DIY guide to installing Track Rotors - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 04-23-2010, 12:10 PM   #1
Site Sponsor
Default DIY guide to installing Track Rotors
I've just finished the first guide, the fronts. I'll get the rear finished up and add it to this first post.
Here's the PDF download that you can just print out if you are doing the install and want it for reference:
Front Rotor Install Guide
Rear Rotor Install Guide
Here are the Specs from HMA service that I made into PDF as well.
http://www.gctuner.com/diy/GENESIS C...ACK SPECS1.pdf
http://www.gctuner.com/diy/GENESIS C...ACK SPECS2.pdf
And here are the .jpg versions of the pages. Enjoy:
GCtuner Chris is offline   Reply With Quote
Old 04-23-2010, 12:24 PM   #2
Car is for sale
Slider's Avatar
Thread added to http://www.gencoupe.com/wheels-tires...-stickies.html.
Mirabeau Blue Genesis Coupe 3.8 GT
Volk Racing | Stance | Seibon | M&S | Sequence | Injen | Blox Racing
Slider is offline   Reply With Quote
Old 04-23-2010, 12:29 PM   #3
Finesse Is Everything
CaptainSlow's Avatar
Great Write Up! Nominate for Sticky
Slowest Gencoupe Driver in The North East
"You know those dot matrix on the M5....I was in my mates kitchen drying my underpants in the microwave and when it had finished it said "enjoy your meal" -James May
CaptainSlow is offline   Reply With Quote
Old 04-23-2010, 02:28 PM   #4
F19x9ET-10 R19x10ET-20
sLydFX's Avatar
^+1!!!
sLydFX is offline   Reply With Quote
Old 04-23-2010, 02:39 PM   #5
特味! 특미 special flavah!
eclee's Avatar
I love DIY~~^^ +11
Nord Grey 2.0T-> dead...
Waiting for 2012 gencoupe.....
eclee is offline   Reply With Quote
Old 04-23-2010, 02:52 PM   #6
Site Sponsor
Finally finished. Man I thought taking the time to snap the pics during my install was a bitch, until I started on the writeup, lol.
Old 04-23-2010, 08:16 PM   #7
Breast Examiner
HotLZGT's Avatar
Chris, Are these rotors available to us bottomfeeders that don't have Bremo's?
Would the install be pretty much the same?
When you say install calipers and make sure the pads are pushed all the way to the side,
can this be done by hand or does the piston push the pads together making it difficult to
push them back?
Great DIY, Stuff sells better when we can see how easy it is to install.
Whatever blows your skirt up!
Ship High In Transit
HotLZGT is offline   Reply With Quote
Old 04-24-2010, 05:54 AM   #8
Fly, Eva, Fly!
WildBill's Avatar
push them back?
You should be able to do it by hand. All your doing is recessing the piston by applying enough force to force the hydraulic fluid back through the line. Also, yes, they do carry the same rotors for the non-brembos. Just shoot him a PM.
Bill
Senior Member of the Genesis Coupe High Mileage Club - 122,000 Miles and Counting
*Over 100,000 miles tuned by Jay @ SFR*
WildBill is offline   Reply With Quote
Old 04-24-2010, 08:06 AM   #9
Use the F'n Search Button
mmrp81's Avatar
great DIY.
mmrp81 is offline   Reply With Quote
Old 04-24-2010, 09:49 AM   #10
Mad Scientist
Nobody's Avatar
beautiful write up!
Nobody is offline   Reply With Quote
Old 04-24-2010, 08:08 PM   #11
Boost Addict
Projectx7's Avatar
Great write up guys!
Beyond Redline Tuned
Projectx7 is online now   Reply With Quote
Old 05-02-2010, 05:11 PM   #12
Breast Examiner
HotLZGT's Avatar
Great DIY Chris. I can hardly wait for mine to arrive. I took off all wheels to see if there might be any issues. The hardest part was breaking the philips screws loose without stripping them. I got a big philips (she likes that) with a rubber grip and tapped it in a little with a hammer and was able to break all 8 free. I also broke the bottom rear caliper bolt loose with a round hex wrench and a mallet so that will be ok also. You can remove that bolt without a rachet - slower!
If you jack the rear up and put stands on both sides at the jack points, you can use the jack to lift the suspension up to use a ratchet.
If you have any problem popping the rotor off, you can get two #10 metric bolts 2 1/2" long and screw them through the open caliper bolt holes to push against the rotor.
Old 05-02-2010, 09:36 PM   #13
tatupu99's Avatar
great write up! recommend placing jack stands though, dont trust a jack to hold it up regardless of how fast u think u can swap rotors. safety first my friends.
if your having trouble with the 2 retaining philip screws, try using an impact driver. i pray to god no one strips them otherwise its gonna suck ass
tatupu99 is offline   Reply With Quote
Old 01-05-2011, 08:38 AM   #14
Heiss's Avatar
Links no longer work on the original post.
Heiss is offline   Reply With Quote
Old 01-05-2011, 12:04 PM   #15
Site Sponsor
fixdidem
Old 01-05-2011, 12:06 PM   #16
FUNCTION OVER FORM
Tufast's Avatar
Excellent DIY!
Sponsored By:
Tufast is offline   Reply With Quote
Old 01-05-2011, 09:49 PM   #17
Originally Posted by Tufast View Post
Excellent DIY!
I agree,very good,but with one problem. I dont see any jack stands under that car. Not only will it possibly damage your car if that jack collapses (and yes,I have had a hydraulic jack collapse) you invariably end up at various points with an arm or a leg under the car when changing brakes,if only for a minute or two. Jack stands cost 30 dollars for the cheap ones and are cheap insurance for both your car and you.
That being said,what I usually do is place a jack stand under the car,then back off the jack,then jack it back until it barely touches the frame. I then place the tire under the car as well,the idea being that if the jack stand fails,the jack will be there to support it,if that fails too,hopefully the wheel,although it will likely be damaged,will support the car,and perhaps save my life or prevent serious damage to the wheel and suspension and god knows what else.
mallen is offline   Reply With Quote
Old 01-06-2011, 10:02 AM   #18
Site Sponsor
I absolutely agree, I remember looking for jack stands that day and the only ones around were sky high, used for big trucks. At home I have about 8 stands. I think anyone doing anything under there car should have a lot more than one crappy little jack (as in the pics above) standing between them and danger / death! Be safe not sorry!
Old 01-09-2011, 05:43 PM   #19
14.3 @ 96 - Stage 1
CrispedPenny's Avatar
Very detailed write up!
BeyondRedline Stage 3 ftmfw
CrispedPenny is offline   Reply With Quote
Old 09-05-2011, 06:20 PM   #20
Icerian's Avatar
I think the links may be dead. Can we get the PDFs reposted?
2.0T - 6 speed M/T
Originally Posted by Kirk View Post
I'm just here for the gang bang
Icerian is offline   Reply With Quote
