#181 | |||
Injector Flow Rate (cc/min) = Engine HP x BSFC x 10.5 / (Number of Injectors x Injector duty cycle) 306 * 0.5 * 10.5 / (6 * .6) = 446.25 cc/min I am just asking, not implying I know anything.
3.8 Yellow Track 6MT I am talking out of my a$$ 99% of the time. Last edited by tgpfarm; 03-25-2011 at 10:26 AM. |
#183 | ||
Why do you need boost tables exactly? For a roots type supercharged engine? I am new to this so curious
2010 Genesis Coupe 2.0T GT 6-speed in Nordschleife Gray Last edited by RudyH; 03-25-2011 at 12:11 PM. |
#184 | ||
I am new also but I am not sure you actually need to do that. I mean they run roots superchargers with carbs. It can't be much harder than just skewing the fuel curve.
3.8 Yellow Track 6MT I am talking out of my a$$ 99% of the time. |
#185 | ||
turbo or supercharger, both make BOOST. even 1 psi is enough to throw most cars off. Most n/a ECU's don't have boost tables for igntion/fuel. They only have vacuum maps. When the map tells the ecu that its over '0' vacuum, there's currently NO table to get ingition or fuel map information from, and it throws a code, and goes into limp mode.
The ecu either needs to be BLOCKED from ever seeing boost (map clamps, other hacks, etc) or the ecu needs to be modified to know what to do with boost (aka, a reflash with positive boost tables for ignition and fuel.
#186 | ||
Hello,
Don't take this wrong, but you are getting way too complex. Everybody goes off the deepend and makes things more complex than they really are. There is no such thing as a boosted ECU. Its all in the fuel curve. The ECU has a fuel map that is based on RPM and load. As the load increases with RPM there is more fuel and injector pulse width. It's very simple. As far as ignition tables. Everyone freaks out and says you need to be able to pull timing with boost. That's a load of crap to a point also. With the factory ECU as load increases, timing decreases. When I reflash the 2.7l ECU, I add timing because of how much load the MAF sees, it pulls way too much timing and hurts peak torque. Plus the factory is overly conservative on timing and fuel. Factory ECU's are generally very fat as load increases and pull a lot of timing. So why can we run a low boost set up without bigger injectors and tuning? Because, there is generally a lot of conservative fuel to eat up as the load and RPM increase. This is why with N/A bolt ons, headers, intakes, exhausts, you need to do a tune in order to make best power. Why, because as you increase the amount of volume through the engine, the MAF sees it as more load, which puts it in a higher load table which has more fuel. So, you have to lean out those load tables in order to make best power on an N/A setup. So to put this simple, we are using the 3-5 lbs of boost as the tune, to eat up that conservative fuel table in the higher loads. I'm not concerned about the MAF sensor as it will have enough range for a good amount of boost before it peaks. It's the MAP sensor I have to deal with since it is only 1 bar and will peak at 4.0 volts. So, I have a very simple device that will clamp the MAP at around 3.8volts. Thanks TC NGM |
#187 | |||
I have read through all the threads and man are people fast on seying the negative parts. Let him work on the project ! Let him post pictures etc. When he will be ready he will be ready ! I emagine having to read all the negative comments and it must be hard for Him to stay positive on the project . I am sure that 99% of the people on this thread cannot produce what this company is doing for our GC. Let him work ! Keep up the good work !
Silverstone Genesis 2010 380 GT Auto
#188 | ||||||
Ie, at column 9, you're ok, but at column 10, you enter boost zone, and the factory 3.8 ecu does not have these colums to read said load in the first place. (a hondata image, but the same concept applies) ![]() Quote:
However this: Quote:
Clamp = hack job piggy back trickery that should be avoided at all costs IMO. Again, I applaud your effort to make a kit, but I would also suggest into getting with one of the tuners to get a flash/tune to go along with it. You'll get better numbers, better results, and be a HELL of a lot safer, and my respect. To some people, that's more important.
#189 | ||
Hello,
Like I said. Your to complex, but that's ok it's something to take up your time. Your basing your findings off of a MAP based tuning. This has a MAP and a MAF. The MAF looks at the load as the weight of the incoming air in mg, kg ect. Anyhow, honestly I don't like to type and this takes too much time trying to explain to someone that is set on having all the answers so I will move forward from here. Thanks TC NGM Last edited by nextgen03gt; 03-25-2011 at 03:25 PM. |
#190 | ||
From the dyno's I've see on stockish 3.8's they're really not running all that rich. Most I've seen have been in the 12:1 range, which for N/A is somewhat rich, but not rich enough to support 80whp extra.
Do you plan on using any fuel tuners? If so, that would put a lot of the debate to rest. Even SFR said it's a bad idea to boost without a tune, I think they know a thing or two about the ECU as they're one of only 2 companies in the US that can tune the Delphi ECU. They have also actually tuned a V6 before, not just winging it, know what I mean? Are you planning on using a zener diode to clamp the map? Are there ANY details you can give out about the tuning? I think saying "keep it simple you're too complex" is a bad idea, you're acting like everyone on this site is a bunch of morons and you're a car god. I know you said this isn't your first rodeo and the same can be said for most of the people asking questions.
#192 | ||
wow, ask valid questions and get an answer like that? Glad I dont have too worry about doing business with you.
#194 | ||
Ngms thread? As he stated himself, he didn't start the thread. Why is it so wrong to ask questions and expect an answer, even if its "we're not ready to divulge that info yet". It's the same questions anyone should ask before they purchase something like this for their car.
#195 | |||
"The amount of intake air flow must be inputted to ECM in order to determine the fuel injection quantity. To measure the pressure inside of intake manifold, MAFS is used at idle and MAPS is required at accelerating. MAPS(Manifold Absolute Pressure) calculates the amount of air indirectly as measuring the pressure inside of intake manifold. This system is called a Speed-Density type. MAPS transfers analog output signal which is proportional to the change of intake manifold pressure, then, with this signal and RPM, ECM calculates the amount of intake air flow." HMASERVICE |
#196 | ||
nextgen, I don't think briansol is trying give you any negativity on your project, but rather pointing out concerns or issues that he might have experienced. I think people of all experience could learn a thing or two with the comments that he has made. His reasoning of the complexity is necessary for this ecu. if you want to be successful with the project (i do hope that you do suceed), you should take it as pointers.
#197 | ||
Thank you for the support.
I've tuned 25+ cars in my day on all walks of life, various software, all motor, n/a, import, domestic, you name it as a free-lance tuner (ie, i never worked for a shop. friends told friends who told friends i can help them because their car ran mint after i was done with it) I'm just trying to save fellow gen coupe owners from buying into unfounded hype, and when your car blows up, you'll get a "sorry" from the dealer and a "not our problem" from the s/c mfg'er and you end up having to spend 10 grand out of pocket for a new motor. Do it right, or don't do it at all.
#198 | ||
![]() To me, with maps like that (CAPA : Eaton Superchargers) you don't need a "fuel table". You just need a way to add X amount of fuel. Hell if RRM's piggyback thing worked or dynojet made a fuel controller this would be awesome. Need a way to clamp the the MAP sensor. A way to increase fuel rate, in general. Not per rpm. What am I missing? With a turbo your VE is all over the place and as such you need finer fuel trims. With a supercharger, you should have pretty flat curves.
3.8 Yellow Track 6MT I am talking out of my a$$ 99% of the time. Last edited by tgpfarm; 03-25-2011 at 06:45 PM. |
#199 | |||||
MR TURBO 2 U
firstly i agree with 80% of ngms statements
secondly who are you all to ask him or anyone to justify anything! so what have we here! the kit is not finished, we have no description of content, and a developer trying to do his job as i have here inthe past! he has stated facts will come as they are available! wait or p/o simple! you will be lucky if he comes back on to disclose info due to your insults! (you call them questions i and believe he will see them as an insult to his inteligence) Quote:
in summary: let the poor bugger do his job sort it out and they once done ASK all you like don't DEMAND as you have been! if then there are still genuine concerns point them out! till then innocent till proven guilty!!! keep up the good work ngm would love to see more facts like 440cc@55psi i for one apreciated it!
let the results speak for themselves!!! "Only two things are infinite, the universe and human stupidity, and no one is really sure about the universe yet"
Albert Einstein (1879-1955) |
#200 | |||
Past: 2011 3.8 R-spec Bathurst Black Present: 2013 YF Sonata GLS Indigo Night |
| 3.8 supercharger! | justin@powerAXEL | California | 23 | 06-21-2011 08:52 PM |
| BOV on supercharger | Madhockeyplaya7 | 3.8 V6 Discussion 2008-2012 | 10 | 04-01-2011 12:10 PM |
| must have supercharger | trackcoupe380 | 3.8 V6 Discussion 2008-2012 | 21 | 11-01-2010 04:55 PM |
