gencoupe.com gencoupe.com
Go Back   Genesis Forum: GenCoupe Hyundai Genesis Coupe Forums > Genesis Coupe Tech > Engine > 2.0T
Old 03-18-2009, 03:43 PM   #1
Galbi's Avatar
Default ECU tune results of 2.0T
This is a Korean dyno on a 2.0T manual.
Only an ECU mapping was done. Stock turbo, intake, exhaust everything.
Stock: 188whp(PS), Torque 30.2kg.m
ECU Tune: 223.6whp(PS), Torue 42.6kg.m
Approximately 35whp(PS) gain and 12.5kg.m torque increase.
The Pony is now a horse
Galbi is offline   Reply With Quote
Old 03-18-2009, 03:53 PM   #2
1ps is not quite equal to 1hp. 188ps is roughly 185whp. So 223ps is 219whp. But nice gains nontheless.
mkit8971 is offline   Reply With Quote
Old 03-18-2009, 03:54 PM   #3
.:EX 300WHP TIB OWNER:.
Corey Maurer's Avatar
I told you guys all we needed was a reflash... imagine intake exhaust downpipe upgraded intercoolr and a reflash...this car is gonna make insane power easily..
|B|O|O|S|T|
My Anti-Drug
..::True ///OFFSET\\\ is done WITHOUT spacers::..
Corey Maurer is offline   Reply With Quote
Old 03-18-2009, 03:58 PM   #4
el chupacabra
NeverNZ's Avatar
seems hard to beleive it is just an ECU tune
NeverNZ is offline   Reply With Quote
Old 03-18-2009, 03:58 PM   #5
el chupacabra
NeverNZ's Avatar
especially with the stock crimped exhaust
Old 03-18-2009, 04:01 PM   #6
AdR
Topless = More Fun 4 Me!
AdR's Avatar
I'd be happy if it is.
Currently own: 2003 Eclipse Spyder GTS - Chrome Blue Pearl
Next car: Genesis Coupe 2.0T Track - Bathurst Black
AdR is offline   Reply With Quote
Old 03-18-2009, 04:03 PM   #7
Banhammer power activate!
N2OInferno's Avatar
Why? I've seen amazing gains on turbo'd cars with just a tune.
Now I want to see a stage 2 intake/turboback tune.. possibly upgraded injectors too.
Mitch Hedberg
N2OInferno is offline   Reply With Quote
Old 03-18-2009, 04:36 PM   #8
amazin and knowing that from 5500rpm up injectors are maxed out the additionnal power comes from leaning upping the boost adjusting timing...nice work....must be perfect for drifting easily...and you can pass cars 40mph in sixth gear no problem no need to shift a geat...dream stuff...go turbo or go home
mr_desmo is offline   Reply With Quote
Old 03-18-2009, 05:10 PM   #9
96gsx's Avatar
Exciting news. I wonder what JR has to say about this.
Hyundai Salesman.
DSMtuner.
96gsx is offline   Reply With Quote
Old 03-18-2009, 07:16 PM   #10
Would this affect mpg at all? The stock air/fuel mixture is insane. I see the engine has been leaned out, but is that because more air has been added or less fuel has been used?
MP-Omnis is offline   Reply With Quote
Old 03-18-2009, 07:18 PM   #11
traction control off =]
cant_stop_spinning's Avatar
yeah um... judging from the graph they changed the rev limiter to 7,500 rpms.
but i wonder what all they changed? because the info we have gathered from JR and the AMS crew leans towards the car needing injectors if they are going to up/hold decent boost.
but we all need to remember, this info comes all the way from korea, and details can get left out, like new injectors only or something.
"I downshift next to hybrids so they can hear me killing the enviroment "
-Beyond Redline Stage 3
cant_stop_spinning is offline   Reply With Quote
Old 03-18-2009, 07:38 PM   #12
looks like they leaned it out a bit
Brillo is offline   Reply With Quote
Old 03-18-2009, 07:40 PM   #13
Didn't sfr make 235whp with an ecu tune?
Still impressive with just a tune but not unreasonable.
theironmonk is offline   Reply With Quote
Old 03-18-2009, 10:11 PM   #14
I wish they could also do ecu tuning for v6.
s2kysk is offline   Reply With Quote
Old 03-18-2009, 10:25 PM   #15
they will retune the V6..
anyone who cant beleive the change in power from a tune.. obviously knows nothing about tuning.. look @ the difference in AFR...
|B|O|O|S|T|
My Anti-Drug
Old 03-18-2009, 10:28 PM   #16
EvoX make about double that on just a tune. 1/335i make about double that on a tune. This seems very believable. Truth be told, I'm dissappointed in that result. I'm hoping for more.
2 gsrs: evoX and 98integra
joe_r is offline   Reply With Quote
Old 03-18-2009, 10:51 PM   #17
Jaynesis's Avatar
You can get over 60 WHP off of just a tune for the EVO X and 135i/335i ??? I am no expert on those cars but that sounds a little much to me.
Jaynesis is offline   Reply With Quote
Old 03-19-2009, 12:42 AM   #18
Jalmir's Avatar
Yup, some 135i/335i owners have seen up to 75whp with just a tune.
Jalmir is offline   Reply With Quote
Old 03-19-2009, 04:18 AM   #19
SUB-GEN's Avatar
nice numbers imo
SUB-GEN is offline   Reply With Quote
Old 03-19-2009, 05:05 AM   #20
GenCoupeFTW's Avatar
Did they also turn up the boost or just tune the air/fuel/timing maps?
GenCoupeFTW is offline   Reply With Quote
