Lifter Tick? - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 04-20-2012, 07:42 PM   #1
Default Lifter Tick?
Hi, I was wondering if anyone else is having this problem? I believe it's a lifter tick but not 100% sure.
0420122028.3gp - YouTube
2012 Gencoupe 2.0T R-Spec
Performance:// AEM CAI // cp-e FMIC // DR 3" Catless DP // Custom 3" Ark Grip // BTRcc Race Spec // Synapse BOV // KW V3 Coilovers // DTM 2-Piece Rotors // R1 Slotted Rotors // Jun B.L OCC // TWM Short Shifter //
Exterior:// Hana Bumper // G35 Rays // 6000K HIDs // Stage 3 LED Lighting // Switch Back Turn Signals // Clear Corner Lenses // 5% Tint F/R/Bar //
Interior:// Prosport EVO Boost & Wideband Gauges // MB Quartz Speakers // Hardwired V1 //
NihS07 is offline   Reply With Quote
Old 04-20-2012, 07:59 PM   #2
Flip! What the zip?!
Hijinx's Avatar
Could be...or it could be the clutch. Sure would be nice to see something in that video.
DEPO | BTRcc | MEGAN | SAMSUNG | MST | NGK | GrimmSpeed | Torque Solutions
Hijinx is online now   Reply With Quote
Old 04-20-2012, 08:04 PM   #3
Gen Coupe 2.0/Manual
Xocai Genesis's Avatar
I've got the same sound coming from my car. not sure what it is
2010 Bathurst Black 2.0T Premium
SFR Flash
OEM GT Strut Bar
OEM GT Wheels
Khumo Ecsta SPT
Eibach Pro-kit
SPARCO 20mm rear spacer
K&N Typhoon Intake
SuperLUX Tail Lights
8000k HID KIT
HKS Plate Cover / LED
M&S Type D Grill
XOCAI GENESIS
Red Barcinas
MXI Corp. Executive
XOCAI "The Healthy Chocolate"
mxi.myvoffice.com/redbarcinas
Powered by XE
Hyundai Genesis Coupe 2.0T
Premium
(Bathurst Black)
SFR FLASH WoW
Xocai Genesis is offline   Reply With Quote
Old 04-20-2012, 08:20 PM   #4
you hear the sound better from the front wheel wells than from the top of the engine if that helps, i've talked to several genesis owners who have the same sound. is it just normal and i'm overreacting?
Old 04-20-2012, 08:23 PM   #5
Hijinx's Avatar
You drive a manual? Then it's fine. Mines does it from time to time as well. It's just the clutch.
Old 04-20-2012, 09:37 PM   #6
1-2-3-4-GRRRIIIINNND-5-6
daniel1pist's Avatar
I hear something like that. Very similar to what I hear on my friend's miata. Specifically when I'm close to the interval for an oil change.
Sound comes from near the head than the clutch.
Originally Posted by THETA 2.0T View Post
All of you deserve to have your cars turned into cubes.
Originally Posted by SplitSurf View Post
How long before the pencils start exploding and the anal beads broadcast reruns of The View to your girlfriend's colon when you turn them on?
daniel1pist is offline   Reply With Quote
Old 04-21-2012, 04:47 AM   #7
PowerBuild Member
GenTech's Avatar
Thats not normal in anyway.
That deffinetly sounds like top end. I would take the vavle cover off and peak around if i were you, that has to be valve/lifter/rocker noise.
Even low on oil wouldnt make that noise, it would make a similer noise, but you can distinguish thats one valve/lifer/rocker.
whoever has a clutch thats making that noise, not normal either, no stock clutch makes that noise, even after market clutch w/ chatter doesnt sound like that.
GenTech is offline   Reply With Quote
Old 04-21-2012, 07:03 AM   #8
I've always thought it was normal. I hear it on mine and all other local 2.0's in my area.
Old 04-21-2012, 07:04 AM   #9
Do you have an OEM oil filter? Is the PS fluid full?
!!!!!LET THE BANKS!!!!!
!!!!!!!!!COLLAPSE!!!!!!!!!.
Red Raspberry is online now   Reply With Quote
Old 04-21-2012, 01:23 PM   #10
Mechanical Engineer
Captlombardi's Avatar
sounds like the orchestra of injectors, turning pulleys, and lifters to me. mine sounds the same and i got it brand new, only 5k miles on it so far.
Captlombardi is offline   Reply With Quote
Old 04-21-2012, 04:13 PM   #11
Hijinx's Avatar
Shows what you know...
Old 04-22-2012, 07:45 AM   #12
I have to agree with gentech.
that slow repeating sound means its coming from the top end and wouldn't be from the flywheel, because that sound would would be faster.
cams move at half the speed of the crank, flywheel moves same speed of the crank.
OP can pop off the valve cover and poke around, but I would take it to the dealer if still under warranty.
Never mind, read mod list lol
Bust out the torque wrench and make sure everything is tighten everything to spec.
Tightening torque
Step 1
M6 : 5.9N.m( 0.6kgf.m, 4.3lb-ft)
M8 : 14.7N.m( 1.5kgf.m, 10.8lb-ft)
Step 2
M6 : 10.8 ~ 12.7N.m(1.1 ~ 1.3kgf.m, 7.9 ~ 9.4lb-ft)
M8 : 27.5 ~ 31.4N.m(2.8 ~ 3.2kgf.m, 20.3 ~ 23.1lb-ft)
AKGC is offline   Reply With Quote
Old 04-22-2012, 09:34 AM   #13
I agree with GenTech. It's definitely not the lifters. They make a little ticking noise. Nor the clutch or flywheel. The only noise I have heard from the tranny is the low rpm cruise around flywheel rattle and the rubbing noise it makes when parked and the noise goes away when the clutch is pressed in.
X3oNx0x00 is offline   Reply With Quote
Old 04-23-2012, 03:05 AM   #14
PowerBuild Member
GenTech's Avatar
Dont know weather or not to be insulted or not with that one.
Old 04-23-2012, 06:39 AM   #15
RudyH's Avatar
It is normal - in that every 2.0T makes the same noise.
It's def where you are saying its coming from, but I don't know if it's a good idea to just go around with a torque wrench tightening things. Agree should take it to the dealer or a proper shop.
RudyH is offline   Reply With Quote
Old 04-23-2012, 06:48 AM   #16
PowerBuild Member
GenTech's Avatar
The only tick you can hear, is fuel injectors, and its a small quiet tick, and that noise he's having is NOT a small noise. Therefore, not normal. If you can't distinguish between lifter tick or fuel injectors, don't do any of your own work.
Old 04-23-2012, 02:42 PM   #17
Hijinx's Avatar
The clutch thing was normal in 3G Eclipses. It was downright normal. And on these cars...its not out of the normal.
Old 04-23-2012, 02:52 PM   #18
PowerBuild Member
GenTech's Avatar
Oh I'm sorry, I wasn't aware this was a forum for Eclipses, I retract my statements.
No no wait.. I don't. Bud, listen, if your not going to be useful, stay off the thread. There are far to many people out there that are being misled because of mis diagnosis due to people like you saying "its normal on other car brands". And again, I'm sorry, but that noise, isn't normal on any modern car.
Old 04-23-2012, 02:56 PM   #19
Actually watch the video. it's not normal.
and I said to go over the cams with a torque wrench because a cap could of loosened or whoever put it together could of torqued everything in the wrong pattern.
if it's still happening after that, then take it to a mechanic.
Old 04-23-2012, 02:59 PM   #20
Hijinx's Avatar
Eat a d***. I'm not your bud. It's normal and not out of the ordinary. Maybe you should learn why instead of claiming that I'm wrong. There's a reason it rattles. I asked for a video with picture to possibly SEE where the sound was coming from. My clutch rattles a bit...then I depress the clutch and the rattle goes away. It's always done that, just like others cars have.
And the reason I brought up the 3G was because I did have lifter tick with it, AND my clutch rattled. My experience may not be on this platform, but I have experience with both conditions nonetheless.
Video: See what makes Shelby SuperCars founder Jerod Shelby tick RSS-Autoblog Autoblog 0 01-02-2012 12:10 PM
Oil Filter Tick Invalid_user Engine 9 06-27-2011 11:22 AM
Tick tick tick Tommich 2.0T Discussion 2008-2012 13 03-04-2010 06:50 AM
