#62 | ||
Gray hair senior member
The 6258 has a T25 flange and will require an adapter to work on T3.
For your viewing enjoyment! This is a VERY nice piece! http://i1105.photobucket.com/albums/...s/IMAG0687.jpg http://i1105.photobucket.com/albums/...s/IMAG0686.jpg
DIY built motor with haltech new 19t v2 fs "Information is not knowledge. The only source of knowledge is experience." Albert Einstein Last edited by Rspecwhite; 12-23-2011 at 06:49 AM. Reason: add photos |
#67 | |||
My other ride has 4000hp
The thing with a tubular SS mani is that this (ceramic coating) can trap heat in too well and cause weak joints and cracking and it is too diffcult and costly to clean it up before trying to reweld it, and then recoat it or then you have uneven coats and temps and rinse and repeat... As if you ever get anything ceramic coated, you are much better off doing it new from the factory But with a cast, I would highly recommend it, as cast is so much stronger and heat and cracking isn't really an issue and it will hold in heat very well which as we know keeps up gas velocity which is better spool and slightly more tq realized (or less tq lost), AND less engine heat soak as an uncoated EM contributes to quite a bit of engine bay heat which generally results in higher IATs. Last edited by whatnot; 01-15-2012 at 03:03 PM. |
#68 | ||||
Jedi Master
but thats only like a $40 adaptor isn't it? and it bolt right on... how the cost it seems worth it. would the 6258 require other mods, for instance change to the o2 housing or anything? and would the stock pipe line up with the few inch's from the adapter?
I am not a list of mods but what i know and share: http://www.gencoupe.com/2-0t/94778-fuel-system-what-you-need-know.html http://www.gencoupe.com/2-0t/86146-wastegate-101-a.html http://www.gencoupe.com/2-0t/91199-compressor-maps-how-read-them.html Fav. JT Quote Quote:
#69 | |||
The EFR 6258 turbo is quite expensive, at about $1900 list ($1500 street price..). Add the BR manifold, downpipe fabrication, and any intake fabrication that may be required.. Last edited by cdnsigop; 01-16-2012 at 08:48 AM. |
#70 | ||
The EFR 6258 turbo is quite expensive, at about $1900 list ($1500 street price..). Add the BR manifold, downpipe fabrication, and any intake fabrication that may be required..[/QUOTE]
It's not that expensive when you save more $500 on BOV and Wastegate and you have a piece of art spooling faaaasssttt...
Silverstone 2.0T |
#71 | |||
Jedi Master
ya... but how much would the o2 housing cost? i mean as for t3 the 7064 for bigger 275-450 and the efr 6255 comes as a 0.83 A/R T3 Housing(Internal WG) and sill still good up to 200-350hp. Wouldn't that line up 100% with the manifold and piping? i mean you might need a little work i don't think anything epic. also has internal wastegate, and there IWG's are bad ass. And that would still give you crazy spooling without needing to be twin scroll.
#72 | ||
Captain Awesomesauce
This has probably been asked already but is there any chance of a divided cast manifold? SPA has done them for at least VW's that I know of.
2010 Silverstone Premium 2.0T 5-Speed AT Done: AEM CAI Synapse Synchronic DV Weirtech FMIC kit + 600hp Garrett Core WeirTech EVOLVE Al. TBE PA 91 Stage-1 Dynojet CMD+WB2 StopTech SS Lines w/ RBF600 WeirTech Protoype Coolant Overflow Tank JUN BL Catch Can OEM GT Strut Bar Eibach Sway Bar Kit Solar Gard 20% Everything Planning: BBB PowerX Tune Bosch 750cc Injectors BR Cast EM GTX3076r Forged Internals... |
#73 | ||
Moarrrrrrrrr please. want teaser install pics.....maybe adapter fitting info and whatnot if you got any
BUILT ENGINE MODS: Every bolt on available from the ground up. Stage 5 coming soon.... Already in: Haltech, DW300 fuel pump, Aeromotive FPR/ Return fuel system, Stage 4 clutch, BR Exhaust Manifold, Holset HX35, Precision 39mm WG, Grimmspeed EBCM, Tomei Poncam/valve springs, Cosworth 1.1mm HG, Elite Intake Manifold, Mishimoto rad hoses, CF snorkel. On the way: Megan racing trans mount, CPE Mounts |
#74 | |||
Garrett GTX3071R Dual Ball Bearing Turbo : atpturbo.com
2010 Genesis Coupe 2.0T GT 6-speed in Nordschleife Gray Last edited by RudyH; 02-09-2012 at 05:13 AM. |
#75 | |||
Jedi Master
Garrett GT turbos are great but there is no (no joke or bashing) better turbo manufacturer then borg warner. but as mentioned $$$$$$. the only thing is borg warner works in T25 falnges (single non-divided) garrett sells on the other hand T3 (easier and more common for our car.)
#77 | |||
Jedi Master
ok your right my bad especially when you look at it as a complete total picture and how borg warner only spend ton's of money to make things like VTG turbos for gas car ad selling for +$5k then selling it to porsche for more $. but Garrett probably makes the best OVER ALL turbo (including price). But borg warner does make very.... unique turbos
#78 | |||
Look at the orientation of the efr Turbo's, ie. location of wastegate actuator, even the small series efr,s you would probably have to have a custom manifold made because of clearance issues with the block (never measured just a guess).It is ideal for top mount though. |
#80 | ||
I reject to reality
Stage 4 has been fully released. Details HERE
BUY MY AUDIO EQUIPMENT HERE http://www.gencoupe.com/private-classifieds-interior/129126-fs-alpine-pdx4-100-zapco-dc650-drc-remote-control.html |
| Beyond Redline Presents: Project Falcon | Tim@BeyondRedline | 2.0T Discussion 2008-2012 | 413 | 09-29-2012 11:10 AM |
| ***Beyond Redline Presents: Exceladyne GT Series Turbo Kit *** | Tim@BeyondRedline | 2.0T Discussion 2008-2012 | 33 | 03-02-2012 05:22 PM |
| ***Beyond Redline Presents: Cast T-3 Turbo Manifold Pre-Sale!!*** | Tim@BeyondRedline | Engine | 34 | 11-20-2011 02:57 AM |
| Beyond Redline Presents: Radiator Block Off Plates | Tim@BeyondRedline | 2.0T Discussion 2008-2012 | 32 | 06-21-2011 02:58 PM |
| Beyond Redline Presents: Project Phoenix Build Up! | Tim@BeyondRedline | 2.0T Discussion 2008-2012 | 471 | 03-06-2011 06:48 PM |
