Why you NEED a catch-can - Page 4 - Hyundai Genesis Forum
 10Likes
post #61 of 626 Old 10-07-2011, 07:07 AM
Burger King Dildo Hammer
grilledcheez's Avatar
Quoted: 36 Post(s)
Maybe this is a retarded question, but I am teh n00berz. Why do some people run two catch cans? Is the first one not large enough to catch the stuff? Or do they have one for each intake hose? Does it depend on the catch can?
2010 Bathurst Black 2.0T Premium M/T
Project - Ass To Mouth Annihilator (ATMA)
grilledcheez is offline
post #62 of 626 Old 10-09-2011, 11:57 AM
Jrs3000's Avatar
My can will be here next week. Anyone had the dealer say anything about the setup?
Jrs3000 is offline
post #63 of 626 Old 10-09-2011, 12:57 PM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
You answered your own question really. Some feel it's better to run two but on the 2.0T it's not really needed because the crank case vent doesn't really blow a lot of stuff out of it..
Snoopy0812 is offline
post #64 of 626 Old 10-09-2011, 01:03 PM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
As long as it's hooked up correctly it can't cause any issues, you might not pass an emmisions inspection though depending on local requiremtents.
Oh, I should have stated that your contents of your catch can need to be disposed of correctly to a proper oil recycling facility, it's not environmentally safe in any way.
post #65 of 626 Old 10-16-2011, 03:04 PM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
post #66 of 626 Old 10-16-2011, 03:09 PM
See You Spring 2013
Mira2White's Avatar
You DA MAN
Sold:2010 MB BR Stage 3 Auto Test Pilot
Sold:2012 KW BR Stage 3 MT
Current: 2012 Apex Silver Evo X GSR
Auto Guys Message Me With Any Question Or Concerns!
Mira2White is offline
post #67 of 626 Old 12-01-2011, 01:13 PM
FlightMedic21's Avatar
Is there a particular brand for catch can's you recommend, or are they all basically the same thing? I just had an Injen CAI installed on my 2.0T, and saw there was a little bit of oil, so I should be getting one soon.
FlightMedic21 is offline
post #68 of 626 Old 12-01-2011, 09:08 PM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
post #69 of 626 Old 12-02-2011, 05:30 AM
AGP's 2 can setup is fantastic, as many here can attest to. Look like they belong under the hood too:
cdnsigop is offline
post #70 of 626 Old 12-02-2011, 06:10 AM
1sty's Avatar
I am assuming you have to cap off the port to the intake manifold as that can have boost on it so just putting a catch can between those points would end poorly?
1sty is offline
post #71 of 626 Old 12-02-2011, 08:00 AM
Nothing capped off at all on the driver side. PCV valve -> AGP Catch can -> Intake manifold.
cdnsigop is offline
post #72 of 626 Old 12-02-2011, 08:58 AM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
I personally don't ever recommend putting boost to a catch can, but a few have argued that there is no real concern but they've never had their can explode and coat everything in engine gunk.
If you'd like to still use the engine manifold port then buy a one way check valve and put it between the intake manifold and the can to allow vacuum but no boost.
post #73 of 626 Old 12-02-2011, 10:04 AM
1sty's Avatar
I am sure the AGP cans can probably handle the boost where the Ebay stuff can not.
1sty is offline
post #74 of 626 Old 12-02-2011, 10:40 AM
LOL The AGP driver side can is bombproof. It is hooked up the way AGP suggests. No check valve required with that one..
I paid around $250 shipped IIRC for both cans. A very worthwhile purchase, especially as they look like they belong there..
cdnsigop is offline
post #75 of 626 Old 12-02-2011, 10:55 AM
The Ebay can is robust enough. There is failure in about anything if enough are made or there are other mitigation circumstances. 20 even 30 lbs should not be considered a problem for pressure. You could get plastic cans to hold that easy enough if you wanted to.
post #76 of 626 Old 12-02-2011, 11:14 AM
rmjgenesis's Avatar
Snoop were you able to get your install video up?
- 2011 Genesis 2.0T Coupe - Daily Fun
- 1987 Supra: 490 whp, 1.5JZ on Meth
- 2013 Veloster: Wife's fun car
rmjgenesis is offline
post #77 of 626 Old 12-04-2011, 01:43 PM
1sty's Avatar
regardless if it hold boost or not. Seems easier/cheaper to just use a T and block off the one tube so you can run a single can.
1sty is offline
post #78 of 626 Old 12-04-2011, 01:48 PM
flylow's Avatar
this was mine when i took it out. about 2 weeks of driving here
Originally Posted by usedwolf View Post
If you replace the pipes, could you just get a Y spliter and also have a CAI installed below the airbox? Can the turbo/ engine handle that much air flow?
flylow is offline
post #79 of 626 Old 12-04-2011, 05:58 PM
No, they are entirely two different situations.
post #80 of 626 Old 12-04-2011, 06:22 PM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
If you hook it up the way I did in my video you won't hurt your engine or require two cans.
To have a fail safe get an inline fuel filter and put it between the intake and the catch can.
I'm working on a "Plan B" catch can install for single cans that go to the intake manifold rather than the intake but its taking longer than expected since I don't have my car atm.
Oil Catch Can Nick Engine 29 08-01-2015 06:16 AM
FS: Jun Oil Catch Can coexrjguy Engine 13 08-05-2010 03:01 PM
WTB: Jun B.L Oil catch can netstat Want to Buy 2 06-13-2010 10:29 AM
Oil catch can? Rustyy 2.0T Discussion 2008-2012 28 04-22-2010 01:25 PM
What's the catch? teknical1ty General Discussion 8 02-06-2010 07:56 PM
