Oil Changes - Hyundai Genesis Forum
post #1 of 18 Old 02-15-2017, 05:23 AM Thread Starter
Sorry if this is a sticky, but I am having a nightmare on mobile right now. What kind of synthetic motor oil do you guys use for a 2010 and how often do you replace it and the filter? Thank you for any kind responses. Just bought my car 3 days ago from a Subaru so they did not have all the info for me. P.s. I drive about 15k a year and dont really beat on it (I shift at about 3000rpm)
nvalde46 is offline
post #2 of 18 Old 02-15-2017, 06:45 AM
inertiamonster's Avatar
Quoted: 575 Post(s)
You'll get a lot of different answers on this topic, on an enthusiast forum oil becomes a highly debated topic. The easiest thing to do is to stick to the recommended 5W-30 from a quality brand, I'd recommend Pennzoil Pure Platinum because of its current reputation, the OEM filter, and change it every 5,000-7,500 miles per the factory maintenance recommendations.
If you want to get more into the weeds you can do some searches and read the countless other oil threads already here. You'll find people running everything from 0W-20 to 5W-40 oil in these cars from every brand you can think of and changing it from anywhere between 3,000-10,000 miles, one consistent thing is almost everyone uses the OEM filter.
2013 3.8 Track Pearl White
inertiamonster is online now
post #3 of 18 Old 02-16-2017, 11:55 AM
Quoted: 246 Post(s)
harsh condition climate (below freezing, about 90*f) = 3,000 miles
otherwise 4,000~6,000 miles or every 3 months.
post #4 of 18 Old 02-16-2017, 12:58 PM
Yoda
GC Rider's Avatar
Quoted: 28 Post(s)
I used synthetic in my 2011. Changed it every 5000 miles. Never had any problems, and it was running like a scalded dog when I sold it at 110K
Suppose you were an idiot. And suppose you were a member of Congress. But I repeat myself.
- Mark Twain
GC Rider is online now
post #5 of 18 Old 02-16-2017, 03:32 PM
Quoted: 575 Post(s)
That's the 2.0T schedule, 3.8 is longer (3,750 severe, 5,000-7,500 normal).
post #6 of 18 Old 02-16-2017, 03:49 PM
Quoted: 33 Post(s)
For the 3.8 the manual specs anything from a 5w20 to a 5w40 for "performance" driving or some sort of verbage like that. If all else fails, just follow the manual. However I can tell you that I have a 2010 3.8 with around 155,000 miles on it currently that I have put most of the miles on, with 6,500-11,000 mile oil change intervals (depending on which oil I'm trying out) and all of the lab analysis reports have come back fine. Unlike others, I actually decide to back up my methods with data rather than speculation. I use 5w20 because and an OEM filter. Every time my engine is warmed up it sees at or near the redline. It sees hot Texas summers and has seen some cold winters in the same oil change interval. It sees miles of extended moderate-high loads at moderate RPM's (100+mph @ ~4,000rpm) on toll roads for hundreds of miles every month.
So there's really no need in the 3.8 for anything beyond a 5w20 with an OEM filter unless you are frequently tracking your car. I would personally do 5-7k oil change intervals with regular oil and up to 10k with synthetic, farther if you have lab results to make sure everything is fine. I am currently running Mobil 1 Extended Performance 5w20 with an OEM filter and will be sampling around 10-11k. I personally like the Castrol Edge Extended performance best but I got some discount Mobil 1 so I'm cool with that. My next oil change interval I will be trying a Fram Ultra filter to see if I can lower the insoluble material count in my oil and maybe see if any wear numbers correlate. I know there is a TSB about using non-OEM filters and startup noise, so I will have an OEM filter on standby to swap out if that happens even once, but the filtration efficiency of the Fram Ultra vs the OEM filter looks better.
nvalde46 if you have any particular questions about oil feel free to ask and I will answer them factually with sources to the best of my ability.
Also, inertiammonster, come by and have a drink!
Lethal1ty17 is offline
post #7 of 18 Old 02-16-2017, 04:24 PM
Quoted: 246 Post(s)
Thats a general rule of thumb for engines made past 2003... unless it has some stupidly high tolerances like some buicks.
10,000 miles or yearly oil changes anybody?
post #8 of 18 Old 02-16-2017, 04:32 PM
Quoted: 33 Post(s)
See my above post. I've done 11k, currently averaging 9-10k with no problems and have data to back that up.
post #9 of 18 Old 02-16-2017, 05:56 PM
Cone Killa
ApexEight's Avatar
Quoted: 137 Post(s)
Just a heads up the Fram Ultra (XG9999) doesn't fit our cars. I tried on my 2010 3.8. For some reasom Fram lists it for our cars but it's definitely too tall. You can see others say the same on Amazon reviews. It appears to fit other Hyundai V6s which might be where Fram got confused.
Are there any other good, relatively cheap synthetic filters out there?
ApexEight is online now
post #10 of 18 Old 02-16-2017, 06:28 PM
kcasusi's Avatar
I'd stick with OEM filters; they work great and they're cheap off ebay ($20-25 for a pack of 5)
ウエスト·サイド。
kcasusi is offline
post #11 of 18 Old 02-16-2017, 06:52 PM
BS without pics!
Adamantine's Avatar
K&N PS-7029
Napa Gold FIL-7029
STP S10515XL
I'm currently using the STP S10515XL Extended Life filter with Pennzoil Platinum.
2014 Genesis Coupe 3.8 Ultimate, Casablanca White
Braided Brake/Clutch Lines | Subframe collar insert Kit | Duralast Max Brake Pads
Retired: 2010 Genesis Coupe 2.0T Track, Tsukuba Red
Adamantine is offline
post #12 of 18 Old 02-16-2017, 07:06 PM
Quoted: 33 Post(s)
It did look quite tall when I got it. I only ordered it because I saw some people comment that it actually fit theirs. Might have to get an OEM filter and go into Walmart to see which Ultra fits in a side by side comparison.
post #13 of 18 Old 02-16-2017, 07:08 PM
Yoda
GC Rider's Avatar
Quoted: 28 Post(s)
Nope! I put about 20K/year on my GC I could probably go closer to 7500 miles (maybe more according to the stats listed above) using synthetic, but 5K is a nice round number, easy to remember, and if I get too busy and forget, I'm still good for another 2.5K before the next change Texas weather can be harsh on engines
- Mark Twain
post #14 of 18 Old 02-16-2017, 07:15 PM
Quoted: 33 Post(s)
As long as everything is in working order it's not too bad. Little dusty in some areas, but I believe the cold is actually rougher on oil.
post #15 of 18 Old 02-17-2017, 09:40 AM
Quoted: 246 Post(s)
I live in alaska and use to work above the arctic circle.... you don't know harsh weather. In Fairbanks, it regularly gets -30*f ~ -40*f
post #16 of 18 Old 02-17-2017, 02:10 PM
I would stick with the recommended oil viscosity for sure i like using Mobil One or Castrol oils, I buy my filters for $4.79 and their O.E. Hyundai filters https://www.hyundaipartsdeal.com/gen...nt-case,,26300
seanracerx1986 is offline
post #17 of 18 Old 02-17-2017, 03:08 PM
Yoda
GC Rider's Avatar
Quoted: 28 Post(s)
You get many tornado's, floods, and hurricanes up there I do think the cold is worse than the heat for an engine.
- Mark Twain
post #18 of 18 Old 02-17-2017, 04:27 PM
Quoted: 246 Post(s)
Tornados- no
floods - yes
hurricanes - pretty much the whole west coast of the state
-65*f windchill - yes
you get landslides large enough to remove roads and access to certain parts of the state, wildfires that burn a 1/16 of the state ?(keep in mind land mass-wise, alaska is about 1/3 the size of the rest of the US)
I need to move . As you can tell I'm bored.
More oil stuff...how I got lower temps and what I notice running redline oil (so far) Jesse Crabtree Engine 46 12-03-2016 11:05 AM
Oil Prices Expected to Drop by Half: Gulf Oil CEO AutoGuide.com AutoGuide.Com News 0 07-15-2013 01:30 PM
VEI dual guage oil temp/oil pressure gauge for sale Terrance32 Interior 1 07-06-2013 09:28 AM
65w transmission oil? lower weight cold trans oil? bren5279 Drivetrain 28 03-18-2013 10:39 AM
What Oil for synthetic engine oil? Viscosity? (dont have my owners manual) GenTarkin 2.0T Discussion 2008-2012 61 08-23-2011 10:26 AM
