2.0L dp flange issue - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 01-26-2012, 10:00 AM   #1
RudyH's Avatar
Default 2.0L dp flange issue
Just a quick question,
I have the high flow cat cp-e DP, and after installing it, I noticed the flange that connects the DP with the cat back piping is a lot larger then stock, and it's hitting the heat shield protecting the drive shaft.
Is there a resolution to fix this? Grind it down is the obvious answer.
PowerAXEL re-flash /w PowerX
TurboXS FMIC
cp-e down pipe
TiC Short Shifter /w bushings
Stance GR+
RudyH is offline   Reply With Quote
Old 01-26-2012, 09:05 PM   #2
(aka El Stig)
WillRacer1JZ's Avatar
I had to grind my down to solve the problem.
WillRacer1JZ is offline   Reply With Quote
Genesis Forum: GenCoupe Hyundai Genesis Forums > Supporting Vendors > Custom Performance Engineering
WTB: Hks bov flange showmethemunnys Want to Buy 0 05-26-2011 08:21 PM
FS: HKS Flange and BOV CrispedPenny Engine 16 01-19-2011 04:20 PM
Lower O2 pipe flange to muffler flange exhaust: what's out there? jvsantosmd 2.0T Discussion 2008-2012 0 07-13-2010 03:49 AM
muffler flange help flylow 2.0T Discussion 2008-2012 1 06-19-2010 02:47 AM
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon RSS-Autoblog Autoblog 0 04-17-2010 03:10 PM
