gencoupe.com gencoupe.com
Go Back   GenCoupe.com Forums - Your Hyundai Genesis Coupe Community > Genesis Coupe Tech > Engine > 2.0t
Old 03-01-2009, 04:17 PM   #21
nice so do you guys actually think the stock internals can handle 400who or so???
Current Car: 2007 NHBP Civic Si 4-door, i/h/e and 75shot of spray
part out has begun
Furure Car:2.0T Track Model, coming late march or april of 2010 color unknown at this time!!
Originally Posted by FlesHBoX View Post
There is also a very solid stop at the bottom as well, while I am more used to a softer "am I all the way in yet?" feeling with others.
ImAuthenticFTW is offline   Reply With Quote
Old 03-01-2009, 04:23 PM   #22
Flesh's Henchman
CKurt3's Avatar
Oh, its an engine....
NOW: 2005 Ford Ranger SuperCab (Red) 4.0L V6 LATER: 2011 Genesis Coupe 2.0T Premium (Karussel White)
Originally Posted by Jeremy Clarkson
Why do you not lie awake at night yearning for the day when you can own a Hyundai? Simple. Because Hyundais are not made to plunge their hand into your pants. Only to plunge their hands into your bank account.
I politely disagree.
CKurt3 is offline   Reply With Quote
Old 03-01-2009, 04:23 PM   #23
Site Sponsor
Luke@BeyondRedline's Avatar
I really like the head design, but it does leave room for improvement. Also the sleeve depth is a lot more favorable for boost than other engines I have seen. I honestly do think that this should handle 400whp, it will just depend on how much you can get away with before switching to something higher octane than 93.
Luke@BeyondRedline is online now   Reply With Quote
Old 03-01-2009, 04:26 PM   #24
thats good seems like my goal is very feasable then, im aiming for around 300-350whp on pump gas for a street tune
part out has begun
Old 03-01-2009, 05:16 PM   #25
Galbi's Avatar
Awesome! Thanks for the engine tear down pics. You guys are amazing!
The Pony is now a horse
Galbi is offline   Reply With Quote
Old 03-01-2009, 07:54 PM   #26
HP builder/Fabricator
Thanks for sharing. Looks promising.
NSX - Big snail
GSX - 571whp 490wtq - My baby for the last 15+ years
Genesis Coupe? Hopefully soon
Momin@EliteAutosport is offline   Reply With Quote
Old 03-01-2009, 11:46 PM   #27
hardmack's Avatar
Whats the bore? Planning on getting some 2.4l rotating assembly pieces together..
hardmack is offline   Reply With Quote
Old 03-02-2009, 12:05 AM   #28
Original member
it's an 86mm bore x 86mm stroke i believe. square engine so should be good to rev to 8000 safely and smoothly. i think stock it revs to 7200.
Seraph0503 is offline   Reply With Quote
Old 03-02-2009, 06:05 AM   #29
Galbi's Avatar
Hmm...thats the same bore/stroke as the EVO X. Good stuff.
Old 03-02-2009, 06:45 AM   #30
its the same bore and stroke as a lot of performance engines lol 2jzgte, K20 and more
part out has begun
Old 03-02-2009, 08:55 AM   #31
96gsx's Avatar
Everyone's wonderd if the Evo manifold will bolt up to the head. Any word on that?
Hyundai Salesman.
DSMtuner.
96gsx is offline   Reply With Quote
Old 03-02-2009, 09:35 AM   #32
Galbi's Avatar
I cant tell from the pictures but does this motor have any counter balance? The Automobile mag said that this motor does NOT.
Old 03-02-2009, 10:13 AM   #33
Site Sponsor
Tim@BeyondRedline's Avatar
This engine is NOT equipped with any counter balance shafts. I can't recall but does anyone know if the Chrysler or Mitsubishi cousins have them?
Tim@BeyondRedline is offline   Reply With Quote
Old 03-02-2009, 10:42 AM   #34
Galbi's Avatar
They dont either.
Mitsubishi 4B1 engine - Wikipedia, the free encyclopedia
Old 03-02-2009, 11:10 AM   #35
this looks very promising... few things I can't tell from the pics though...
Rods... are they cracked cap or machined
ringlands look fairly spaced apart.. and I'm assuming that's a teflon coated skirt in the picture as well too. Anything else you've noticed that you can't really get a picture of? Like oil squirters, anything along those lines?
Overall though, I'd say we're definitely likely to see some 400rwhp cars, and the 300-350 range should be very safe on them. Really depends on if anybody unlocks the ecu, or how well it adapts to higher boost levels and the such.
Genecrosis is offline   Reply With Quote
Old 03-02-2009, 11:12 AM   #36
there was a quote on here already from someone at Hyundai that said "while the ECU isnt easy to crack, if someone really wanted too they will" or something along those lines, ill try to find it
part out has begun
Old 03-02-2009, 11:18 AM   #37
FlesHBoX's Avatar
I believe it was a quote of John Krafcik and was something along the lines of;
It wasn't designed to be easy to crack, but it is not hard.
..: J e s s e :..
Easy like Hyundai morning.
Originally Posted by logitec View Post
when i see flesh has made a comment i usually scroll through to read what he said due to the fact I dont think hes been wrong yet...
FlesHBoX is offline   Reply With Quote
Old 03-02-2009, 11:22 AM   #38
Notice this quote:
"Core components such as pistons and rods should move freely between them, for example. Hyundai’s engine uses a different computer, from Siemens. The software wasn’t intentionally made easy to crack, “but it’s not very tough,” says one Hyundai exec with a wink. That means up to 300 horsepower should be possible without major surgery."
part out has begun
Old 03-02-2009, 02:54 PM   #39
Site Sponsor
Rods are Cracked Cap
Ringlands look spaced apart and boost friendly. The top ring is fairly low as far as new production engines that have to pass todays emissions are concerned.
Also this motor is equipped with oil squirters, and not the BS ones like the 2G Eclipse had.
Old 03-02-2009, 04:07 PM   #40
Are you by chancing putting the rods through any tensile strength tests or the such? You guys are actually going through and doing exactly what I wanted to do with ours in a few months (I want to build our car up through the standard bolt ons route to see what works best and how far stock components can be taken for less money).
Anyways, cracked cap rods aren't hateful. I still prefer a nice forged and machined unit, but the cracked rods worked very well in the srt-4's as well too. Thanks for the info though, I'll be sure to chuck you guys some electronics information once I get my grubby hands on our 2.0t :-P That's also going to be quite interesting on these cars imho, how the DBW reacts to larger map voltages, sweet scaling spots for larger injectors and clamping the map, ahh I can't wait to get to tinkering with a brand new toy :clap:
