Drive Shaft Flex Discs - Hyundai Genesis Forum
 2Likes
post #1 of 183 Old 11-20-2013, 07:13 PM Thread Starter
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
Good news...
Found that my flex discs (sometimes called Guibos) on the end of my propeller (drive) shaft are cracking and it is time to replace them. This is good in that I caught it before a major failure.
Bad news...
Hyundai, unlike Mercedes, BMW, etc., does not sell these wear item flex discs on there own. You must buy the entire propeller shaft to the tune of $800-$1200 depending on where you go to get it.
Perfect...thanks Hyundai...
Trying to see if I can find one from another platform that is the same size to use or if there is a company that makes these that I can contact about getting into our market to make them for the Gen Coupe.
Senior Member of the Genesis Coupe High Mileage Club
2010 Hyundai Genesis Coupe 3.8L V6 Track M/T in Mirabeau Blue (Eva) - Retired
Bought - 25 miles, Retired - 145,000 miles, Total Miles - 145,000 miles
2012 Hyundai Genesis Coupe 3.8L V6 Track M/T in Interlagos Yellow (Fei) - Active
Bought - 22,000 miles, Currently - 83,000 miles, Total Miles - 61,000 miles
Total Miles in a Genesis Coupe - 206,000 miles
WildBill is offline
post #2 of 183 Old 11-20-2013, 07:49 PM Thread Starter
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
Looks like our best bet is to find flex discs off a low mileage totaled donor car.
WildBill is offline
post #3 of 183 Old 11-21-2013, 12:13 AM
omran's Avatar
Just out of curiosity,how did u find out its cracked?did the car drive or feel different?
I'm just asking coz I'm running 125k kms and don't know if I should be worried
omran is offline
post #4 of 183 Old 11-21-2013, 01:48 AM
Quoted: 260 Post(s)
Wow, they really don't sell them separately. Just checked
Ever thought about getting a solid aluminum puck made?
Or even a custom shaft?
I understand that you don't want to spend all the money, but averaging $1000 for oem, you can get a decent custom one.
post #5 of 183 Old 11-21-2013, 04:37 AM Thread Starter
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
Usually it is a visual inspection during other routine maintenance once you pass 60k (or the equivalent KMs) every oil change while the car is on the lift/jack stands. You will easily start seeing the cracks when they begin to wear out.
You may also notice more vibration from the drive train right under your seat as well as klunks when pulling away from a stop of engine braking (if you have M/T for the second one).
I found out by visual inspection when I had the driveshaft out while putting in the new clutch because Terrance pointed it out.
WildBill is offline
post #6 of 183 Old 11-21-2013, 04:40 AM Thread Starter
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
There is already one piece Aluminum and Carbon shafts out there. Also, I can get the OEM new for $700ish. I don't want to go Aluminum flex disc even though I know some companies that could make a custom one just because it doesn't provide the sane flex and on modded cars could lead to premature failure of other parts.
WildBill is offline
post #7 of 183 Old 11-21-2013, 09:04 AM
Keeps Them Guessing!!
BHBomber's Avatar
Quoted: 15 Post(s)
Did the '13s replace these with actual U-joints? If so would it be possible to upgrade to these parts?
3.8 GT(Can) 6M
Bathurst Black
"The more I learn about people, the more I like my dog" - Mark Twain
Using a Dynojet is like trimming your pubes. It's still the same size engine but you can see it's full potential.
BHBomber is offline
post #8 of 183 Old 11-21-2013, 09:17 AM
Quoted: 260 Post(s)
I believe the disc is there to dissipate torque load on the diff, not to be an actual laterally flexing joint.
post #9 of 183 Old 11-21-2013, 09:28 AM Thread Starter
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
No, the 13s use flex discs still. Confirmed by Snoopy.
WildBill is offline
post #10 of 183 Old 11-21-2013, 09:56 AM
ControlFreak's Avatar
Quoted: 26 Post(s)
These guys have some universal ones, compare carefully and you might get lucky.
Poly Flex Group Pty Ltd
2010 Nord Grey 2.0T 5AT- Sold
2016 DGM Rex
ControlFreak is offline
post #11 of 183 Old 11-21-2013, 11:20 AM Thread Starter
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
Interesting. Thanks for the heads up. I will look into that.
WildBill is offline
post #12 of 183 Old 11-21-2013, 11:26 AM
Ricer
Roly D Sauce's Avatar
or get an aluminum drivesaft made
Roly D Sauce is offline
post #13 of 183 Old 11-21-2013, 11:48 AM Thread Starter
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
You could do that anf there are already companies that do, but the driveshaft is fine. Just need the flex couplers. Its the difference between a $200 fix versus a $800-$1000 fix. I am on a budget right now and don't have that kind of money.
WildBill is offline
post #14 of 183 Old 11-21-2013, 02:50 PM
ElDominio's Avatar
Quoted: 31 Post(s)
Since I barely ever contribute:
... "Big name" shops live off of kids like this. Enough money to buy super sweet marked up name brand parts at MSRP and then pay outrageous labor rates all day long to have a car that could have made the exact same power for significantly cheaper that will run ten times better... ... That's when people just pay out the ass 24/7 for the rest of their lives.
-Chapter 11, Section 51
- Self-proclaimed tuner
-I tune remotely!
My Facebook page at: https://www.facebook.com/AlphaSpeedPR
ElDominio is online now
post #15 of 183 Old 11-21-2013, 02:53 PM Thread Starter
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
Nice! I am not a fan of the Revshift all aluminum flex disc myself, but if you could find out what BMW that size fits model wise, we could order and use the BMW OEM ones. Can you please clarify what model BMW that size is for please?
WildBill is offline
post #16 of 183 Old 11-21-2013, 03:00 PM
I drive a V6
2.0TGT's Avatar
Quoted: 29 Post(s)
From revshift site...
This is the 105mm flex disc with 12mm bolt holes. It is commonly found on 2006 and newer vehicles. Please refer to the cross reference links below.
The Revshift high performance flex disc is CNC machined from 6061 billet aluminum. It utilizes high quality polyurethane bushings to maximize rigidity and strength while maintaining the proper amount of flex to protect your drivetrain.
This is a high performance alternative to the oem flex disc. The oem rubber flex disc is known for failing under high loads and needing to be replaced on a regular basis. There is no longer a need to worry after you install a Revshift flex disc on your BMW.
- CNC machined 6061 aluminum body
- 95A durometer polyurethane bushings
- Replacement for OEM part # 26117546425 (LK=105mm/12mm)
- Rebuildable using one of our flex disc rebuild kits
Installation Instructions
Product Code: FLX-10512V
2010 3.8
Bilstein PSS Coilovers
Eibach sways bars
Braelin BR02 19"
Solo Performance exhaust
2.0TGT is offline
post #17 of 183 Old 11-21-2013, 03:25 PM Thread Starter
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
Yeah, I didn't see the url links originally nor the reference to the BMW OEM part number. I am going to buy one of the BMW OEM ones to check size and fit and will report back.
WildBill is offline
post #18 of 183 Old 11-21-2013, 07:45 PM
ElDominio's Avatar
Quoted: 31 Post(s)
One of my clients had his one cracked too, and he took the measurements to get one, and well, this is their reply.
-I tune remotely!
post #19 of 183 Old 11-22-2013, 04:13 AM Thread Starter
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
FYI to all, I will also take the opportunity to post this as a DIY too. Flex discs aren't hard to begin with, but it is always nice to have something to reference.
WildBill is offline
post #20 of 183 Old 11-22-2013, 05:09 AM
Why so serious, Bro?
GenCoupeGeek's Avatar
Quoted: 1201 Post(s)
Okay... now I'm subb'd. I want to grow up to be just like WildBill so when I have 200,000 miles I will still be driving my coupe. Yanno... unlike most of our mods on here.
BTRcc Custom Tuned
~Albert Einstein
GenCoupeGeek is offline
Loud drive shaft? Kris76 General Discussion 5 02-28-2013 04:10 AM
Drive shaft Game Over on a 2013 2.0T phayzie Ontario 13 06-04-2012 05:44 PM
Interest?? aluminum drive shaft SoCalturbo Engine 130 02-09-2012 01:40 PM
Drive shaft feeler surfmavrik 2.0T Discussion 2008-2012 19 11-27-2011 01:09 PM
Drive shaft feeler. surfmavrik 3.8 V6 Discussion 2008-2012 13 10-31-2011 05:09 AM
