gencoupe.com gencoupe.com
Go Back   Genesis Forum: GenCoupe Hyundai Genesis Coupe Forums > Genesis Coupe Tech > Engine > 2.0T
Old 03-19-2010, 11:15 PM   #181
You Mad?
NJGX03X87's Avatar
Originally Posted by briansol View Post
Yeah, the injectors are likely set on a multiplier within poweraxel. You can just swap CC numbers, and the map stays the exact same.
so if you had 750 injectors installed... u would have to replace the stock injectors b4 u flashed back to stock?
NJGX03X87 is offline   Reply With Quote
Old 03-19-2010, 11:17 PM   #182
CrookedH's Avatar
Yep
CrookedH is online now   Reply With Quote
Old 03-20-2010, 04:19 AM   #183
1sty's Avatar
For stage 3 I am guessing new turbo and new clutch.
1sty is offline   Reply With Quote
Old 03-20-2010, 05:28 AM   #184
Zoile's Avatar
Does the Fmic keeps the crash bar?
Wow!!
Winning an argument online is like winning the special olympics, at the end, you are still retarded.
Happy Genesis Coupe owner
RRM Intake.
Eibach Pro-Kit.
+ a lot more.
Zoile is offline   Reply With Quote
Old 03-20-2010, 05:42 AM   #185
Site Sponsor
Tim@BeyondRedline's Avatar
Wow!!
Yes, the crash bar is kept in tact. No cutting/welding required.
I'll have a detailed write up on the Intercooler kit sometime during the week.
Tim@BeyondRedline is offline   Reply With Quote
Old 03-20-2010, 05:43 AM   #186
Zoile's Avatar
Ok,,,now i hate you...i will have to buy this kit now.
RRM Intake.
Eibach Pro-Kit.
+ a lot more.
Old 03-20-2010, 06:04 AM   #187
Do the I/c pipes come flanged for a bov? And does it include a secondary cat delete? Thanks!
Justin182 is offline   Reply With Quote
Old 03-20-2010, 06:04 AM   #188
is it fair to say at this point that the stock turbo is maxed out? I'm trying to think of other ways to get the HP number up. TQ really isn't an issue at this point.
2004 RX8 6speed with MazdaSpeed Suspension
Brillo is offline   Reply With Quote
Old 03-20-2010, 06:39 AM   #189
I'd say so... you could always try meth injection, but the turbo is tiny and trying to push it further would just be blowing hot air into your engine. At this power level the car should be tons of fun, so I'd say if you're not satisfied with this it would be cheaper (and alot more fun) to just throw on a new snail and go! I'm sure BR has something like this in store for us. I'd also imagine that much more power than this you'll be needing a clutch, so you have to remember that expense as well.
I WANT THIS KIT SOOOO BAD!!!!
Old 03-20-2010, 07:24 AM   #190
Site Sponsor
The IC pipes do not com pre-flanged as its designed to use the stock BOV.(which at this level works just fine)
We are more than willing to accommodate flange requests on a case by case basis.
Our downpipe does eliminate the need for the secondary catalyst. However it does not cause any check engine lights etc.
Old 03-20-2010, 07:25 AM   #191
Site Sponsor
We may have some tricks left up our sleeve that could boost peak hp a bit more...
Old 03-20-2010, 07:26 AM   #192
Site Sponsor
You are spot on about the clutch. However, don't forget about the dual mass flywheel. We are rapidly approaching the limit of its usefulness as well.
Old 03-20-2010, 09:13 AM   #193
traction control off =]
cant_stop_spinning's Avatar
finally this summer is looking like we might have some fun!!!
looking forward to seeing the writeup on the intercooler before i'm sold....
"I downshift next to hybrids so they can hear me killing the enviroment "
-Beyond Redline Stage 3
cant_stop_spinning is offline   Reply With Quote
Old 03-20-2010, 09:39 AM   #194
DIY King
Projectx7's Avatar
Hmm after seeing this i may be changing my mind on tuning solution and going with you guys....
Red R-Spec 2.0T
Projectx7 is online now   Reply With Quote
Old 03-20-2010, 10:30 AM   #195
cjd82187's Avatar
You will when you hear the exhaust... give me a call, I'm in your area right now. Just came back from a cruise around Asharoken for some odd reason. Lookin for something to do =)
-CJ
Bathurst Black R-Spec Owner
247whp/287wtq with Exceladyne TBE, FMIC, and Fuel Line, TiAL Q, AEM CAI, 550cc injectors, R-Spec Camber Bolts and Beyond Redline PA Tune.
Also have Replacement hoses and vac lines, M&S Type D Grille, GlowShift Boost Gauge, KPR Matte Black Shift Knob
cjd82187 is offline   Reply With Quote
Old 03-20-2010, 11:10 AM   #196
2.0T track #3875
briansol's Avatar
@BR request:
Can you get a dyno graph with both stock, stage1 and stage 2 on the same chart?
2.0Tt
Bone Stock
briansol is offline   Reply With Quote
Old 03-20-2010, 11:25 AM   #197
@BR request:
+1
Also is there a flywheel solution out there yet?
Old 03-20-2010, 01:20 PM   #198
Site Sponsor
@BR request:
Ask and you shall receive....
Old 03-20-2010, 01:35 PM   #199
Ruinerofallfun's Avatar
Damn! Nice! So what your saying is I just need a TBE and some injectors and I'm looking at 20WHP more... oh and a custom tune :P haha Damn! I want a v6 killer! TAX MONEY!
2.0T Base Black
Mods:
debadged
CHIC BOV
IC6020F Full Pipe Replacement Intercooler kit
ITG filter + 3D Intake Pipe
Ruinerofallfun is offline   Reply With Quote
Old 03-22-2010, 05:07 AM   #200
These posts are great and I too can't wait to see the stage 3 results. I'm really excited that we are having the opportunity for our cars to grow some Balls lol. With stage 2 kit installed this car should definately turn some heads at the track for sure. Do you think soon we can see some videos of the phoenix project build so I can stare at it long enough for me to buy the stage 2 kit! Just sayin
010boostcoupe is offline   Reply With Quote
