DIY Replacing OEM hood vents with Real Hood vents for 2013+ - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 12-26-2012, 03:07 PM   #1
USEEDAT?
Default DIY Replacing OEM hood vents with Real Hood vents for 2013+
I plan to put up a DIY if there isn't already but first I need to know if there's a DIY thread for removing the clips that attach the head shield to the hood. I'm only used to the clips for removing the front bumper and these clips are different. I assume these might be easy to remove but didn't want to risk breaking one upon removal....
PetesSweets is offline   Reply With Quote
Old 12-26-2012, 10:15 PM   #2
USEEDAT?
No one has bothered to replace their vents?
Old 12-26-2012, 10:18 PM   #3
Turbo noob
SketchedOut's Avatar
ImportShark makes replacement vents
2013 Tsukuba Red 2.0T R-Spec
Eibach Pro-Springs
GrimmSpeed front plate relocation kit
XenonDepot Xtreme 6500K HID low beams
XenonDepot Xtreme 6500K HID fogs
Osram Night Breaker Plus high beams
Diode Dynamics full stage 2 LED kit
UniqPerformance strut bar
StopTech SST brake lines front & rear
Weir-Tech Evolve SRI
Weir-Tech Evolve charge piping
HKS SSQV BOV
SketchedOut is online now   Reply With Quote
Old 12-27-2012, 03:22 AM   #4
USEEDAT?
The ****? I already have the damn vents from import shark, I'm asking if anyone has bothered to show removal of the heat shield...the clips are not the same as other clips to such things as the air snorkel....your answer is irrelevant...
Old 12-27-2012, 04:33 AM   #5
Turbo noob
You didn't really clarify that. How was I supposed to know you had the vents sitting there? Next time be more clear. Maybe go into the hood vent thread and look for the guys that have said they installed them and PM them instead of making a irrelevant thread.
Sent from my iPhone using AutoGuide.com App
Eibach Pro-Springs
HKS SSQV BOV
Old 12-27-2012, 10:10 AM   #6
JWreck's Avatar
This is a DIY thread. Hopefully the mods can remove this post or move it so it doesn't junk up all the useful information here.
This should probably be posted in External or General until a DIY is made.
2013 3.8 GT A/T | Gran Premio Gray
6000k HID | LED Stage 2 Fogs | Full Interior LED Conversion
K&N Drop In Filter
JWreck is offline   Reply With Quote
Old 12-28-2012, 03:23 AM   #7
USEEDAT?
It was to be a DIY but seems no one here had viable feedback in order to process the DIY. Thankfully the vendor helped me out when no members on here did. Installing them tomorrow with pictures
Old 01-06-2013, 03:54 PM   #8
The point of posting a DIY thread is to offer a DIY to fellow members...not to ask for instructions. Had your tone of voice been more polite, you would have received polite responses as well.
2012 Genesis Coupe 2.0T NG premium auto
- Wingsssssss
- Magnaflow catback exhaust
- K&N Typhoon SRI
- OEM GT strut bar
- BBM lip spoiler
- Spacers: 20F & 25R (UNIQ Performance)
- Diode Dynamics 4300K low beam HIDs
- Diode Dynamics 7.5W fog light LEDs
- LED footwell lighting
- Formula 1 Pinnacle 30% ceramic tint all around
tapan is offline   Reply With Quote
Old 01-06-2013, 03:58 PM   #9
13gencoupe's Avatar
....theres at least 4 threads already about this....
Edited due to OP prob having sensitive feelings
Sent from my DROID3 using AutoGuide.Com Free App
13gencoupe is offline   Reply With Quote
Old 01-07-2013, 01:30 AM   #10
USEEDAT?
I was finally able to find them after some free time searching through threads, was able to get heat shield off but the hood vents from Import Shark do not fit because or the mesh that is basically just glued to the back of the vents....is too large an doesn't sit flush in its placement.
Home-Made 2013 Functional Hood Vents NJtricker609 Exterior 2013 and up 119 04-18-2013 12:01 PM
Are you waiting for the IS hood vents too? 13gencoupe Exterior 2013 and up 4 10-22-2012 11:02 AM
2013 hood/vents for a 2011? ROIDMONKEY Exterior 2008-2012 4 08-25-2012 08:26 AM
Part number for the hood vents? 2Cool Exterior 2013 and up 6 07-28-2012 03:59 AM
Hood Vents burks95 Exterior 2008-2012 5 11-28-2011 09:31 PM
