Problems with Revs going up between shifts. Throttle position sensor? - Hyundai Genesis Forum
post #1 of 7 Old 05-07-2015, 01:11 PM Thread Starter
If i am accelerating nd I go to shift it goes like this:
1) take foot off gas
2) push in clutch
3) rpms go up relative to the throttle position before taking my foot off
4) after they go up some they will go back down after about 2 seconds
At the same time this started my cruise control also stopped working.
I was thinking it was a throttle position sensor. I stopped by a NAPA and an Autozone, and neither of them could get one. Where can I buy one?
Ecreps is offline
post #2 of 7 Old 05-07-2015, 05:56 PM
TenZen's Avatar
Quoted: 177 Post(s)
Throttle by wire throttle bodies don't have a TPS.
2013 3.8 Track 8 Speed A/T
K&N Replacement Filter
BFGoodrich g-Force COMP-2 A/S (OE size)
TenZen is offline
post #3 of 7 Old 05-07-2015, 07:36 PM Thread Starter
So I would need to buy the entire throttle body?
Does anyone have any input on what they think this issue may be caused by?
The three main things I can think of are:
Throttle Body
Pedal assembly
ECU
Ecreps is offline
post #4 of 7 Old 05-07-2015, 08:02 PM
TenZen's Avatar
Quoted: 177 Post(s)
Throttle Body
Pedal assembly
ECU
No idea what could cause it. You could disconnect the battery for a bit and see if it does it again. I would dig for info to see any ways of testing the throttle body and pedal assembly, I'm not familiar with this system.
TenZen is offline
post #5 of 7 Old 05-08-2015, 12:53 AM
MiloBear's Avatar
Quoted: 47 Post(s)
I have similar issue have had it since bought car.
Rev hanging I've noticed it's worse when cold so assume it's something to do with ECU and protecting engine.
MiloBear is offline
post #6 of 7 Old 05-08-2015, 10:12 PM
Quoted: 235 Post(s)
not very wise to throw parts at a car before a diagnosis is made.
It sounds like rpm hang. Mine does this as well until its warmed up fully, ecu also limits boost until it reaches operating temp. Downside of DBW (drive by wire) is how much control the ecu has over throttle inputs.
Mine hands even once warm randomly. Makes having an aftermarket bov to scare ricers away mostly useless unless aggressive WOT shifts because it wont fully lift throttle when I do to decel the engine and vent any built up pressure, it just hangs for a second or two.
2013 Empire State Gray 2.0t Base 6MT
- HKS SSQV
- K&N Drop-In
- Exceladyne CBE
thomas91169 is offline
post #7 of 7 Old 05-09-2015, 05:31 PM
99.9% Lurker...
ScarlettGen's Avatar
Quoted: 25 Post(s)
Check the switch at the top of the clutch pedal. If may have gotten stuck in the "pressed/closed" position.
2014 2.0T R-Spec
Mods:
K&N SRI
Synapse BOV
Treadstone IC piping
Snow Performance Stage 2 W/M Kit
TurboXS Racepipe
Exceladyne Cat Back
MAMBA GTX3076r
SPA T3 Manifold
Precision 39mm Wastegate
394whp 320wtq SAE (No meth)
ScarlettGen is offline
hm throttle position sensor? throttle cable? throttle body stuck? hajimah 2.0T Discussion 2008-2012 9 02-22-2015 04:16 PM
Throttle position sensor output voltage lead? YellowGC 3.8 V6 Discussion 2008-2012 20 07-14-2010 02:31 AM
boost vs throttle position KEgcYYC 2.0T Discussion 2008-2012 4 05-04-2010 06:34 PM
Throttle Position vs HP Floorit 2.0T Discussion 2008-2012 7 01-05-2010 10:37 AM
electronic throttle and gear position sensor; are we getting ****ed? mr_desmo Engine 46 03-10-2009 04:20 PM
