#141 | |||
Gray hair senior member
DIY built motor with haltech new 19t v2 fs "Information is not knowledge. The only source of knowledge is experience." Albert Einstein |
#142 | ||
I am running the NGK's right now and ive not had any problems..but im going to regap them
BUILT ENGINE MODS: Every bolt on available from the ground up. Stage 5 coming soon.... Already in: Haltech, DW300 fuel pump, Aeromotive FPR/ Return fuel system, Stage 4 clutch, BR Exhaust Manifold, Holset HX35, Precision 39mm WG, Grimmspeed EBCM, Tomei Poncam/valve springs, Cosworth 1.1mm HG, Elite Intake Manifold, Mishimoto rad hoses, CF snorkel. On the way: Megan racing trans mount, CPE Mounts |
#144 | ||
2.0 MT - Shanghai
BBB (William) at PRW has one, get in touch with him.
TD05H-20G, K1 rods, Wiseco pistons, Siemens 750cc, BR Swain Tech coat. EM, Tial EWG, Forge BPV, Haltech, WB2, Grimspeed P&P IM, FMIC, custom K&N intake, AEM MAP sensor, BR EBCS, TurboXS Stealthback + Wilson Perf. cat-back, Eibach Pro-Plus kit, LSD, CC flywheel + stage 3.5 clutch, Brembo + SS lines + Ate Super Blue + Hawk HPS Front / EBC yellow rear, Yokohama AD08, 19" Soon: 24psi tune, Synapse DV Youtube Channel (Nice Gen vids, mostly Go-Pro): http://www.youtube.com/user/ecyout |
#145 | ||||
2.0 MT - Shanghai
Here is useful info posted by Rspecwhite in another thread:
#146 | ||
The V2 should FORCE a very slight spool decrease, while adding a bit more flow capability. The extra flow capability should allow the engine to take in a bit more CFM at a given boost level, while the slower spool should make it easier to avoid that surge region. I get some surge as well with my 18G, its something that needs to be tuned around. Run less boost thru the surge prone ranges, and you will be good to go.
#147 | |||
Sent from my PG86100 using AutoGuide.com App
Legal Disclaimer: Anything that I or anyone else says about my vehicle on this website (www.gencoupe.com or any affiliated or non affiliated sites), pertaining to modifications and/or events, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car or real world experiances, and thus, cannot be held against me in any issue, i.e. warranty claims, that may arise. (Thanks to author) |
#148 | |||
2.0 MT - Shanghai
What is your surge experience with the 19T? Same as Rspecwhite? Over 20 psi at under 3300? Please share. I did not experience any surge with the 20psi boost map posted earlier. I am not sure about Rspecwhite setup but I have no cats and extrude hone, that might be one reason if he does not have the same setup (no idea). Also I am on stock air box, that could play in creating a restriction, not sure...
#149 | ||||
I can always build V1's, if given enough notice before hand. All of my stock is now V2's, except for one that isnt built yet. As of today, I have the V2 on my car, and let me tell you its FANTASTIC. I notice no spool loss, and if there is any, it is absolutely minimal. The top end feels as potent as the 18G at same boost, and in this below freezing weather, 15 psi is bloody fast, and enough to put the clutch on the threshold of slip... I recommend the V2 for all who would have had the V1 in the first place, to be totally honest! It is truly worth it. I believe it is the perfect balance of response/power capability/value, for a street driven Genesis on stock internals. I did experience surge above 20 psi at lower rpm with the TD04HL-19T V1. I ended up turning boost down to save the clutch before I could test many combinations. My 18G also surged, around 4000-4500 at ~16-17 psi.. |
#150 | ||
Oh man im so excited...hearing all this good news! So do you believe it is a definite gain going from V1 TO V2? Once i get my car up and running..and the Dyno Man finishes building his DynoJet in town I will gladly post my charts.
#151 | ||
See You Spring 2013
You will be happier then a fat kid at his BDAY! I'm so excited for you!
Sold:2010 MB BR Stage 3 Auto Test Pilot Sold:2012 KW BR Stage 3 MT ![]() Current: 2012 Apex Silver Evo X GSR ![]() Auto Guys Message Me With Any Question Or Concerns!
#152 | ||
All that CAKE!!!!= all that BOOST lol. thank you.
#153 | ||
Vroom Vroom Party Starter
My dyno session got delayed a couple days. I used to be sponsored by the shop back when I was big into drag racing with my Camaro. I had him tune my car when I was basically stock with CMD, so im eager to get back and see the difference. I was supposed to get tuned yesterday, but I could tell he was slammed, and behind a little, so I told him I could wait until early next week. Also my new/real HKS will be here today. So as a just in case, I wouldnt mind my $20 fake HKS being off the car when we tune. His dyno does read low compared to other local dynos, so Im not looking for high numbers, but I am looking for huge gains. lol Im just hoping to be over 300whp/325wtq on his dyno. That would put me at around 75whp gain, and 65wtq over my 20lb CMD tune. If I can get 325hp/350tq on his dyno, that would be amazing.
Daily: Twin Turbo SHO Taurus. AWD, Black on Black Airaid Intake, Tint, Viper 2 way Remote Start Hertz HSK165XL Comps, Audison Amp 2 10inch Sundown Subs, Kicker IX Amp Sold: 2010 White 2.0T R-Spec Haltech, 19t Best Dyno: 320whp/384wtq Toy: 2007 Kawasaki ZX-14 Best Dyno Pull: 228whp 135wtq Currently torn down and getting a built motor 300whp or bust Near St Louis? Join our group. https://www.facebook.com/groups/215112971924325/ |
#154 | ||
...Ill do the HORSEPOWER dance for you too
#155 | |||
2.0 MT - Shanghai
Can you post your CMD logs when you have something stable. It'd be great to compare the spool up and the rest. For power and torque, unfortunately only dyno graphs would be useful to compare. There's no graph of a V1 at 20 psi flat or higher from what I know. It would be good in these conditions to have a V2 dyno graph with the same boost BBB was running the V1. Anyway, these are exciting news!!! Can't wait to see what will be achieved by the soon to be dynoed cars!
#157 | ||
#159 | |||
Dynojet Combustion Management Device Product Downloads / Accessories / Buy Options
#160 | ||||
Jedi Master
I am not a list of mods but what i know and share: http://www.gencoupe.com/2-0t/94778-fuel-system-what-you-need-know.html http://www.gencoupe.com/2-0t/86146-wastegate-101-a.html http://www.gencoupe.com/2-0t/91199-compressor-maps-how-read-them.html Fav. JT Quote Quote:
| td05h-16g vs td04hl-19t | troyracin54 | 2.0T Discussion 2008-2012 | 124 | 12-05-2012 09:23 AM |
| Feeler: PRW TD04HL-19T used (R&D) | cdnsigop | British Columbia | 5 | 01-27-2012 08:15 PM |
| Feeler: PRW TD04HL-19T used (R&D) | cdnsigop | Saskatchewan | 7 | 01-26-2012 07:19 PM |
| Feeler: PRW TD04HL-19T | cdnsigop | Engine | 12 | 01-21-2012 06:55 AM |
| Offical NSPP Tuning Thread | formsim | 3.8 V6 Discussion 2008-2012 | 125 | 04-25-2010 04:10 AM |
