Why you NEED a catch-can - Page 6 - Hyundai Genesis Forum
 10Likes
post #101 of 626 Old 12-20-2011, 05:42 PM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
Originally Posted by sd_davis View Post
Snoop, your a dedicated soldier!
New questions: (feel free to be brief...)
-- The best setup for the 2.0T is last diagram; "Dual Catch Can"?
-- I read this DIY and saw your video. You mentioend the PCV valve. Can we remove that, or what was that all about?
--Is the check-valve in the last diagram already "in place" or is that something I need to install?
Thanks for all you do brother!
--Best setup is the one that works best for you.
--The PCV valve prevents boost from entering your upper deck. Don't remove it.
--You'd have to add the check valve.
That check valve could be the PCV valve if it was moved to the side of the can that goes to the IM.
Another option. Adding that check valve to prevent boost from entering the can would essentially act as a PCV valve, leaving the stock one in would act as a fail safe.
Originally Posted by tigershark09 View Post
I know that the stock hose between the crankcase vent and the intake has a check valve. Would we not need one in the dual can setup too?
There is no check valve or PCV valve between the crank case vent and the intake (passenger side). The PCV valve is on the line from the upper deck and the intake manifold.
^^^ That's the PCV valve.
I'm pretty sure he's talking about the vent on the passenger side. The only check valve (aside from the boost control body) on the passenger side is part of the brake booster system on M/T GC's.
Originally Posted by 1sty View Post
why cant you just use one?
You can, but I'm trying to be thorough in my information. I only use one can.
Snoopy0812 is offline
post #102 of 626 Old 12-20-2011, 05:58 PM
Snoopy you really seem to know your stuff. I have a single Mishimoto can and I'm wondering if you'd be interested in doing the install on it.
marshak is offline
post #103 of 626 Old 12-20-2011, 06:22 PM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
if you come for the meet in the spring np. If I end up getting sent to toon town earlier then we could easily meet up and get it done.
post #104 of 626 Old 12-21-2011, 08:03 AM
Not in the face!
jaov2k's Avatar
I believe it would be a decision based on volume; if you get a lot of blowby and still getting oil inside the IM after installing a catch can, cost, and space.
2011 | 3.8L | Track | A/T | Karussell White
| PowerAXEL Reflash | R2C SRI | DD Stage 3 LED Kit - White |
Info@JAOV2K.com
JAOV2K, Inc. Consulting Services
(708) JAO-V2K0 (526-8250)
jaov2k is offline
post #105 of 626 Old 12-21-2011, 10:17 AM
Was ordering up a new gauge from prosport and noticed they have their real carbon fiber catch can on sale for 75.00
Sent from my Acer Liquid using AutoGuide App
genjuice is offline
post #106 of 626 Old 12-23-2011, 08:23 AM
RudyH's Avatar
Emptied my JUN for the first time yesterday...probably around 1,000+ km.
Filled entire concentrate juice can full of the gunky mess. Running off both boost and non-boost side, but it looks like non-boost PCV side is the most used and most dirty. IMO if you are going run a catch can, and can only afford to do one, do PCV side!
Sure glad its not going back into my engine that's for sure
RudyH is offline
post #107 of 626 Old 12-23-2011, 08:36 AM
lackadaisical
JimmyA7X's Avatar
Quoted: 147 Post(s)
how hard was it to empty JUN CC?
2011 Hyundai Genesis Coupe 2.0T w/ Premium
Tsukuba Red | 6 speed
Originally Posted by GenCoupeGeek View Post
I blew past a Lamborghini Gallardo in a parking lot... and I never even left 3rd gear. It was so exhilarating I stopped, backed up, just so I could pass it again!
JimmyA7X is offline
post #108 of 626 Old 12-23-2011, 08:52 AM
RudyH's Avatar
Pretty much have to unmount it, take it apart and flip the one end, not sure if there is an easy way - took 5 mins, more so took longer to let it drip out then anything.
RudyH is offline
post #109 of 626 Old 12-23-2011, 09:35 AM
If you can only afford one catch can (like me), you could just do both sides with a T coming into your can like snoopy's DIY video... no reason not to.
Sent from my DROIDX
Subversion is offline
post #110 of 626 Old 12-24-2011, 09:16 AM
Orange Fogs
cmdrbato's Avatar
Just drained mine after ~4000km
its a good idea i installed a drain plug on both cc's. no hazzle to drain...i dont have to remove the cc, just loosen up the drain plug...
Jong
BTR Tune | K&N | CNTV3 | Synapse BOV (HotSide) | Mishimoto | GS | HSD | Enkei GTC01 | Project Kics | Brembo | Enthuspec | R1 |Hankook | Seibon Trunk & Hood | VIS | RMX | 2013 Tails | Acer Nav |
http://genesiscoupe-cmdrbato.blogspot.ca
www.mytestautomation.com
...your manufacturing and test automation solution
cmdrbato is offline
post #111 of 626 Old 12-24-2011, 04:33 PM
Severed member
sd_davis's Avatar
Awesome man! Nice work.
I just installed a Mashimoto catch can today. Figuring out the mounting placement was the hardest part. The Mashimoto intake nubs are 1/2. I ended up going to the auto parts store, and getting a same thread nub for 5/16" to fit the one side, and some 1/2" fuel line for the other. I'll do a small write up and install review later this weekend.
I DO want to do like you have with the drain line. The Mashimoto has a drain plug on the bottom already, so it;s just a matter of finding the right nub.
- PRW FMIC & Piping kit
- CP-E differential mounts
- K&N Typhoon SRI; Forge BOV
sd_davis is offline
post #112 of 626 Old 12-24-2011, 06:53 PM
seems pretty straightforward and the carbon fiber catch can for 75 bucks is a huge deal
NoXiDe is offline
post #113 of 626 Old 12-24-2011, 10:25 PM
Never heard of Mashimoto.... they any good?
<_<
>_>
Sent from my DROIDX
post #114 of 626 Old 12-25-2011, 04:57 AM
Severed member
sd_davis's Avatar
Never heard of Mashimoto.... they any god?
Doh! I meant: Mishimoto.
Honestly it's too soon for me to speak to performance, as I just put it on yesterday. However, I can speak to its apparent quality. The CC seems very well built, is light, and looks really nice.
I got it because it was mentioned by Snoopy and I could have it delivered for $80 from amazon.
sd_davis is offline
post #115 of 626 Old 12-30-2011, 04:12 PM
Synthmanic's Avatar
Just got the mishimoto cc as well. Any ideas on the best mounting location. Looking to put this one on the PCV side. I was playing around with a few spots today, but I can't seem to find a spot to keep it upright.
Synthmanic is offline
post #116 of 626 Old 12-30-2011, 04:43 PM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
If anyone's interested I have an un-used Mishimoto CC for sale.
post #117 of 626 Old 01-02-2012, 12:11 PM
Vroom Vroom Party Starter
Kolk1's Avatar
I have a $20 one off ebay, and this isnt even 2000 miles. Makes me sad that 18,000 miles went through the motor before I put this on.
Why do some look like pure used oil, and mine almost looks like a beer? lol Mine is installed like the video he posted in the first post.
Daily: 2011 SHO Taurus, AWD Twin Turbo, livernois Stage 4 kit.
For Sale: 2010 R-Spec 2.0T, 6sp, tinted windows, viper keyless R/S, basic little stuff.
Cruiser/Bruiser Bike: 2007 ZX-14, 300whp, Built block, Garrett GT2871R turbo, you name it.
Touring/backroading Bike: 2013 ZX-14R, Full titanium Hindle exhaust, dyno tuned, drop pegs, bar risers, Puig DB screen,
Kolk1 is offline
post #118 of 626 Old 01-02-2012, 12:18 PM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
post #119 of 626 Old 01-02-2012, 12:20 PM
Kolk1's Avatar
Originally Posted by Snoopy0812 View Post
yeah that's some condensation righ there uh huh.
If it matters, our weather is all over the place. Normally we have had a good amount of snow by now, but its only snowed once and then it hit 45 that day. Today is a high of 28, but in a couple days its supposed to be mid 60s, and Im going on a bike trip. lol
Kolk1 is offline
post #120 of 626 Old 02-08-2012, 12:44 AM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
!IMPORTANT NOTICE!
!DO NOT HOOK YOUR CCV AND PCV TO THE SAME CAN!
I'm working on a solution to a potentially very hazardous situation for cold climate GC owners, better safe than sorry atm.
Oil Catch Can Nick Engine 29 08-01-2015 06:16 AM
FS: Jun Oil Catch Can coexrjguy Engine 13 08-05-2010 03:01 PM
WTB: Jun B.L Oil catch can netstat Want to Buy 2 06-13-2010 10:29 AM
Oil catch can? Rustyy 2.0T Discussion 2008-2012 28 04-22-2010 01:25 PM
What's the catch? teknical1ty General Discussion 8 02-06-2010 07:56 PM
