How to - replace rear speakers - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 10-04-2009, 06:31 PM   #1
Default How to - replace rear speakers
Some of you have already done this, but for those that are thinking about and haven't done it yet, this might help. I've got lots of nice pics, but the post counter won't let me post them yet. I'll edit it later when my post count is higher.
(Use at your own risk. This probably voids some portion of your warranty, and you'll be working near some air bag wiring, so you may want to remove the negative battery cable as a precaution.)
Also, I have a base 3.8. I'd guess the GT or track might be slightly different.
Step 1:
Get the tools and stuff you'll need:
10 mm socket, extension, ratchet, soldering gun, solder, wire cutters, pair of gloves, plus the new speakers. I used Pioneer TS-G1642Rs, but I think most 4 ohm 6-1/2" would work.
The OEM speakers are just 6-1/2 cones (no tweeter) and there only rated for 20W nominal (read cheap). I wanted more efficient, higher wattage speakers with a tweeter and the Pioneers were only about 50 bucks. Whatever you buy, make sure it's 4 ohms impedance (most are).
If you follow my mounting scheme, you'll also need (8) #8 x 1" machine screws, (4) for each side.
Step 2:
I'd put on a pair of sweats instead of jeans to avoid having the rivets scratch up your seats or plastic.
Start with the left (driver's) side:
Step 3:
Open the left door and pull off the left sill plate. It's not held in my any screws, just tabs. Seems easier if you start at the back and pull straight up.
Step 4:
Starting at about half-way up the back of the left door frame and working down, pull off about 3 feet of the weather strip. The idea is to free up the front edge of the rear left cover. The speaker is behind the left rear cover and the only way to get to it is to remove the cover.
Step 5:
Remove the left C-pillar cover (the cover above the truck deck on the left (driver's) side of the car). To do this, pry out the small circular cover in the middle of the C-pillar cover using your finger nail. Next, using a 10 mm socket, extension and ratchet, remove the single retaining bolt, and pull off the C-pillar cover (gently). Several tabs hold it in place in addition to the screw you removed.
Step 6:
Fold the seat down, and remove the two plastic screws in the left rear cover that are now exposed.
Step 7:
Now that you have the weather strip off, the C-pillar cover off, and the two screws out, the only thing holding the left rear cover on is clips. Carefully pull the cover away from the quaterpanel, popping off the clips in the process. Once the cover is off, you'll see the speaker mounted to the left quarter panel.
Step 8:
Unplug the speaker, remove the (4) bolts that hold it to the car using the 10mm socket, extension and ratchet, and take the whole assembly inside.
Step 9:
Next remove the (4) Phillips screws that hold the speaker retaining ring in place, and CAREFULLY pry the retaining ring from the speaker. Be careful not to rip the old speaker if you ever plan on using it again.
Step 10:
Unsnap the speaker wire harness (plug and about 2" of cable), and cut it from the OEM speaker. Cut right at the speaker leaving yourself as much wire as possible.
Step 11:
The Pioneer's don't have the same sheet metal lip that the original speakers do, so the retaining ring will sit about .060" higher with the new speakers. The interior cover will still fit over them, but the (4) sheet metal screws may not be long enough to hold the speaker in firmly. Plus, the OEM speaker bracket holes are just the right size to accept a #8-32 tap.
Tap each of the four holes in the speaker mounting bracket with a #8-32 tap.
Step 12:
Assemble the new speaker, mounting bracket and retaining ring with your (4) #8-32 screws. The retaining ring only goes on one way, but the speaker will go on @0, 90, 180 and 270 degrees. Only one of these positions will allow the short wiring harness you have to reach. Position the speaker so the short wire harness you have will fit.
Step 13:
Snap the plug of the wire harness back into the speaker bracket, and solder the two wires to the speaker, red to (+) and black to (-). It's much easier to do this if you assemble the whole thing, and solder last. Be careful not to drop hot solder on to the back of the speaker cone.
Step 14:
Reassembly: Mount the speaker assembly in the car with the (4) bolts, plug it in and make sure it works. Put the left rear cover on, install the two plastic bolts, install the C-pillar cover, and install the weather strip and the door sill.
Step 15:
Repeat for right side.
Like I said - pictures coming later.
I like the sound much better. Rear speakers used to sound very flat. Now they sound better than the front.
Hope this helps.
John
JohnPawlak is offline   Reply With Quote Quick reply to this message
Old 10-04-2009, 06:47 PM   #2
I haz no GC no mo :(
CrookedH's Avatar
Nice write up, thanks for taking the time to put it together.
  • Detailed title of item
  • Asking price
  • Actual Photos of the item
CrookedH is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 06:43 AM   #3
Token Metro Guy
brandon1987's Avatar
Added to the how-to sicky.
--CurrentCar--
(Canadian Spec)
Carbon Filter Removed - 7000K High Beams/DRLs - 20% Tint - M&S Type D Grille - Black Vinyl Roof Overlay - Carbon Wrapped Console - BBM Lip Spoiler
--Previous Cars--
2005 Acura RSX Premium
2000 BMW 323i
1988 Toyota Supra Turbo
brandon1987 is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 07:22 AM   #4
Track Rat
Gamz's Avatar
Nice write up.
Gamz is offline   Reply With Quote Quick reply to this message
Old 10-07-2009, 11:13 AM   #5
coupster's Avatar
all we need now are pix. great write up btw.
Genesis Coupe2.0T Rspec in waiting
coupster is offline   Reply With Quote Quick reply to this message
Old 07-17-2010, 12:41 PM   #6
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
thanks for the write up, ever get those pictures?
Genesis 200Turbo - Mirabeau Blue - 206whp/239wtq not tuned.
Subscribe for my latest reviews and how-to's!
Need help? Ask here!
Follow Project Woodstock for some awesome GC goodness
Buy my stuff!
^links, just click them
Proudly supported by:
Snoopy0812 is offline   Reply With Quote Quick reply to this message
Old 01-14-2011, 05:41 PM   #7
AMB~1YR
Moley's Avatar
Stock speaker
Stock speaker size ( 6.5" )
Stock speaker wattage
New Kicker 6.5" Coaxial
What a difference in sound qualitly and volume!
2010 2.0T BASE A/T AMB
Moley is online now   Reply With Quote Quick reply to this message
Old 11-27-2011, 02:42 AM   #8
Thanks for DIY, im looking for these info to upgrade my car sound.
Does your base model come with infinite system?
Coupe380 is offline   Reply With Quote Quick reply to this message
Old 11-27-2011, 07:54 AM   #9
Stephenk291's Avatar
no the base model doesn't have the infinity sound system. You'd see an amp in the photo next to the speaker on the passenger side.
2011 Silverstone 3.8
Sold!
2013 G37s
wife has 2013 Sonata 2.0T limited.
Stephenk291 is offline   Reply With Quote Quick reply to this message
Old 11-27-2011, 08:48 AM   #10
believe me, you're not missing anything!
tom49 is offline   Reply With Quote Quick reply to this message
Old 11-27-2011, 06:22 PM   #11
AMB~1YR
Moley's Avatar
@Coupe380. What type of speakers are you planning on using? I replaced the Kickers with Alpine Type S after a few weeks. I found the Kickers were loud but too shrilly because of the Titanium tweeter. The Alpines use silk dome tweeters and sound so much better. Not quite as loud though but I would rather have clear, rich sound over volume.
Old 11-27-2011, 06:36 PM   #12
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
I was wondering about those Kickers, you seem like more of a quality orientated kind of guy over sheer volume.
I've been saving up for some Macroms, they're outstanding for quality and volume.
Buy my stuff!
Old 11-27-2011, 06:42 PM   #13
AMB~1YR
Moley's Avatar
I am both. I like it loud as I can get it but it still has to sound good. The Kickers were great at medium volume but when cranked the tweeter took over. I was looking for efficiency when I bought them as I didn't have an amp yet but soon discovered that metal tweets in the rear weren't for me.
I have never heard of Macrom. They look nice though.
Macrom Car Audio and Entertainment
Old 11-27-2011, 06:48 PM   #14
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
When I worked for an electronics shop the rep came around to promote the speakers and brought a truck that would have done well in a SPL competition, it was insane.
Buy my stuff!
Old 11-30-2011, 01:03 AM   #15
I was planning to get Alpine speakers, but since i already Infinity system in my car so i dont know which one is better. I dont want to waste money to buy if they sound the same or worst. So any advice is appreciate .
Im new to these car audio sound, here are the questions if anyone have any advice or recommend to help me out:
1. For speakers, what is the best brand to have?
2. What is the best brand for amps?
3. What is the best brand to use for sub?
All i want are clear and loud sound, with some bass
Thanks in advance..
Old 11-30-2011, 08:16 AM   #16
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
The infinity speakers in this car are near the bottom of the brands range.. they're not that great. Most likely your alpine's will be better.. since I think the base model speakers are better.
Buy my stuff!
Old 11-30-2011, 04:14 PM   #17
What name is good for subwoofer?
Old 11-30-2011, 04:44 PM   #18
BreezyBree11's Avatar
Very helpful thanks !
LIVE.LAUGH.LOVE...I do it all in my Genesis
BreezyBree11 is offline   Reply With Quote Quick reply to this message
Old 11-30-2011, 05:57 PM   #19
AMB~1YR
Moley's Avatar
Kicker Solo X
Orion HCCA
Re Audio
TC Sounds
DC Audio
Audioque
Massive Audio
Alpine Type R
I could go on and on. These are some top brand names. There are so many. If you a looking for bang for the buck then go Alpine Type R imo.
Old 11-30-2011, 09:20 PM   #20
JL is better than alpine?
Powered by vBulletin® Copyright ©2000 - 2014, vBulletin Solutions, Inc.
