Magnaflow resonated x pipe - Hyundai Genesis Forum
post #1 of 7 Old 02-16-2017, 11:57 AM Thread Starter
Question Magnaflow resonated x pipe
Sup, never posted so my apologies if something with formatting is wrong. I just recently purchased a 2012 3.8 Track MT, with 80k miles. Loving it so far, aside from the inability to shift smooth without ample practice and understanding of this unique transmission. I'm looking to change the exhaust set up, I'm not into any of the premade systems out there. The muffler delete sounds good but I feel as if I might get annoyed with it. The flowmaster 80 has a good volume but I don't particularly care for the pitch and wine that comes with it. I've decided try something custom, I'm thinking of putting a magnaflow resonated x pipe (11386) directly after the secondary cats, with dual piping back to tips. I feel as if this is the best option, it will include an x pipe and resonation without the need for separate parts. I don't believe that anybody has tried this before, any ideas or suggestions?? I'm actually worried that it will be too quiet, considering that the resonation occurs where the pipes cross.
kstonebeats is offline
post #2 of 7 Old 02-17-2017, 01:43 AM
TwoBigBalls's Avatar
Sup.
I messed around with our factory exhaust for a bit before picking what I wanted.
Which included drilled primary and secondary cats (secondary cats first, swapped out for test pipes, then drilled primary).
Created quite a bit of "err, grr, rumble, whistle, pop", in that order.
Honestly the Second cats being replaced with test pipes would have been sufficient to make it sound much nicer IMO, but the muffler had to go anyways.
I have straight pipes out the end now with an X pipe in place of the test pipes, STOCK down pipes and header as well because replacing those doesn't seem worth it at the moment and I like the startup/idle purr. Doesn't have any rasp until 5.5K+ RPM which at that point airflow is high enough it sounds like love. My wife, having heard me hit the posted "40"mph (or 108, who knows anymore) on the back roads here said it sounded beautiful. So I guess I'm solid.
Of all the real custom setups I've heard, straight w/ primary cats to test pipes then resonators and exit - seemed to sound the nicest. Every video I've watched as well as testing with my own car showed a CAI also changed the range of rasp to higher up, in case you haven't done that already.
Dual tipped exhaust is a must have, otherwise it just looks odd (excluded; Turbo owners, rock on with them single pipes please).
TwoBigBalls is offline
post #3 of 7 Old 02-17-2017, 02:04 AM
StrangeLiform's Avatar
Quoted: 51 Post(s)
We used a resonated X-pipe setup on Project Hoondy's custom exhaust and it worked fantastically. We assembled separate resonators and X-pipe components to build a custom mid-pipe, but an integrated unit like the one you're looking at from Magnaflow should perform similarly. Resonators really help cut out the drone without reducing the aggression of the exhaust sound when you get on the gas.
We wanted minimal rasp from our system, so we kept the cats and integrated a custom muffler as well. A no-muffler system will have more rasp and be louder overall, but that should be ok if you're into that sort of thing.
Here's how it ended up sounding, a muscular no-rasp, no-drone setup that we've really fallen in love with:
I don't know about that specific Magnaflow unit, but there are definitely several guys running an integrated resonator/x-pipe combo. There are a couple of different old Ferrari mufflers that work as resonated X-pipes. Mufflers from both the Ferrari 456 and 550 have been used, really wild sound:
Here's a pic of a Ferrari 550 resonated X-pipe install, this is on a GenCoupe that belongs to Jesse Crabtree:
Yea, don't worry about that. Any no-muffler install on this platform is LOUD. Even our own setup with a muffler is pretty damn noisy when you get on the gas.
Loving it so far, aside from the inability to shift smooth...
As a side-note, the notchy shifting and potential missed shifts on this platform are caused by floppy drivetrain mounts, not the transmission itself. A Megan Racing Transmission mount will help the problem and firmer engine mounts will eliminate it completely. We have upgraded engine, trans, and rear diff mounts on Project Hoondy and you can tell how slick our shifts are as a result in that exhaust video posted above.
Happy tuning!
StrangeLiform is offline
post #4 of 7 Old Yesterday, 06:11 AM
superchode's Avatar
Quoted: 274 Post(s)
I just actually did this (#11385)..... Was gonna go with a used maserati GT center muffler. I am glad i didnt..... It is a flat out wicked sound with 2-1/4" piping. Not too loud when cruizing but holy sheep ballz it comes to life when you open her up... You will have to like some drone here and there, it doesnt bother my def a$$ . And coming from my previous single setup the car is awake now.... Anyway cant go wrong with this. If you can listen to this with headphones, there are some sounds the phone just wont put out.
https://youtu.be/oMFsjRT2JlE
superchode is online now
post #5 of 7 Old Yesterday, 06:14 AM
superchode's Avatar
Quoted: 274 Post(s)
Happy tuning!
Holy crap that rear muffler!!!! Work of art right there
post #6 of 7 Old Yesterday, 12:25 PM
Quoted: 51 Post(s)
Hand-built by Ron at SpinTech exhaust. It says: "COME AT ME BRO!"
post #7 of 7 Old Yesterday, 01:06 PM
superchode's Avatar
Quoted: 274 Post(s)
Well whoever Ron @ Spintech is.... He's a freaking wizard. I love that and most things that are out outside the box thinking. Thanks for sharing
Tags
3.8 , exhaust , magnaflow
Magnaflow w/ h-pipe? dogoca 3.8 V6 Discussion 2013 and up 14 05-24-2016 08:53 AM
Magnaflow CBE w/ ARK H-pipe dogoca General Discussion 1 05-13-2016 07:24 PM
Resonated Test Pipe LyleH General Discussion 0 03-14-2015 08:33 PM
Magnaflow + Test Pipe -- Too Loud Rotax800 3.8 V6 Discussion 2013 and up 16 10-06-2013 05:47 PM
Will a O2 HFC and resonated test pipe allow me to spit fire? Levy Ontario 18 03-11-2013 09:20 PM
