Genesis Coupe Footwell LED Kits! Easy Install! Control w/Smartphone App! - Hyundai Genesis Forum
 5Likes
post #1 of 86 Old 09-26-2012, 08:37 PM Thread Starter
www.diodedynamics.com
Diode Dynamics's Avatar
Quoted: 70 Post(s)
Arrow Genesis Coupe Footwell LED Kits! Easy Install! Control w/Smartphone App!
Looking to add a fresh look to your Hyundai Genesis Coupe's interior? Footwell LEDs are the way to do it! By adding bright LED strips under your dash, you can add a lot to the look of your Genesis.
Diode Dynamics has been producing and designing easy-to-install LED kits for nearly a decade, and this kit is no exception. We have designed new LED strips to be used in this kit, which are highly flexible, IP67-waterproof, and long-lasting. This kit also uses our RGB Multicolor products, which are controlled by the included remote! You can change the color to fit your mood.
Included in the kit:
  • 2 (two) 30-5050 SMD Strips (flexible and waterproof)
  • Wiring harness for easy installation
  • 2 (two) quick-splices for installation
  • LED Toggle switch in your choice of LED color
  • RGB Controller Box with RF Controller and 4 outputs
  • Remote Control (choose Standard or upgrade to Bluetooth/WiFi)
  • 4 (four) zip-ties and 3M outdoor adhesive pads for mounting strips
  • Three-year Diode Dynamics worry-free limited warranty
  • 30-day satisfaction guarantee
Also included with rear footwell option:
  • 2 (two) additional 30-5050 SMD Strips (flexible and waterproof)
  • 2 (two) 3-meter (ten-foot) extension wires
  • Additional zip-ties and adhesive pads
Any questions email us at contact@diodedynamics.com
*PM us for the free-shipping code* (U.S. forum members only)
Thanks!
Nick C.
Genesis Coupe - Lighting
We Are The #1 GenCoupe Lighting Experts
(314) 205-3033
Diode Dynamics is offline
post #2 of 86 Old 09-27-2012, 10:25 AM Thread Starter
Quoted: 70 Post(s)
Thanks for the orders everyone, these ship out same-day!
(314) 205-3033
post #3 of 86 Old 09-27-2012, 10:26 AM
whitelight's Avatar
PM to Canada T9E 8T2 please, love your guys products
whitelight is offline
post #4 of 86 Old 09-27-2012, 11:33 AM Thread Starter
Quoted: 70 Post(s)
PM sent!
-Paul
(314) 205-3033
post #5 of 86 Old 10-08-2012, 02:45 PM
pm price to 70114
NBKD16N is offline
post #6 of 86 Old 10-08-2012, 02:47 PM Thread Starter
Quoted: 70 Post(s)
Shipping to 70114 would be $5.00 and usually takes 2-3 business days.
Please let me know if you have any further questions!
(314) 205-3033
post #7 of 86 Old 10-08-2012, 02:51 PM
So $5.00 for the front two foot well lights?
NBKD16N is offline
post #8 of 86 Old 10-08-2012, 02:56 PM Thread Starter
Quoted: 70 Post(s)
For the footwell lights for single color it would be $19.99 each plus the $5.00.
Here is the direct link:
50cm 30-5050 SMD Strip - LED Strips - LED Bulbs
If you wish to go the mulitcolor lights with a standard remote: $59.99, with the upgraded remote: $69.99 plus the $5.00 shipping
Diode Dynamics Footwell LED Kit - LED Strips - LED Bulbs
(314) 205-3033
post #9 of 86 Old 11-12-2012, 07:47 AM
Cool! This is what I've been looking for. DD, is there enough wire in the kit to pull power from the over head dome light in the GC? And will the LEDs dim/fade with the dome lights? thx
Morphia32 is offline
post #10 of 86 Old 11-12-2012, 07:49 AM Thread Starter
Quoted: 70 Post(s)
The kit is designed to be installed with the cigarette lighter power. The kit requires 12V + and - so you can wire it in any configuration you would like, however, we do not recommend adding extra load to the dome light dimmer switch as it is a somewhat fragile component in most vehicles.
Thanks!
Paul
(314) 205-3033
post #11 of 86 Old 12-08-2012, 05:22 PM
Weirdo29's Avatar
Got mine installed.
Phone pic.
Only thing i had problems with was the switch. I drilled a 3/4 hole, but it wasn't big enough i had to file it out to make it fit. I put it here:
looks pretty stock especially with the blue light.
Weirdo29 is offline
post #12 of 86 Old 12-09-2012, 01:58 PM Thread Starter
Quoted: 70 Post(s)
It has to be a tight fit, so you do have to make sure you have it on there head-on. I usually just wiggle the bit a bit to get it just a hair bigger if it's too tight.
-Paul
(314) 205-3033
post #13 of 86 Old 12-09-2012, 05:09 PM
Weirdo29's Avatar
-Paul
Yeah that's why I just filed it.
Sent from my SAMSUNG-SGH-I717 using AutoGuide App
Weirdo29 is offline
post #14 of 86 Old 12-17-2012, 07:54 AM
RET_ARMY's Avatar
Thanks!
Paul
So I can install, and just plug it into the cigarette lighter power, or splice into that power?
2012 Gen Coupe 3.8T
R2C SRI, Magnaflow Cat Back Exhaust System
Varrstoen ES 2.2.2 Finish: Full Polish + Transparent Blue (Powder Coat)19x9.5+22F 19x10.5+22R Tires 245x35F &275x35R, Pro Line Vis Carbon Fiber Grill, GrimmSpeed Phenolic Thermal Intake Manifold Spacer,Diode Dynamics Stage 3 Lighting kit, and fuse box covers, Spyder LED Tail Lights – Black, Torque Solution Short Shifter, Sequence Diffuser Add-on, GTSPecc Strut Bar,Megan Coilovers,P2R - Throttle Body Spacer
Fayetteville, NC
RET_ARMY is offline
post #15 of 86 Old 12-17-2012, 08:02 AM Thread Starter
Quoted: 70 Post(s)
Yes, we recommend that you splice into the cigarette lighter power using the included connectors. Just two simple connections! Check out the vid for an example.
Thank you,
Paul
(314) 205-3033
post #16 of 86 Old 12-19-2012, 07:49 AM
Weirdo29's Avatar
Why does it only stobe in white? How can I get the advanced remote?
Weirdo29 is offline
post #17 of 86 Old 12-19-2012, 08:28 AM Thread Starter
Quoted: 70 Post(s)
That is the standard remote. The new upgraded RF remote can strobe in any color, in either a fast blink or full strobe.
RGB Multicolor Diode Dynamics Footwell LED Kit - LED Accent Kits - Specialty Lighting
(314) 205-3033
post #18 of 86 Old 01-03-2013, 09:59 PM
Gregd1805's Avatar
Pm shipped 93060
Gregd1805 is offline
post #19 of 86 Old 01-04-2013, 07:27 AM Thread Starter
Quoted: 70 Post(s)
Shipping is $5 for any order, so the kit would be $44.99 shipped.
Thank you!
Paul
(314) 205-3033
post #20 of 86 Old 01-12-2013, 01:49 PM
Hellfire5670's Avatar
Shipping was 10 to canada :P made my girlfriend order me a pair for my birthday on Tuesday and my new gen.. Whenever i get it. How long does ahippibg usually take to saskatchewan?
Sent from my SGH-I747M using AutoGuide.Com Free App
Proud owner of a beautiful black 13 2.0t genesis
Current mods
- resonator & cat delete[
Hellfire5670 is offline
Hyundai Genesis Coupe LED Conversion Kit! Upgrade your lighting! Easy Install! Diode Dynamics Diode Dynamics 236 02-17-2017 05:43 PM
Redout Tail light Vinyl Overlay Kit (easy to install) DSG Owner Exterior 47 07-20-2013 07:21 AM
FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!) Diode Dynamics Exterior 327 11-04-2011 01:51 PM
