#22 | ||
From what I read from members far more knowledgable than I and other sources all cars can benefit from these. In my mind my car provides me so much fun and if there is anything I can do to make it run smoother or last longer I am doing it.
White Genesis Coupe 3.8 Auto/Nav SPEC SRI, SFR 1.5 Flash, Megan Race Mid Pipes, Flowmaster Muffler, Tsien Springs, Quad tips. “I’m sorry, but having a DB9 on the drive and not driving it is a bit like having Keira Knightley in your bed and sleeping on the couch.” -Jeremy Clarkson |
#23 | ||
does that catch can need to be close the actual air intake or can I run hose so I can locate it somewhere accessible?
Installing now and need some guidance... I did locate the correct hoses thanks to the folks who helped here THANKS
#24 | |||
Locate it in the coolest spot. The length of hose doesn't matter. Try to have the hoses run downhill too.
2010 Red 2.0L track Quote:
#25 | ||
Basically, from PCV (passenger side of engine or right side valve cover) to catch can to plenum (upper intake manifold). That simple.
It really makes a difference. Next time I remove the plenum, I'll take pictures of valves. Squeaky clean!
2010 3.8 GT AT Bathurst Blk | AEM CIA | GrimmSpeed PnP | GrimmSpeed Phenolic Spacer | SFR Canned Tune | Ark Downpipes | MR Mid Pipes | MR Coilovers Future mods: Ark Headers | Rotora Big Brake Kit | Quaife ATB Helical LSD | Cams (wish list) Last edited by superfreak; 04-21-2012 at 12:17 PM. |
#26 | ||
Hey thanks folks... I had to give up as I could not find a spot on the passenger side. So I will look tomorrow on the driver side for a suitable location.
#27 | ||
2010 3.8 GT AT Bathurst Blk | AEM CIA | GrimmSpeed PnP | GrimmSpeed Phenolic Spacer | SFR Canned Tune | Ark Downpipes | MR Mid Pipes | MR Coilovers Future mods: Ark Headers | Rotora Big Brake Kit | Quaife ATB Helical LSD | Cams (wish list) Last edited by superfreak; 04-21-2012 at 03:18 PM. |
#29 | ||
Well folks I installed it. I got some metal brackets and did an OK install. I am going to get something custom made so that the install not only functions well but looks good. I will post when I get this done. Thanks everyone for your help... I was close to not doing it but got r done.
![]() I think it will work well here.
#31 | ||
If this helps any, I figured I'd share how and where my catch can is installed.
Since mine came with brackets and straps I decided to bolt a bracket to the passenger side fuse box and strap the catch can to it.
2010 3.8 GT AT Bathurst Blk | AEM CIA | GrimmSpeed PnP | GrimmSpeed Phenolic Spacer | SFR Canned Tune | Ark Downpipes | MR Mid Pipes | MR Coilovers Future mods: Ark Headers | Rotora Big Brake Kit | Quaife ATB Helical LSD | Cams (wish list) Last edited by superfreak; 04-22-2012 at 02:51 PM. |
#32 | ||
Man some nice installs here.... I spoke to my buddy and we are going to make a formed piece of metal anyone can install their unit.
#37 | ||
Keeps Them Guessing!!
V6Noobie in that picture I see that you capped off the vacuum line on your injen intake. What did you do with the hose that hooked up there?
3.8 GT(Can) 6M Bathurst Black "The object of war is not to die for your country, but make the other poor bastard die for his" - General George S. Patton |
#38 | |||
제네시스 쿠페
same way i had mine in with the same intake and can.. haha
2010 Genesis Coupe 3.8 Track 6MT w/Navi - Karussel White 1995 Mazda Miata MX-5 5MT - Black █▄▄ ███ █▄▄ _ █▄█▄█ █▄█ ▀█▀ ಠ_ಠ |
#39 | ||
Do you have that hose plugged off too?
#40 | ||
제네시스 쿠페
no. i kept mine.
if anything.. he probably put on one of those small breather filters on the other end or capped that side as well.
| Why you NEED a catch-can | Snoopy0812 | 2.0T Discussion 2008-2012 | 417 | 04-28-2013 12:47 PM |
| FS: Catch Can | Heiss | Engine | 7 | 04-11-2012 09:44 AM |
| Catch can | reneirwolf878 | 2.0T Discussion 2008-2012 | 77 | 06-19-2011 02:33 PM |
| What's the catch? | teknical1ty | General Discussion | 8 | 02-06-2010 06:56 PM |
