Power on Nexus 7 without pressing the power button! (No Kernel required) - Genesis Forum: GenCoupe Hyundai Genesis Forums
#1 Old 04-28-2013, 12:47 AM
DISCLAIMER: I am not held responsible for anything that might go wrong with the installation of this mod OR any damage to user data/files.
Having a tablet mod is cool but what if your tablet battery is drained out and you have to open the bezel to press the power button? This mod will automatically turn on your tablet as soon as it's plugged in to charge. There is no need to drill your bezel to create an external power button.
Default behaviour while charging (device in power off state): Charging only
New behaviour while charging (device in power off state): Power on to your home screen!
This mod requires you to unlock your bootloader (WARNING!!! - you will lose all your data when you unlock your bootloader. I am not sure if this mod will work on a locked bootloader - but try it out BEFORE unlocking your bootloader)
Steps to unlock your bootloader (steps for PC/MAC included):
1) Download R3Superboot.zip by clicking on the following link:
https://dl.dropbox.com/u/25213603/r3superboot.zip
2) Extract R3Superboot.zip to a convenient location. For this guide, I am going to extract it to my Desktop. Once extracted, RENAME the folder to R3Superboot (not necessary but makes it easier to open it up in step # 6)
3) Enable USB Debugging on your Nexus 7
- Go to Settings --> About tablet
- Tap "Build Number" 7 times
- There should now be a "Developer Options" in your main settings menu
- Go to Developer Options and check USB Debugging
4) Connect your tablet to your PC/Mac and power off your tablet
5) Press and hold Power + Vol Down button until you get to the bootloader screen (with the Android logo)
6) Now open Command Prompt (PC) OR Terminal (Mac)
PC - Command Prompt (go to your R3superboot directory). Type the following:
cd desktop (hit enter)
cd R3Superboot (hit enter)
Mac - Terminal (go to your R3superboot directory). Type the following:
7) Now it's time to unlock the bootloader. Type the following and hit enter
PC: fastboot oem unlock
Mac: ./fastboot-mac oem unlock
You will be presented with the following two options:
Yes - Unlock Bootloader
No - Don't Unlock Bootloader
By default, it should automatically be selected to "YES". Simply hit the POWER button ONCE and wait for a few seconds until it says "DONE" on the top left side of the screen
8) Now it's time to tell the tablet to turn the device on when the charger is plugged in
PC: fastboot oem off-mode-charge 0
Mac: ./fastboot-mac oem off-mode-charge 0
***If you ever want to return to the original set up (tablet stays off while device is charging in a power off state), simply replace the "0" with "1"
i.e.
THAT'S IT!!! Now reboot your tablet and test it out!
Enjoy and do this mod at your own risk!
2012 Genesis Coupe 2.0T NG premium auto
- Wingsssssss
- Magnaflow catback exhaust
- K&N Typhoon SRI
- OEM GT strut bar
- BBM lip spoiler
- Nexus 7
- Spacers: 20F & 25R (UNIQ Performance)
- Diode Dynamics 6000K low beam HIDs
- Diode Dynamics 7.5W fog light LEDs
- LED footwell lighting
- Formula 1 Pinnacle 30% ceramic tint all around
tapan is online now
#2 Old 04-28-2013, 07:27 PM
Photogineer
KAIJU's Avatar
You sir, are a life saver!
Will this work on the Acer Iconia Tablets?
W: momentsmedia.ca
FB: facebook.com/momentsmedia
KAIJU is offline
#3 Old 04-28-2013, 07:31 PM
Not sure man - but DON'T try it on your Iconia lol...i will look it up tomorrow. I am sure there is a similar software mod for the Iconia
- Wingsssssss
- K&N Typhoon SRI
- OEM GT strut bar
- BBM lip spoiler
- Nexus 7
tapan is online now
#4 Old 06-06-2013, 11:12 AM
This work on every tablet that use android? what version of android are you running?
XVEGANX is offline
#5 Old 06-08-2013, 11:38 PM
I am pretty sure this is specific to the Nexus 7 only. I am not sure how other tablets' bootloaders are configured but DO NOT attempt this on any other tablet. You could end up with a bricked tablet.
I am running 4.1.2 on my Nexus 7.
- Wingsssssss
- K&N Typhoon SRI
- OEM GT strut bar
- BBM lip spoiler
- Nexus 7
tapan is online now
#6 Old 08-01-2013, 01:24 PM
jhwan90's Avatar
will this work on the new nexus 7 2nd gen?
'11 Kraussell White 2.0T
Cosmetic :
Superlux Taillight, Customized Headlight by ElStig Garage ,
6000k HID, OEM Foglight, Powerfolding side mirror,
OEM spoiler, Matte Black Wing Emblem, BTRcc Roof Wrap,
VIS AMS CF hood, F20mm & R25mm GarageLine spacers
Interior :
DiodeDynamics stage 4 LED ,
New Google Nexus 2nd gen installed w Type B bezel,
hardwired Escort Passport MAX
Enginge :
cp-e full Turboback Exhaust,
InJen Cold Air Intake, HKS BOV,
BTRcc Custom Tuned
jhwan90 is offline
#7 Old 08-01-2013, 02:03 PM
There is a fairly good chance it won't work.
Gorethox is offline
#8 Old 08-01-2013, 06:14 PM
unce unce unce
D!RTYLOUD's Avatar
Quoted: 21 Post(s)
Someone be a guinea pig and try it on the iconia so i know the outcome :P
Also someone try it without unlocking their bootloader ha.
I would REAAAALLLY love to have this mod on my Acer Iconia A100
nonetheless,
Very cool mod!
- 13' Front End Conversion
D!RTYLOUD is online now
#9 Old 08-30-2013, 04:21 AM
that guy
kepone's Avatar
Hey i've got a Nexus 7 1st gen, on 4.3 already unlocked and rooted using Wugs toolkit. Can I just follow your instructions, and ignore all the parts relevant to unlocking and rooting ( since that is already done ) to get this usb mod done?
'12 2.0T 6SP Base- 320whp, 320wtq
Kinugawa TD05-20G +Antisurge Cover+ Billet wheel
Bosch 750CC
Tuned by BTRcc, 1:1
TXS SRI, FMIC, RFL BOV Racepipe, RSD Cat Back
Grimmspeed MBC, Phenolic Spacer, Ported Exh+Int. Mani
ARP Turbo Studs
P2R TB Spacer+Thermal Gaskets
GL STS + ATQ Bushings
CC Stage 2 kit
Saikou Michi Catch Cans
Eibach FSB/RSB
PSM Pro Coilovers +RLCA
MOOG Endlinks
Nexus 7 dash install
kepone is online now
#10 Old 08-30-2013, 05:37 AM
Cece's Daddy
ShaverZBT's Avatar
If you have rooted your tablet, you should be able to install any ROM that will work with the N7. There is a genius on youtube I follow regularly who knows how to root just about anything. Here is his website: AndroidRoot.org - Android Rooting Video Tutorials In the search box, just type Nexus 7. Good luck!
ShaverZBT
SOLD
2012 Genesis Coupe 200T
Bathurst Black | Wing Emblems | K&N Drop-in | Niche Targa M130 19" Rims
Nexus 7 2nd Gen Tablet | iPod Nano 8GB | Tint 15R/20F
ShaverZBT is offline
#11 Old 11-13-2013, 01:22 PM
240SX turned GC
s3t0_S13's Avatar
subbed to check later. any update on a acer a100?
Competition Clutch
HKS
K
&N
M&S
ABS Dynamic
ARK
AGP
Superlux
Btrcc
PowerAXEL
Magnaflow
s3t0_S13 is offline
#12 Old 05-04-2014, 11:27 AM
Newbie
Hyundave's Avatar
This is awesome!! Definitely a needed solution for those installs
2011 Black Genesis Coupe 2.0T Premium Current
- 6000k HID headlights
- Wing Emblems
- Switchback Turn Signals
- Switchback Fog Lights
2008 Gray Elantra SE Incus Kit Sold
Hyundave is offline
#13 Old 05-08-2014, 05:49 AM
zeaux's Avatar
Link for R3Superboot.zip is dead?
Black Noir Pearl 2.0T Base MT from White Satin Pearl 2.0T Base AT
zeaux is offline
#14 Old 05-14-2014, 02:02 AM
reupload pls
hajaa is offline
#15 Old 05-15-2014, 05:29 PM
Insert Klever Title Here
38special's Avatar
Any chance there is a command prompt for shutting down the tablet when device is on and not in a charging state? Basically to get the tablet to auto shutdown when the car is powered off
History
1990 EF Hatch - Sold
2002 Civic EX - RIP (Katrina Victim)
2005 Corolla - Sold
2000 Civic Si - Sold
1991 MK3 Supra - Sold
2010 MB Genesis 3.8 GT 6MT - New Daily
1989 MK3 Supra - New Project
**38special's Other Car Build Thread**
http://www.gencoupe.com/other-vehicle-discussion/130757-38specials-other-car-build-thread.html
"I am always doing that which I can not do, in order that I may learn how to do it." -Pablo Picaso
38special is offline
#16 Old 05-16-2014, 10:41 AM
RedGen13's Avatar
Use Tasker or Automateit is a very easy way to do this. There are roms that are made specifically for this, the 2012 Nexus 7 has UsbRom which has many of these setting built into it. You probably wont want to fully shut it down though because then you have to wait for it to start up every time. It is better to just have it go to airplane mode + shut the screen off on power loss, and screen on + airplane mode off when power is restored.
'13 2.0T R-Spec
'99 Eclipse Fully Built
RedGen13 is offline
#17 Old 05-16-2014, 11:41 AM
38special's Avatar
I installed Tasker and set it up to shutdown when I disconnect BT. It takes less than a minute to fully load up from a powered off state, which is less time than it takes me to get situated and pull out of my driveway lol
History
2005 Corolla - Sold
#18 Old 05-16-2014, 11:49 AM
RedGen13's Avatar
I had it that way too, with the same thought process. Eventually it got really annoying to me for when I would need to run into the store quickly and make several smaller trips. It feels more OEM to have it boot up instantly so I went that route.Having it go into deep sleep worked better for what I was looking for. I can have it sit idle in deep sleep mode without starting the car for over a month and the battery still wont be dead
'13 2.0T R-Spec
RedGen13 is offline
#19 Old 05-16-2014, 02:39 PM
zeaux's Avatar
Waiting for Timur's Kernel for Nexus 7 2013 to be released for the fast charging in order to avoid having to shutdown everytime car is turned off
zeaux is offline
#20 Old 05-28-2014, 08:29 PM
Hi all...very sorry for the late reply. I haven't logged in a while and have been lurking this whole time lol...
I just reuploaded R3Superboot.zip and the link follows:
https://dl.dropboxusercontent.com/u/...3superboot.zip
DISCLAIMER: This bootloader unlocking method was previously attempted on 4.2 jellybean so I am not sure if it will work on 4.4+ kitkat versions. WARNING: Unlocking your bootloader will most likely erase all of your data. BACKUP everything before attempting to do this!!!
Do this at your own risk. I will not be held responsible for anything that might go wrong!
- Wingsssssss
- K&N Typhoon SRI
- OEM GT strut bar
- BBM lip spoiler
- Nexus 7
tapan is online now
Toyota Modifies Power Button for Easier Shutoff AutoGuide.com AutoGuide.Com News 0 01-07-2013 12:00 PM
How Finevu/Blackvue Power Kit/Power Magic Pro work - Parking Mode Alex@BBMC Ontario 0 09-04-2012 11:24 AM
Ford Power Stroke Diesel to Power Joint Light Tactical Vehicle AutoGuide.com AutoGuide.Com News 0 03-27-2012 11:40 AM
