Why you NEED a catch-can - Page 9 - Hyundai Genesis Forum
 10Likes
post #161 of 626 Old 02-10-2012, 08:11 AM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 90 Post(s)
@Sheijo
Mishimoto's cans are not baffled.
I don't know if you could pop the breather off the AGP and connect a host, most likely could with some hose reducers though.
PM some pics if you'd like help with placement.. that and I'd like to see your engine
Snoopy0812 is offline
post #162 of 626 Old 02-10-2012, 08:31 AM
too easy, ill snap some when i get off work and send them your way. did you see my youtube videos floating around?
Power Lab manifold + GT3071R + Haltech = 424 whp and maxed injectors (never tuned the water/meth)
Having somebody build your car for you is like getting a prostitute over a wife. Sure you pay a bit, but you get all the fun with out any of the headache.
sheijo is offline
post #163 of 626 Old 02-10-2012, 01:47 PM Thread Starter
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 90 Post(s)
No I didn't, what's your YT tag? I'll add you to my friends and subs and look at your vids. Your engine is
post #164 of 626 Old 02-10-2012, 01:59 PM
just search my user name
sheijo is offline
post #165 of 626 Old 02-10-2012, 02:01 PM
RudyH's Avatar
Originally Posted by sheijo View Post
did the kids come over because you have a van parked in the front that says "free candy" on the side?
Ice cream truck
RudyH is offline
post #166 of 626 Old 02-10-2012, 02:04 PM
what nobody sees is the AMAZING hand made basket that SPS Autosport made for my two fuel pumps. it is pure sex. i might try to pull it out the next warm day i have and take some pics of it.
sheijo is offline
post #167 of 626 Old 02-11-2012, 06:20 AM
RudyH's Avatar
I just blew my second turbo in a month!!!!
The only modification to the car is the catch can!!!
RudyH is offline
post #168 of 626 Old 02-11-2012, 06:32 AM
This would cannot happen if they were plumbed directly inline individually and kept empty enough so freezing will not block them off.
post #169 of 626 Old 02-11-2012, 06:34 AM
cowcow's Avatar
Quoted: 40 Post(s)
That's what I was thinking which is why I left it off the car. Try routing all the lines back to stock, put a bit of oil back in and staring it. The seal might not actually be gone, just excess crankcase pressure pushing oil out the seal.
cowcow is offline
post #170 of 626 Old 02-11-2012, 06:36 AM
Orange Fogs
cmdrbato's Avatar
How's your catch can connected?
Are you using single/common catch can on CCV side and PCV side?
Jong
BTR Tune | K&N | CNTV3 | Synapse BOV (HotSide) | Mishimoto | GS | HSD | Enkei GTC01 | Project Kics | Brembo | Enthuspec | R1 |Hankook | Seibon Trunk & Hood | VIS | RMX | 2013 Tails | Acer Nav |
http://genesiscoupe-cmdrbato.blogspot.ca
www.mytestautomation.com
...your manufacturing and test automation solution
cmdrbato is offline
post #171 of 626 Old 02-11-2012, 06:51 AM
RudyH's Avatar
It's the JUN.
I emptied it literally on Wednesday.
I have 3 lines
1) from PCV
2) from intake + check valve
3) from valve case
4) nub from valve case to intake is blocked off
The first time this happened it happened when it was around 2 degrees Celsius and dropped to -16, this time it was hovering all week around 2-6 degrees, woke up this morning and it was -13 and it popped.
RudyH is offline
post #172 of 626 Old 02-11-2012, 06:53 AM
You need to keep the two lines separate. Use two cans, get rid of the check valves and make sure it does not fill and freeze. The intake one is the worst as it will have a mixture of water and oil. The turbo side is almost all oil.
post #173 of 626 Old 02-11-2012, 07:00 AM
Dollars to donuts its the JUN can, with its single chamber for both sides. Unless you have other crankcase pressure issues, such as broken ringlands..
You cannot convert AGP's passenger side can for connection to the intake pipe either. Not if you want it to work correctly. The passenger side flows 2 ways, mostly as a fresh air intake. Under boost, the opposite, a crankcase discharge. You would require a can that keeps airflow clean both ways. The AGP can does not achieve this.
cdnsigop is offline
post #174 of 626 Old 02-11-2012, 08:36 AM
RudyH's Avatar
Yup dead on. Catch can is in the garbage and car is running great! Minus the gunk that flows through it.
That said, have that back of my mind feeling the first turbo was fine...
RudyH is offline
post #175 of 626 Old 02-11-2012, 09:07 AM
Orange Fogs
cmdrbato's Avatar
i think issues will ONLY occur if both sides uses same and common catch can, but dont quote me on this, this just based on what i have read.
does anyone here have same issue using separate catch cans?
Jong
cmdrbato is offline
post #176 of 626 Old 02-11-2012, 09:12 AM
It's when you put a check valve into the system when you have problems. The pressure has to go somewhere. Short of the freezing issue.
Check valves are also prone to sticking from gunk of freezing material.
post #177 of 626 Old 02-11-2012, 09:14 AM
FUNDAI's Avatar
This is why i turned my jun can into a single side....glad I did
Originally Posted by qwaszx
Dude... I just drove by Dunkin Donuts because I was too busy thinking about what kind of donut I wanted!
FUNDAI is offline
post #178 of 626 Old 02-11-2012, 10:46 AM
cowcow's Avatar
Quoted: 40 Post(s)
Yeah. I'm thinking my first turbo never went either. Too late for that though
cowcow is offline
post #179 of 626 Old 02-11-2012, 11:09 AM
1-2-3-4-GRRRIIIINNND-5-6
daniel1pist's Avatar
I'm running two separate catch cans. On the passenger side the can simple has a breather and no lines running back into the intake (my sri has only one outlet available :[ ) no problems. So far so good, but I think I need to get a different reducer, my line blows off the vc under repeated runs in high boost. The reducer I used has no lip for the clamp to grab the line onto -__-
Originally Posted by THETA 2.0T View Post
All of you deserve to have your cars turned into cubes.
Originally Posted by SplitSurf View Post
How long before the pencils start exploding and the anal beads broadcast reruns of The View to your girlfriend's colon when you turn them on?
daniel1pist is offline
post #180 of 626 Old 02-11-2012, 11:44 AM
FUNDAI's Avatar
So is this the best way to run the passenger side? I currently just have a filter on the valve cover. Because when I realized the issue with the JUN can I quickly switched its setup.
What's the difference between something like the AGP breather, and just a filter, in the way it operates? Or does it just simply provide a place to store oils.
What's the optimum setup? A CC with a breather that has both a line to the VC and to the intake?
FUNDAI is offline
Oil Catch Can Nick Engine 29 08-01-2015 05:16 AM
FS: Jun Oil Catch Can coexrjguy Engine 13 08-05-2010 02:01 PM
WTB: Jun B.L Oil catch can netstat Want to Buy 2 06-13-2010 09:29 AM
Oil catch can? Rustyy 2.0T Discussion 2008-2012 28 04-22-2010 12:25 PM
What's the catch? teknical1ty General Discussion 8 02-06-2010 06:56 PM
