FS: Switchback Turn Signal LEDs - AWESOME Mod! Ships same-day! - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 11-04-2011, 01:09 PM   #1
www.diodedynamics.com
Diode Dynamics's Avatar
Talking FS: Switchback Turn Signal LEDs - AWESOME Mod! Ships same-day!
1157 Dual-Color 60-1210 SMD
The 1157 Dual-Color 60-1210 SMD is a direct replacement for any 1157-size front turn signal bulb. This is a unique, specialty item. When on as normal, with parking lights, it shines a nice, pure white color, and when you activate the turn signals, it flashes an amber color. Two colors, for an awesome lighting effect!
Since our introduction of this item in 2010, we have sold over 800 bulbs to Genesis Coupe owners! Rest assured, this is a great mod that will work perfectly in your vehicle.
This bulb has 60 1210-size SMDs. It uses an 1157-size metal terminal and will fit as a replacement for stock halogen. It uses less power and heat than halogen bulbs, and will last longer, with its engineered heat-sinking technology. A load resistor is embedded to prevent blowing the LED from voltage surge, and a diode is implanted to protect the LED from reverse polarity. The LED is wired for 12v operation, the kind found on all vehicles.
Resistor Option: Some vehicles may have fast-blinking issues when LED bulbs are installed as turn signal replacements. We offer resistors to remedy this issue for a nominal charge. As an alternative to resistors, in some vehicles, you can fix the hyperblinking by replacing the Flasher Module. Since this is a plug-and-play fix, we recommend it whenever possible. The CF13 flasher module is the size needed in the Genesis Coupe.
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not jack up the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are made just for us by a company that has been in business since 1992, and every bulb carries with it a one-year full warranty.
This is the new for-sale thread. For feedback and reviews, please find the old thread here.
CLICK TO SEE MORE PICTURES AND TO ORDER
Leading Lighting Sponsor in the Hyundai Community
Best Sponsor 07, 08, NewTiburon.com
Platinum Rated Sponsor, CrookedH.com
Diode Dynamics is online now   Reply With Quote
Old 12-20-2011, 10:58 AM   #2
Where does the flasher module go?
killawhiterex is offline   Reply With Quote
Old 12-21-2011, 09:24 PM   #3
Replaces the stock one, under your steering wheel. It's the thing that clicks!
Old 01-12-2012, 01:38 PM   #4
Genesis Coupe FTW
Zhox's Avatar
Hey Paul I need a kit for my Hyundai tiburon 2003, only need 1 bulb with the relay, how much ??
2010 2.0T Premium 6M/T
:: SFR :: Sequence-X :: Diode Dynamics :: Superlux :: GCTuner :: M&S :: Injen :: Eibach ::
Zhox is offline   Reply With Quote
Old 01-13-2012, 05:50 PM   #5
PM sent!
Old 02-13-2012, 08:30 AM   #6
Generation's Avatar
So how fast is the blinking without putting in any flasher/resister kit and just straight replace the bulb on the headlights? Is it noticeable enough for a cop to pull me over with it? lol
also if I were to purchase this kit, what's the difference with the addon resister kit +$10 and the flasher CF13 +$5? would i need both? Or just one of the other?
thanks!
Nord Grey 3.8GT 6sp ZF
Generation is offline   Reply With Quote
Old 02-13-2012, 08:38 AM   #7
It's pretty darn fast. A cop wouldn't pull you over, but it's pretty annoying. You would just need one, you can read more about it here: Turn Signal LEDs, Hyperblinking Issues
Old 02-13-2012, 10:49 AM   #8
Generation's Avatar
So if I purchase a set of these switchbacks on your website, on the drop down box for the hyperblink fix i would select the flasher CF13 which cost additional $5 and that would all I be needing in order to fix the issue?
thanks!
Old 02-13-2012, 11:27 AM   #9
That is correct!
Old 02-24-2012, 06:49 AM   #10
I've left a couple of messages for you. Call me back when you get a chance please. My callback number begins with area code 662. I want to talk about my headlights and turn signals.
Boogra is offline   Reply With Quote
Old 02-24-2012, 11:30 AM   #11
Thanks, we'll get back to you ASAP!
Old 03-06-2012, 01:00 PM   #12
Rubyfox's Avatar
Just ordered these, along with the HID kit. Ordered 2 sets for 2 cars, but only one arrived in the box. Made one phone call, and they are going to ship me the other one out. Was great customer service, and its refreshing that the issue was resolved easily in what is just a minor mishap.
Just installed the other set on the other car, and wow these look great. The flasher kit is a must, as without it they do blink pretty fast. Glad I went ahead and ordered it with the bulb. Very pleased with the results on these.
Rubyfox is offline   Reply With Quote
Old 03-07-2012, 08:21 AM   #13
Thanks for the review, and sorry again for the packing error!
Old 03-14-2012, 04:35 PM   #14
syuusuke's Avatar
bought this after getting the complete stage 2 kit for interior lights. stage 2 had 1 bad led board and now this one has a bad led unit as well -_-, the white LEDs do not turn on for one of the units
the CF13 flasher did not fit in my 2012 genesis coupe either, if looking at it with the grounded prong sitting horizontally on the bottom, they need to be raised ever so slightly to fit correctly
syuusuke is offline   Reply With Quote
Old 03-15-2012, 02:34 PM   #15
These may have been damaged in shipment. Please email contact@diodedynamics.com with your name and order number as well as the problem, and we can help you out. Thanks!
Old 03-15-2012, 05:43 PM   #16
Here to Party!
JewishThunder's Avatar
Hey Paul I don't know if you just aren't seeing this or if you are ignoring it. The cf13 flasher modules don't fit our cars. You need the triton ep34 for correct fitment that solves the hyper blink.
Serena is home. As loud and black as ever.
JewishThunder is online now   Reply With Quote
Old 03-16-2012, 08:18 AM   #17
Our CF13 flasher fits just fine in the GenCoupe. I have personally done it a few times. Just push it in! Now for 2012, I am aware that the flasher model has changed.
Old 03-16-2012, 09:34 AM   #18
Rubyfox's Avatar
Well, the one that shipped with the LED's did not quite fit flush in the 2012. I would say that it only hangs out a bit. However it functions, and fixes the hyper blink issue. It just does not look "clean".
Old 03-16-2012, 01:23 PM   #19
Wide Open Ones
iMissLayups's Avatar
The flasher for my 2011 fits and works perfectly!
2011 Karussell White 3.8 Track A/T
Performance
Magnaflow Catback Exhaust | AEM CAI | Eibach Sportlines
Cosmetics
Sarona Grill | Spec-D Headlights | DD 6000k HID | DD Stage 2 LED | LED Foglights | Switchback LED Turn Signals
http://www.facebook.com/layupsphotography/
iMissLayups is offline   Reply With Quote
Old 03-16-2012, 09:14 PM   #20
I know it's not a 100% exact fit, but it's much cheaper than any other option, at just $5. I figured you guys would prefer to kind of push it in a bit rather than pay $10. Thanks!
THEY FINALLY WORK! "Switchback" LED Turn Signal Bulbs (video demo, SALE!!!) Diode Dynamics Exterior 214 11-04-2011 01:11 PM
FS: Rear Turn Signal and License Plate LEDs nobb Exterior 3 10-24-2011 07:51 AM
FS: "Switchback" Dual-Color LED Turn Signal Bulbs - ONLY $45 Diode Dynamics Exterior 128 03-05-2011 10:21 AM
Importshark switchback LEDs sLydFX Exterior 2008-2012 58 09-10-2010 06:25 AM
Plug-and-play FLASHERS available soon with turn signal LEDs Diode Dynamics Exterior 10 08-26-2010 09:14 AM
