[[BTRcc]] Canned and Custom Tune Dyno Results for 3.8's - Hyundai Genesis Forum
post #1 of 434 Old 11-17-2011, 08:56 AM Thread Starter
Custom Dyno Tunes!!
BTRcc's Avatar
BTRcc has been working on tuning Genesis Coupe's with custom tunes.
Following will show what BTRcc's tuner has done so far and also give you a hint of what your car can do with our custom or soon to come canned tunes with complete ECU replacements.
Examples of our canned tune on stock vehicles (MT and AT)
MT 3.8 Stock (Before/After)
AT 3.8 Stock (Before/After
MT 3.8 Intake + Exhaust
AT 3.8 Intake + Exhaust
Next are a few fun ones that our tuner has been having fun with in Korea
MT 3.8 Twin Turbo
AT 3.8 Twin Turbo
AT 3.8 Rotrex Supercharger
EDIT:
2.0T
Stock tune $650
1. Removal of speed governor
2. Increased Rev Limiter (Manual Only)
3. Increased throttle response
4. Ability to turn off the traction control 100% when you press the button
5. Option to turn off the 2nd O2 sensor
Bolt on tune $700 (includes features of stock tune)
1. Adjustments of the tune according to your bolt-ons, such as FMIC, Exhaust, Intake, etc
Race spec tune $750 (includes Stock and Bolt on tune features)
1. 1:1 throttle response (turns off cruise control permanently)
2. Launch Control System
3.8
Stock tune $750
3. Near 1:1 throttle response
Bolt on tune $800 (includes features of stock tune)
1. Adjustments of the tune according to your bolt-ons, such as Exhaust, Intake, etc
Thanks for looking
BTRcc is offline
post #2 of 434 Old 11-17-2011, 08:58 AM
Wait .. So you've tuned both supercharged and twin-turbo 3.8??
BrandonGS is offline
post #3 of 434 Old 11-17-2011, 09:00 AM Thread Starter
Custom Dyno Tunes!!
BTRcc's Avatar
Yes sir
BTRcc is offline
post #4 of 434 Old 11-17-2011, 09:07 AM
Originally Posted by BTRcc View Post
Yes sir
Very nice! What turbos did they use?
post #5 of 434 Old 11-17-2011, 09:08 AM Thread Starter
Custom Dyno Tunes!!
BTRcc's Avatar
TD05-14G x 2
BTRcc is offline
post #6 of 434 Old 11-17-2011, 09:55 AM
Genesis 3.8 R-Spec
Sthetic's Avatar
Excellent work. on the TT is there a reason you guys are running 16psi on the AT and 12psi on the MT??
2011 Hyundai Genesis Coupe 3.8 R-Spec
2004 Honda CBR 600RR
Sthetic is offline
post #7 of 434 Old 11-17-2011, 10:02 AM Thread Starter
Custom Dyno Tunes!!
BTRcc's Avatar
Just customer preference
BTRcc is offline
post #8 of 434 Old 11-17-2011, 11:34 AM
sigel's Avatar
So it clearly states that the twin turbo/supercharger was tuned in korea. Can he tune north american ECUs? Will you be importing SC/Turbo kits and have him tune it? How soon before you have the canned tune + new ecu for sale? Thanks.
2010 KW Genesis Coupe 3.8GT
Eye Candy
- RMR CF Grill
- Superlux Tails
- BBM Rear Lip Spoiler
- 2013 F/L LED OEM Sidesteps
- DD 6000k DS1/Switchbacks/Stage 2 LED
Performance
- R2C Intake w Phenolic Spacer
- UR Pulleys
- TWM STS
- ARK DP/Sec Cats/GRiP <--- Pure Sex.
- BC BR+ with MST 17/20 Spacers
- BTRcc Tuned
SOLD!
sigel is offline
post #9 of 434 Old 11-17-2011, 11:46 AM Thread Starter
Custom Dyno Tunes!!
BTRcc's Avatar
Yes we have cracked the U.S. ECU's and can definitely tune for the above mentioned setups and other variances
As for the twin turbo/sc setups, they have all been custom setups over in Korea. There was a supercharger kit that was offered that we reviewed and said that the risk factor did not make sense at the moment.
The stock 3.8 cannot handle much boost and needs to be built almost right away and this is a factor most people do not recognize. And all the inquiries we had gotten was about putting these kits on stock engines. With a stock engine, a safe parameter to run will be around 370-380 whp which is fairly weak for the amount you would end up spending for the kit.
However, this isn't to say that we will NEVER bring anything over. We are consistently working with other companies in Korea to build a reliable setup and we will keep working until we find the perfect/tested product for the U.S. market.
Lastly, We can start shipping out the canned tunes + ECU's right away.
Stock 3.8 $750 including a brand new genuine Hyundai ECU
Modified 3.8 $800 including a brand new genuine Hyundai ECU (Bolt-ons)
BTRcc is offline
post #10 of 434 Old 11-17-2011, 12:09 PM
ernibal1musicman's Avatar
so no sending in ECU's for reflash? y'all just send new ones already flashed for $750 - 800?
Current Car: Genesis Coupe 3.8 Base 6MT Nordschleife Gray
Previous Car: 1992 Camaro RS
ernibal1musicman is offline
post #11 of 434 Old 11-17-2011, 12:13 PM Thread Starter
Custom Dyno Tunes!!
BTRcc's Avatar
This is correct
keep your ECU for when you make the trip to the Dealership
BTRcc is offline
post #12 of 434 Old 11-17-2011, 12:21 PM
If we send in our ECU then how much is it cost to reflash only?
Will the result be varies for different car on reflash?
Coupe380 is offline
post #13 of 434 Old 11-17-2011, 12:24 PM Thread Starter
Custom Dyno Tunes!!
BTRcc's Avatar
We do not offer this option.
We only offer with a brand new ECU for a few reasons:
1. No down time for the customer
2. Guarantee that the ECU is in working condition since we get it NEW from Hyundai
3. Ability to save the stock ECU for warranty or reselling purposes for the customer
4. Warranty work through BTRcc doesn't require downtime on the customer.
Only time we will offer to reflash without sending out seperate ECU's is if we were to stop by your location for a tour. Which requires 6+ custom tune customers or 10+ canned reflash customers.
And as with any car, the results will vary. Every car dynos differently stock and other factors such as clogged cat or a poorly designed intake system etc. can effect the numbers as well.
Given that your car is in good condition without any issues, you will yield similar numbers as shown above.
BTRcc is offline
post #14 of 434 Old 11-17-2011, 12:37 PM
sigel's Avatar
You got my money in spring when the car comes outta storage!
Eye Candy
- RMR CF Grill
- Superlux Tails
Performance
- UR Pulleys
- TWM STS
- BTRcc Tuned
SOLD!
sigel is offline
post #15 of 434 Old 11-17-2011, 01:57 PM
elementrider87's Avatar
Quoted: 11 Post(s)
what are you guys doing for 2.0t?
Built/Benson Sleeved
Haltech,Sheppey Manifold, GTX3076, ID 2000CC/ E85, Tial EWG, Synapse BOV, BR twin pump DW300 fuel pump, Aeromotive FPR, Stage 4 clutch, DSS Aluminum driveshaft/ axles, Custom diff mounts, all tranny/engine mounts, Garrett FMIC, Grimmspeed EBCM, BC valves/springs, Undercover Intake Manifold, UR pulleys, ATQ slim fan setup, BC coilovers, AG wheels.
elementrider87 is offline
post #16 of 434 Old 11-17-2011, 02:03 PM
ptitan's Avatar
What fuel octane ratings are both the canned and custom tunes done with?
ptitan is offline
post #17 of 434 Old 11-17-2011, 02:08 PM Thread Starter
Custom Dyno Tunes!!
BTRcc's Avatar
What you see there are done with 93 octane (Stock graphs)
if your area offers something lower, please let us know and we will adjust the tune accordingly
BTRcc is offline
post #18 of 434 Old 11-17-2011, 02:09 PM
Why is AT tune so much lower?
echelonphoto is offline
post #19 of 434 Old 11-17-2011, 02:11 PM Thread Starter
Custom Dyno Tunes!!
BTRcc's Avatar
here you go
http://www.gencoupe.com/2-0t/81669-b...lts-2-0ts.html
Automatic transmission eats up a lot of power. The loss is just a lot bigger than the manual transmission, this is the case with the most vehicles on the road. If a tuner claims their Automatic numbers match Manual numbers, WALK AWAY lol
BTRcc is offline
post #20 of 434 Old 11-17-2011, 03:20 PM
BTRcc, I personally am very impressed. Very well done!
cdnsigop is offline
[[BTRcc]] Canned and Custom Tune Dyno Results for 2.0T's BTRcc 2.0T Discussion 2008-2012 1389 12-24-2015 07:44 AM
Custom tune vs canned / dyno results buzzmc 3.8 V6 Discussion 2008-2012 25 05-21-2013 10:08 AM
BTRcc Custom Dyno Tune Results Astocdm Product reviews 45 02-17-2012 08:45 AM
BTRcc custom dyno tune!!! balachel Mid-West / Great Lakes 4 08-29-2011 03:59 PM
Dyno results after SFR canned tune... Suns_PSD 3.8 V6 Discussion 2008-2012 14 06-09-2011 04:23 PM
