Rattle or creak fix - Page 2 - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 05-15-2009, 10:04 AM   #21
silverstone's Avatar
I ruled the seat belt out by driving with it tucked into the seat and still experienced the under the seat noise.
Thanks for you reply.
silverstone is offline   Reply With Quote
Old 05-16-2009, 07:31 AM   #22
KDM is my religion
gencoupe10's Avatar
i tried lol
2.0T Premium Mirabeau Blue
"the best engine in the world is the vagina. It can be started with one finger, it is self-lubricating, it takes any size piston and it changes its own oil every four weeks. It is only a pity that the management system is so F**cking temperamental"
gencoupe10 is offline   Reply With Quote
Old 05-19-2009, 12:07 AM   #23
I knew I wasn't crazy!
You think the clunk is the same as the rattle?
3.8 6MT Tuksuba Red
bubba is offline   Reply With Quote
Old 05-19-2009, 12:26 AM   #24
Alberta Genesis Club
dogstar's Avatar
I think the rattle is caused by something (wire/cable or hose) that runs inside the C pillar. If you remove the interior plastic C pillar cover, right up near the edge of the headliner you can see the backside of a little clip pressed through from the inside of the pillar. I think whatever that clip is supposed to be holding is what makes the rattle, but I can't see or feel anything that comes out of the C pillar at the bottom which could be the culprit. Eventually I'll probably take the headliner off and try to find it, but with the neoprene in there I can only barely hear it when I concentrate on it so it hasn't been bothering me.
The clunk/crack sounds like a suspension thing to me, maybe a spring is shifting in it's perch and binding a little. It's pretty infrequent on my car so it's going to be a real bear to find and cure, but it doesn't bother me that much.
dogstar is offline   Reply With Quote
Old 05-19-2009, 09:25 AM   #25
Whatever it is I've made an apointment for Friday to take it into the dealer. I don't have the time or patience to fix it myself.
3.8 6MT Tuksuba Red
Old 05-19-2009, 12:15 PM   #26
dogstar's Avatar
Hopefully they can find it, it took me several hours. Feel free to use my description and info if they need help finding it.
Old 05-23-2009, 07:32 AM   #27
Keep the rubber side down
BFHK's Avatar
I have found mine to creak also coming from the passenger rear quarter panel. Mainly heard just driving down the road as I hit bumps (more prevalent at low speed) but you can really hear it as that corner wheel comes off a raised curb (ie leaving a parking lot or driveway). The service tech at the dealer thought at first I was hearing the seatbelts hitting interior panels but I had already discounted that as the source by buckling all 3 unused belts while driving. It's best described as a popping sound and from the pics dogstar posted this looks like the most logical source. I haven't removed the back seat to get at it yet but will be doing something about it soon. It's like fingernails on a chalkboard to me! However I've found as it's becoming more humid the noise is becoming less frequent. Which only means as it gets cold again in the fall it will get worse. Hopefully Hyundai will acknowledge the issue and release a bulletin to the dealers on a fix.
Big thanks btw to dogstar! With your photos and this thread I was able to convince my service tech that I'm not crazy.
BFHK is offline   Reply With Quote
Old 09-29-2009, 06:02 AM   #28
americankommie's Avatar
There is a TSB on hmaservice.com for this now.
09-BD-012 INNER QUARTER PANEL CREAK/TICK NOISE
http://hmaservice.com/files/331/5002922/09-BD-012.pdf
DESCRIPTION:
CONDITION
Some Genesis Coupe vehicles may exhibit a creak and/or ticking type noise from the
rear when the vehicle is driven on uneven or rough roads.
CAUSE
Contact between the inner surface of the quarter outer panel and the quarter inner
panel.
REPAIR
Remove body panel reinforcement (BPR) sealer from the contact areas between the
panels and apply urethane adhesive and under coating to the affected area.
APPLICABLE VEHICLES:
Model: Genesis Coupe (BK)
Applicable Vehicle Production Date Range: December 16, 2008 through February 23,
2009.
3.8 Base - Lime Rock Green
americankommie is offline   Reply With Quote
Old 09-29-2009, 06:31 AM   #29
Genesis Coupe FTW
Zhox's Avatar
Dont have any noise.... even the seat belt dont flap ...
2010 2.0T Premium 6M/T
:: SFR :: Sequence-X :: Diode Dynamics :: Superlux :: GCTuner :: M&S :: Injen :: Eibach ::
Zhox is offline   Reply With Quote
Old 09-29-2009, 08:14 AM   #30
My drivers seat was creaking all the time on bumpy roads. So I took it to the dealer and they are replacing the seat track. I hate them having my coupe. They had to order the track so it won't fixed until tomorrow. The better not be out joy ridding in my car!! I know the mileage.
quickstang1 is offline   Reply With Quote
Old 09-29-2009, 08:35 AM   #31
dogstar's Avatar
DESCRIPTION:
CONDITION
CAUSE
panel.
REPAIR
2009.
Great news, thank you!
Old 09-29-2009, 08:46 AM   #32
Only creek/rattle I get, comes from the junk I leave in the cup holder
AKGC is online now   Reply With Quote
Old 09-30-2009, 12:19 PM   #33
FlesHBoX's Avatar
I added the above post as a link in the Common Issues sticky with the link to the TSB PDF
..: J e s s e :..
Easy like Hyundai morning.
http://www.pshift-stormrage.com/jess...es/wow/syl.png
Sylani <Paradigm Shift> Stormrage-US
FlesHBoX is offline   Reply With Quote
Old 09-30-2009, 03:00 PM   #34
JL380GT's Avatar
Only minor creak I had was coming from the rear-view mirror. Got rid of it, by pinching the squarish plastic cover that connects the mirror to the windshield.
Nords Grey 3.8GT (CDN) 6MT
JL380GT is offline   Reply With Quote
Old 09-30-2009, 11:39 PM   #35
It is not red. Not red..
satheian's Avatar
How did you pinch it? just with fingers? How hard?
http://www.gencoupe.com/general-discussion/56608-north-american-genesis-coupe-meet.html
http://www.williamworley.com/nitrogen.php
Originally Posted by 2.0T Mirabeau: I am beginning to wonder about almost all these Vendors..
Genracer~Tom@G&M~Grimmspeed~Beyond Redline
Have had NO complaints to my knowledge.
~Havoc - new, but desperate to keep their Customer Service name 100%
~Diode Dynamics - Paul always takes care of his customers
These are vendors I recommend. PM me if you think differently.
satheian is offline   Reply With Quote
Old 10-01-2009, 05:58 AM   #36
JL380GT's Avatar
More of a fluke really. While I was driving I was just trying to figure out what the hell was creaking so much by putting some light pressure on the plastic.
All I did was pinch (using the thumb and index finger) up and down the length of that squarish piece and then it stopped.
Old 11-09-2010, 10:30 AM   #37
Did replacing the track fix this issue? I have a new 2011 and I can hear some ticking coming from the drivers seat as well.
shudon is offline   Reply With Quote
Old 11-09-2010, 11:02 AM   #38
Eh Hee
dic51's Avatar
+1. I have a very annoying squeak coming from my driver's seat. Every time I accellerate and over bumps. It's not a click or pop. It's a squeak as tho the seat can't handle my heftiness. Had the technician check it last time I had the car in the shop but I outweigh him by 100lbs, lol. He's a little guy.
To the OP. This may be a different noise than what you are refering to but I had a popping coming from the rear when I turned the stereo up. Come to find out after poking around it was the rear deck cover piece smacking against the window and then against the rear deck. I removed the deck cover and stuffed the space between with acoustic foam to cut down on movement. It all but resolved the issue and also gave the OEM sub a more solid sound.
dic51 is online now   Reply With Quote
Old 11-09-2010, 12:11 PM   #39
Sounds similar to my problem. If you just sit in the seat and push back or to the sides sometimes I can get the noise to happen so I know its a seat issue. Mine's brand new though so I'm giving it a little while to break in since it kinda just sounds like plastic flexing or something to that effect.
Old 01-31-2011, 06:50 AM   #40
I am having this exact problem. I hear it all the time now. Even when I get in just to sit in the car it'll creak. Very loud when I accelerate as my body's weight and gravity cause the seat to creak. What can I do to remedy this? I want to know before I take it to my dealer. It's driving me nuts...
2010 HYUNDAI GENESIS COUPE SOLD
| KARUSSEL WHITE - 3.8 TRACK - 6MT - FLOWMASTER EXHAUST |
2012 BMW M3 COUPE
| ALPINE WHITE/FOX RED - 4.0 V8 - 6MT - COMPETITION PKG - DINAN TUNE |
2001 JEEP WRANGLER TJ
| STONE WHITE - 4.0 I6 - 5MT - SAHARA EDITION |
Ghetto2315 is offline   Reply With Quote
