgrade TD04HL-19T arrives, Ill STILL run the primary cat. Its a street car. It needs to pass a sniffer test every 2 years. $30K street driven sports cars shouldnt have CEL's, or other crap, IMO. They shouldn't fail sniffer tests. They shouldn't have ANY hiccups. Otherwise, the upgrade strategy has failed the car and the driver. IMO. My tuning philosophy IS to improve the factory's product. How has it improved, if you have to live with a bunch of quirks that werent there prior? All this is in my OPINION. Some are willing to put up with lots of 'quirks' for an extra 20 hp. In my experience (10+ years of turbocharged goodness), those extra 20 hp are just not worth it. |
#170 | ||
Im not running the stock primary cat, but what cdnsigop has described is representing my philosophy with this car and also the reason why i went with a high-flow cat. I've passed an emission test with it and has no CEL whatsoever. Happy customer
#173 | ||||
Out Pissing Off cops!
#174 | |||
On another note: I have spoken to Mark over at TurboXS. They are willing to supply a tune for the TD04HL-19T, once they get a Gen Coupe over there with this turbo upgrade. So this turbo upgrade will soon have a TurboXS tune available, for those that want to rock that. I have also removed my Magnaflow cat back exhaust, and returned to stock (with stock downpipe, and gutted secondary cat). Power is not noticebly different. Car is quiet though!! Lovin it. Last edited by cdnsigop; 08-24-2011 at 05:40 AM. |
#175 | ||
Well if there's 2 wires used to supply the heatercore of the sensor, then if you supply a constant voltage/amperage, you can monitor for changes in the actual current and extrapolate temperatures from that, since temperature changes in metal usually changes the conductivity ratio of the metal, which can be seen by the changes in required current readings.
This is my opinion on how the ECU can see EGT through the O2 sensors. |
#176 | |||
Stage 3 |
#177 | |||
Gray hair senior member
My thoughts exactly.
DIY built motor with haltech new 19t v2 fs "Information is not knowledge. The only source of knowledge is experience." Albert Einstein |
#178 | ||
Larger wheel = cooler/denser air= leaner afr. My logic, (and motor) are fine. lol
#179 | ||
x1 to Mcmonopoly
This is nothing new, Heated O2 sensors need to know when to turn on and off and it is done with voltage parameters.There is a MAP in the ECU that expands on those parameters to determine EGT. |
#180 | |||
I remember the WRX's had a factory EGT sensor, IIRC, it was for cat protection as well. Smoke!! Clear your inbox man! |
| Genesis Coupe 2.0T EVO 8/9 Turbo Kit | Jamie@Elite | Engine | 46 | 05-16-2012 08:32 AM |
| Genesis Coupe was a TAD bit out of place (Pics) lol | Billysoco7 | Media | 33 | 04-14-2010 02:31 PM |
| Pics of my new Genesis Coupe | strictlygunners | Media | 17 | 12-17-2009 05:03 AM |
| Getting on Track: Ferrari releases more pics, details on experimental 599XX | RSS-Autoblog | Autoblog | 0 | 04-27-2009 09:10 AM |
| Some pics I took of the Genesis Coupe today... | Mike@ImportShark | Media | 18 | 03-28-2008 06:33 PM |
