#21 | |||
Takes at the most 60 minutes for all 4 wheels. Counting jaking and taking wheels in and out of bolts.
Silverstone Genesis 2010 380 GT Auto
#24 | |||
And easy to bleed if you need to. Just crack open the bleeder valve and let gravity work for you.
2010 Red 2.0L track Quote:
#25 | ||
Her Name is Elisabeth Jr.
Any idea what grease the guy put on the pads in the evo video before putting the fresh set in is?
'11 3.8 Track Karussell White | 3M Medium All-Around Tint | Magnaflow #16507 | Ventureshield Clear Bra | Blacked-out OEM Badges | Hella Supertones Horns | AEM CAI Previous Rides: '11 Sonata Turbo SE '10 V6 AT, Karussell White | 3M Medium All-Around Tint | Ventureshield Clear Bra | Magnaflow #16507 | DD Stage 3 LEDs | DD 6000k HIDs | DD 2 Way LED Signals |
#26 | |||
Usually just silicone dielectric grease like what you put on spark plugs.
#27 | |||
Site Sponsor
![]() www.InvisionAutomotion.com Find all your aftermarket products for your Hyundai Genesis Coupe! Brakes, Cosmetics, Performance, ECU Management, Suspension, Wheels, Lighting, and Car Care are all available through our online store! |
#28 | ||
has anyone actually done this successfully on their car? the dealership told me that they would charge 700+ for the replacement of the front brake pads...
And how would you know if it is necessary to bleed the brakes or not? |
#29 | ||
Site Sponsor
Ummm, yea. Your new to cars, aren't you?
#30 | ||
i just did this last weekend, super easy.
One thing to note... I used Hawk HPS and the rears would not fit. No matter how hard I tried, the rear pads were too wide to fit. In fact it wasnt the pads, it was the shim stuck to the back of the pad. Hawk has some fancy rubberized metal shim stuck to the back of the pad, it was just thick enough to interfere with the seals/pistons. I ripped them off and they went in perfectly. I thought Id hear squeeks and rattles without the shim but fortunately there was no ill effect. |
#32 | |||
Site Sponsor
brembo pad replacement |
#33 | |||
It is a good idea to bleed out all the old fluid every two years or so though.
#34 | |||
Brembo's around 150$ Be careful Hyundai dealers sell the pads 300$ + for stock pads. Ripoff !! Take the time to do it yourself you will then know how to change pads for the rest of your life ! When you are used to it,it should take you no more than 1 hour for all 4 wheels.
#35 | |||
Site Sponsor
#38 | ||
Site Sponsor
Read this chart: Easy to Use Brake Selector Chart | EBC Brakes
Read these too, since it's a bit hard to explain: Red:http://www.ebcbrakes.com/automotive/...ake_pads.shtml Yellow:http://www.ebcbrakes.com/automotive/...ads_4000.shtml Last edited by BrandonGS; 05-31-2011 at 05:29 AM. |
#39 | ||
Yellow for track use
Red for street use. Yellow less dust and noise that the Hawks HP Plus.the Hawks sound like a bus is stopping.
#40 | ||
