I searched and searched and couldn't find exactly what I was looking for. I even used google and didn't find the answer so I'll ask it here. ( flame suit on). I can not find an exact how to on installing my new bov off the intake manifold, instead off the oem setup with ecu control. I remember seeing a picture a while back that had every thing shown on it but now I can't find it. Can someone help me out.
Sent from my iPhone using AG Free
2013 Rspec-Tsukuba Red Lower, Wider, and Faster *Weirtech Race o2 Housing*Isis Downpipe*CNT test pipe*CNT Single Exit*SRI W/ AEM Filter* Weirtech I/C Pipes*Synapses BOV*SFR Tune*Stance Super Sport Coils*Garage Line Spacers*Torque Solutions STS* ![]() ![]() ![]()
#2 | ||
FLAME ON!!!!!
![]() this isnt exactly neat, but its the only video i've seen to show the process that was taken. anyone chime in if you feel a better job, or different method can be taken
2013 Genesis Coupe 2.0T |
#3 | ||
Pretty much the same process you'll find on any boosted car. Find a boost refernce and run it to the BOV... Why avoid the factory solenoid though? I ran the factory solenoid, and still do, for 40K miles without issue and 3 different BOVs (stock, forge ms, and synapse). Bypassing the solenoid just bypasses safety mechanisms built into the ECU.
#4 | ||
Well I'm installing on the cold side for one do I might as well pull from that side and two I have heard it doesn't actuate as fast since its ecu controlled. I am installing a synapses bov also
#5 | ||
Synapse even suggests running their BOV off the factory solenoid, I'd say they know best. Synapse isn't a spring based BOV so you should have no issues with it not reacting fast enough. I'm running one with my Evo 9 kit and it works flawless off the factory solenoid.
#6 | ||
I would not run a Synapse off reference boost unless you are also recirculating it. VTA without the solenoid control would leave your car breathing unfiltered air in through the BOV at idle. (Synapse BOVs are "normally open")
(YASQ) Synapse BOV normally open? |
#7 | |||
With the Tial BOV the factory solenoid works, but only with the black spring, and you will still get some surge, especially at part throttle shifts. They just work better using a boost reference. |
#8 | |||
The IC pipes and intercooler are at positive pressure at idle because the turbo is spinning and pumping air, granted very little, but air does not get sucked into an open BOV even at idle. |
#9 | ||
Daily Dreamin'
Hey Rev Ron, what is the short ass line you used on your bov, I want to use the same.line since it seems to be in a good spot just not sure what line that is
#10 | ||||
I can feel a small bit of air coming out of mine at idle.
#11 | ||
Site Sponsor
![]() Join Date: Nov 2011
hope these help.
2013 Genesis Coupe BOV kit | Facebook
Formerly known as WeirTech |
#13 | ||
Ex-DSMer
2012 Genesis 2.0T Nord Gray A/T Ark Grip v.2, K&N Intake, TurboXS DP Some visual mods and Ricer horns Avantgarde M368s, H&R Springs |
#14 | ||
The pictures worked wonderful and I just ended up running it off the intake manifold just like in your pictures.
![]() Sent from my iPhone using AG Free
#16 | ||
#17 | ||
White 2.0T A/T
how is the synapse running with off the intake manifold? Last i saw people were having problems. Look at the bov source comparison thread in the 2010 2.0t section.
2012 Karussell White 2.0T A/T HP - 183 TQ - 205 on stock tune Mods: Eibach Sportlines, and some stuff ;D pm me if you wanna know how i got to these nnumbers....... |
#18 | ||
| CEL after installing forge BOV!!! | mykee | Ontario | 29 | 10-02-2012 04:59 PM |
| Does anyone have the instructions fo installing the hks bov and agp adapter? | Jamaicanballer | 2.0T Discussion 2008-2012 | 35 | 10-15-2011 02:33 PM |
| CEL after installing HKS BOV Kit | pneetpal | 2.0T Discussion 2008-2012 | 7 | 06-22-2011 10:10 PM |
| help installing FMIC with bov (hks knock off) | el_ramon | 2.0T Discussion 2008-2012 | 8 | 03-22-2011 07:32 PM |
| Installing both cp-e intake and hks bov w/ cp-e kit? | ericthedude | 2.0T Discussion 2008-2012 | 2 | 09-15-2010 10:12 PM |
