#1 | |||
Hey guys I've been noticing a good amount of heat coming from the floor/firewall of my cabin which floats up and reaches up to my knees. This is with a 3.8 R Spec and it occurs when my car has warmed up. Notice it when I come to a complete stop and begin moving forward. Car currently only has an r2c Intake but I've noticed this happening when it had the stock airbox as well.
I'm wondering if this is a common occurrence with other members and if there is a fix for it. I'm sorry if there's a thread for this already, I've searched for a half hour and would greatly appreciate it if you guys could point me in the right direction. Came to a conclusion/answer. Quote:
#2 | |||
Shifty Eyed Engineer
For it to actually radiate through would require alot of heat coming from the transmission. Auto or Manual?
2011 5.0 Mustang GT/CS 2013 5.7 Hemi Grand Cherokee |
#3 | ||
When you say "heater vents set to the foot well" do you mean is it on the option to direct air to my feet? If so, then no. The air is not on that setting. Also, I have a manual transmission. Thank you very much for the reply btw.
2012 Genesis Coupe 3.8 R Spec |
#4 | ||||
Is this happening with the A/C on?
#5 | ||
I honestly wouldn't be surprised if they were stuck open. The car is a little short of 5,000 miles off the lot but has been having excessive and unresolved clutch chatter and transmission problems since 300 miles :P.
And no the a/c isn't on when this happens. Mine is running warm even after a short distance, like today it happened after a 2 mile drive to fill up my tank.
#6 | ||
new 3.8L owner
I sometimes get the same thing with a manual. sketches me out a lil....deff feel some heat on my knees but I thought thats what comes with having a 3.8 v6 in front of you...happens with a/c on or off...should I be worried?
.neCC0. 10' 3.8L 6Spd. Track Edition ![]() -Magnaflow Exhuast -Yellow Fog Lights -25% Tint ![]() -GenCoupe emblem -L.E.D lighting all around -Google Nexus 7 Tablet much more to come... |
#11 | ||
슈퍼 쿠페 ^_^
It's perfectly normal for it to get warm where the bell housing area is as your exhaust and engine heat are directly below the foot pan. While moving the air under your hood is being directed along the transmission body and down and out, while stationary your exhaust isn't receiving air flow across it and causes it to heat up the floor pan. As long as it doesn't get too hot to touch or you start smelling melting plastic you're fine.
As previously stated, this is actually normal for most RWD vehicles, especially in our price bracket. If you're overly concerned however, you might want to consider buying a pint of eDead and spraying under your carpet, along your footwells and transmission tunnel.
Genesis 200Turbo - Mirabeau Blue - 206whp/239wtq not tuned.
Subscribe for my latest reviews and how-to's! Need help? Ask here! Follow Project Woodstock for some awesome GC goodness Buy my stuff! ^links, just click them Proudly supported by: ![]() |
#12 | |||
| Short Ram intake and Engine heat | bigblueshock | 3.8 V6 Discussion 2008-2012 | 9 | 05-14-2012 06:53 AM |
| Engine Heat | genisisNFCII | 3.8 V6 Discussion 2008-2012 | 11 | 07-20-2011 05:24 AM |
| Transmission/engine problem? | Pyrophor2011 | Engine | 11 | 06-13-2011 03:24 AM |
| SFR Engine Damper.. Cabin Vibrations | Archi13 | 2.0T Discussion 2008-2012 | 15 | 09-01-2010 11:17 AM |
| NISMO renting GT-R engine and transmission computers in Japan | RSS-Autoblog | Autoblog | 0 | 05-18-2009 12:30 PM |
