2013 Genesis Downpipe Fitment Question - Hyundai Genesis Forum
post #1 of 27 Old 06-21-2012, 08:03 PM Thread Starter
So on genracer.com there a couple exhaust option that say it will fit on 2013 2.0t. i was wondering would the tsudo downpipe fit the 2013?
rosepocoloco is offline
post #2 of 27 Old 06-23-2012, 10:06 AM
Drakkcoil's Avatar
GenRacer.com only lists the ISIS and MXP downpipes in their 2013 section.
2013 2.0T - For the 2013 Genesis Coupe at GenRacer - Performance parts for the Hyundai Genesis Coupe
So I assume those are the only 2 that fit. Could be wrong though.
2013 BB 2.0T Premium M6
PTE 6152 56-trim | PRW Cast T3 Top Mount Manifold | TiAL 38mm Wastegate | DeatschWerks 1000cc Injectors | DeatschWerks DW200 255lph FP | FabZilla SRI | FabZilla Custom Catless O2 Housing |
WeirTech CBE | Synapse BOV | FabZilla ICP | RTM 3x12x30" FMIC | Eibach Pro-Kit | AEM Digital Boost, WB AFR & Oil Pressure | ATQ Short Shifter | OEM LSD | Haltech Tuned by APH | AEM Electronic Boost Controller @ 30psi
425whp, 351tq
Drakkcoil is offline
post #3 of 27 Old 06-23-2012, 02:11 PM
genvador13's Avatar
both are really (mid pipes) not downpipes a true down pipe is what they call o2 housing that removes the 1st cat,,
but yes the (isis & mxp ) will fit ,,i have the isis on my car you wont realy notice anything much at all maybe 2hp,,but if you plan on full 3inch exhaust its a must
genvador13 is offline
post #4 of 27 Old 06-23-2012, 02:59 PM
Parabolica2.0T's Avatar
Anyone know if theres a difference in the previous yrs downpipe or not?
Parabolica2.0T is offline
post #5 of 27 Old 06-23-2012, 04:14 PM
max9string's Avatar
wich cat that you remove that makes the engine light come one?
max9string is offline
post #6 of 27 Old 06-23-2012, 07:45 PM
Drakkcoil's Avatar
The cat is bolted to the turbo then?
425whp, 351tq
post #7 of 27 Old 06-23-2012, 08:19 PM
Fought to Live
hmcclung's Avatar
The first cat (immediately after the turbo) has the O2 sensor and therefore will cause a CEL if removed.
2012 2.0T Premium Monaco White auto *sold
2013 2.0T RSPEC Beckett's Black
To Each His Own:
15% Tint
Forge Atmo BOV
GCP Intake
ISIS CBE w/ mid & test pipes
Tein S springs w/ Eibach 20mm spacers
Kicker speakers, amp, and L3
DD H7 HID conversion 6K w/ relay harness
hmcclung is offline
post #8 of 27 Old 06-23-2012, 09:21 PM
genvador13's Avatar
you can install test pipe for rear cat and not get a check eng light.like i did....
if you gut or have a downpipe/o2 housing made, since there is not made for the 13 yet you will get a check eng light till a tune comes out to remove the cel light for it.so no last years downpipe/02 housing will not fit are new turbo
gcp is working on true downpipe that removes 1st cat just off the turbo,,,should make it spool up faster and gain 10 to 15 whp&tq
should be ready in a few weeks if all go,s as planed,,,cant wait for it
post #9 of 27 Old 06-23-2012, 10:18 PM
What about the previous model downpipes that bolt onto the first cat? Would that bolt up to our cat on our car?
post #10 of 27 Old 06-24-2012, 09:28 PM
genvador13's Avatar
if you are talking bout this then yes it will fit ,,,,,,really its a mid pipe (or what i call it),,,genracer has this item...for the 2013s
http://i1170.photobucket.com/albums/...3/downpipe.jpg
post #11 of 27 Old 06-24-2012, 09:38 PM
PM me for deals
Sam@PRW's Avatar
That is not a midpipe. You should call that a downpipe. Midpipe is what goes from the test pipe to the axle back.
Your best source for upgrades that matter!
19t's
Bosch Injectors
Coming soon:
Fuel return line setups
Originally Posted by Quartermaster View Post
Hydro printing is for making Carbon Fauxber fake wannabe carbon fiber ricer crap products that not only look bad and not like carbon fiber, but they cost almost as much and cause you to eventually develop colon cancer.
Sam@PRW is offline
post #12 of 27 Old 06-25-2012, 04:49 AM
Yea that's wat I was talking about.....u know if any sound or performance difference with that?
Sent from my Autoguide iPad app
post #13 of 27 Old 06-25-2012, 07:45 AM
genvador13's Avatar
maybe 2hp ..sounds the same as befor,,but if you plan on full 3inch exhaust you will need it....the real performance will come from the o2housing ( when thay make 1 for are 19t turbo) that removes 1st cat (and what us old school guys call a downpipe ,,lol
post #14 of 27 Old 06-26-2012, 05:30 AM Thread Starter
i look under the car and it looks the same. but the stock piping is pretty close so like he said, i dont think i would notice much. but the tsudo has a cat del on their pipe so maybe that will make a difference?
post #15 of 27 Old 06-26-2012, 10:46 AM
2013 R-Spec 2.0T
I have a isis down pipe that I have not installed yet, would getting the test pipe that removes the second cat help with more rwhp. I have not decided if I want to get a single exit exhaust or duel exit exhaust. So I'm getting everything else first.
2013 Genesis Coupe 2.0T R-Spec
GenSport Carolinas
BASELINE DYNO RESULTS (STOCK)
232whp
236tq
Forge Atmosphere BOV (removed and for sale)
Formula One window tint 29%
DEFI 60mm Boost gauge
Isis down pipe
Isis test pipe
Tein S-Tech lowering springs
xxr 531 (19x8.5 and 19x10)
SFR stage 1.5 tune (removed because his tune is junk)
ARK Dual Grip
HPS brake pads front and rear
Injen SRI
Synapse BOV w/cold pipe
LEICHTWORK is offline
post #16 of 27 Old 06-26-2012, 12:40 PM
genvador13's Avatar
yes test pipe will help gain some more flow rate and hp ,,,i have done both with stock cat back and removed muffler with y pipe in to stock tips sounds good and def gained some hp 15 hp maybe...gona install isis cat back soon
post #17 of 27 Old 06-26-2012, 05:11 PM
Was the Y pipe Custom made....? of did you just get the mid pipe?
post #18 of 27 Old 06-26-2012, 06:12 PM
genvador13's Avatar
y pipe that replace muffler was custom made at muffler shop for now till i get money for isis race exhaust...i had to have some more sound asap lol
made it lil bit faster cant wait for full 3inch isis exhaust.....if u wonder what it sounds like just onbolt ur muffler right after axle there ya go
post #19 of 27 Old 08-23-2012, 07:00 AM
eastpureplaya's Avatar
Does anyone know if this will fit the 2013 gencoupes?
Genesis Coupe 2.0L Turbo 76mm Tsudo racing Down pipe test pipe coupe
I hope so....
|MODS|
TurboXS RSD CB Exhaust | SFR Tune | Evolve HF O2 Housing | Evolve Down/Testpipe | Evolve IC Piping | Evolve Short Ram Intake | Vibrant Air Filter | Synapse BOV | Prosport EVO Boost/Wide-band/Oil Temp Gauge | System Upgrade STS | BC Coilovers | Grimmspeed Intake Manifold | Gemini AR CF hood | VIS K2 CF Trunk | Roof Spoiler | Custom Painted Interior | CUSCO Roll Cage | AME TM-02 Wheels | CF Diffuser | Valeo HD Clutch | Quaife LSD | Whiteline Rear Sway Bar
eastpureplaya is offline
post #20 of 27 Old 08-27-2012, 03:28 PM
can you post a video of your exhaust? rev, drive by, in car (windows up and down) that would be very helpful. I know you said if you wana know what it sounds like unbolt the muffler, but that would be a problem if we dont have the car yet like me, (stupid korea strike)
2.0luver is offline
Gear in this thread - Powered by O'Reilly Auto Parts
wheel fitment question ArmyHooah Wheels, Tires and Brakes 2008-2012 2 07-12-2011 09:18 PM
wheel fitment question - kT Wheels, Tires and Brakes 2008-2012 12 04-03-2011 07:02 PM
New Wheels fitment question stevek Wheels, Tires and Brakes 2008-2012 1 07-14-2010 06:18 PM
Fitment Question ashhabib Wheels, Tires and Brakes 2008-2012 15 06-25-2010 03:38 PM
Fitment question fade Wheels, Tires and Brakes 2008-2012 5 01-13-2010 11:58 PM
