DIY - Cabin Air Filter - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 09-30-2011, 09:22 PM   #1
JK-DM!
nellyville41's Avatar
Default DIY - Cabin Air Filter
For those of you who don't know how to change your cabin air filter and don't want to pay a dealership to have it done, here is some very simple and easy steps. Cabin Air Filters should be changed every 15k or year, sooner if you live in a really dusty environment.
Approx. time should be less than 5 mins.
Step 1:
Open glove box and empty its contents.
Step 2:
Look for the tabs on each side of the glove box.
Step 3:
Remove the tab by first sliding it down, then second sliding it out away from the side wall. If you have problems trying to slide it down you can kinda access the back side of the tab and wiggle/push it down to loosen it up.
Step4:
Remove the tab by pulling it away from the side. Now repeat Step 3 and 4 and do it for the other side.
Step 5:
Remove the lowering hydralic? (not sure on the name of it) from the glove box
Step 6:
Lower the glove box and let it rest so that you can see cabin air filter door
Step 7:
Pinch the clips on the left side to open the cabin air filter door and then swing it open and it should disconnect from the hinge.
Step 8:
Pull out old and dirty cabin air filter. Hint to know its dirty, the OEM ones are suppose to be white. LOL.
Step 9:
Open new cabin air filter and take notice of the arrow on the filter with the words "air flow" as you want to make sure its pointed in the same position as the old one (pointed down).
Step 10:
Place new cabin air filter into the slot and reverse the previous steps.
Pat yourself on the back.
Nelly the
My Current Build Thread
http://www.gencoupe.com/media/104664-nellyville41s-jk-dm-current-build-thread-pic-heavy.html
nellyville41 is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 11:43 PM   #2
ManOnFire's Avatar
Nice job, how does that new filter smell?
'10 Tsukuba Red 2.0T A/T - CP-e aIntake -TurboXS RSD CBE - Chromium Black XXR 522's 19x8.5+15/19x10+20 w/Hankook Ventus Evo tires 245/35 + 275/35 - Eibach Pro-Kit - R1Concepts Drilled & Slotted Rotors w/Hawk HPS Pads - M&S Type D Grill - 2013 LED Tails - 6000K HID Conversion/Interior LED Conversion - Tints 5/15%
ManOnFire is offline   Reply With Quote Quick reply to this message
Old 10-01-2011, 06:06 AM   #3
JK-DM!
Thanks! It's odorless so I don't smell anything. Lol. I did however used a sheet of bounce so I smell that.
Old 10-01-2011, 06:11 AM   #4
Finesse Is Everything
CaptainSlow's Avatar
Great Write Up! Will bookmark this one!
Slowest Gencoupe Driver in The North East
"You know those dot matrix on the M5....I was in my mates kitchen drying my underpants in the microwave and when it had finished it said "enjoy your meal" -James May
CaptainSlow is offline   Reply With Quote Quick reply to this message
Old 10-04-2011, 03:28 AM   #5
archMonkeyMojo's Avatar
Thanks for sharing! I'm definitely going to try this filter with a fabric sheet, looks like it will do a much better job then the OEM one.
archMonkeyMojo is offline   Reply With Quote Quick reply to this message
Old 10-04-2011, 05:55 AM   #6
Jedi Master
cris90's Avatar
whats the life of the OEM air filter? i have 14k miles should i change mine?
Fav. JT Quote
cris90 is offline   Reply With Quote Quick reply to this message
Old 10-04-2011, 10:49 PM   #7
JK-DM!
Usually you change it around every 15k or every year depending on your road conditions. Also it doesn't help to take it out and take a look at it as well to see how dirty it has become.
Old 10-05-2011, 02:37 AM   #8
hkusp45's Avatar
Well done write up!! Thanks for taking the time to do this.
hkusp45 is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 06:48 PM   #9
BLitZ's Avatar
Was just thinking about this the other day, will be doing this one for sure.
2010 KW 3.8 Track
Ark - Agency Power - GTspec - Megan Racing
BLitZ is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 07:04 PM   #10
SubtleStyle's Avatar
Got two fram ones, one for now one for later
2010 IY 3.8 Track
SubtleStyle is offline   Reply With Quote Quick reply to this message
Old 10-07-2011, 08:30 PM   #11
The Boss
where do you buy the filters
Superman is offline   Reply With Quote Quick reply to this message
Old 10-07-2011, 09:03 PM   #12
JK-DM!
You can get it online on like amazon or any auto retailer. Auto retailers are more expensive though. I bought mine at walmart for $20. Buy it online at walmart and have it shipped to the store for free, then pick it up.
Old 10-25-2011, 06:22 PM   #13
JoeyGenesis's Avatar
Someone recently told me about this, and how FILTHY his filter was when he finally learned about it. Thanks for the DIY, need to get this done ASAP before mine looks like the birds nest that my buddy had going on in there.
2011 2.0T Tsukuba Red
M&S Type-D Grille / Plasti-Dipped 18's / 5k HID's
Black Headlight Housing / Superlux Tails
KDM Badging / NGM Defender CF Intake
Track Trunk Swap
Purchased:
DD Stage 3 LED Kit - Blue
Custom Powder-Coated Gloss Black XXR 522's
19x8.5 +25
19x10.5 +22
Ark SFX CF Hood
NEXT UP:
Eibach Pro-kit/Window Tints
THEN FINALLY ONTO PERFORMANCE!!!
JoeyGenesis is offline   Reply With Quote Quick reply to this message
Old 10-27-2011, 05:13 PM   #14
aarondr's Avatar
Thanks for this - my wife has bad allergies and we always wondered why she seemed to get worse in my old car (Tiburon) turns out that the factory 'forgot' to put in a filter. I haven't checked the genesis yet, but I"m planning on replacing this filter every year (especially after spring pollen).
aarondr is offline   Reply With Quote Quick reply to this message
Old 10-28-2011, 01:27 PM   #15
spoofyman's Avatar
nice write up!!!!! i just got mine after my dealership showed me mine lol!!!! yeah white i think not it was more dark grey lol!!! stupid florida weather and roads (only have 20K on the car). so i grabbed a filter from advance auto ($19.99) and thanks to this post i don't have to pay my dealership an insane amount ($80) to replace something so simple.
spoofyman is offline   Reply With Quote Quick reply to this message
Old 10-28-2011, 01:47 PM   #16
SJ is the man
JewishThunder's Avatar
I will definitely be changing mine ASAP.
Joe's milkshake brings all the boys to the yard...
I AM SPECIAL!
JewishThunder is offline   Reply With Quote Quick reply to this message
Old 10-31-2011, 08:59 PM   #17
dbigboi703
dbigboi703's Avatar
Nice wright up i'm gonna grab a filter tomorrow when i go into work
*Ark DT-S Exhaust
*Pa Headers
*SFR Custom 1.5 Tune
*R2c Intake w/ TB and IM Spacers
*RmR Carbon Fiber Front Lip
*Sequence Carbon Fiber Rear Diffuser
*Meagan Carbon Fiber Roof Spoiler
*VIS Carbon Fiber Grill
*VIS Carbon Fiber Fog Bezels
*Samsung Galaxy Tablet
2010 3.8L GT A/T 287whp 262tq
dbigboi703 is offline   Reply With Quote Quick reply to this message
Old 11-08-2011, 05:30 PM   #18
Thanks for the pictures! I already bought the filters but it's not time to switch it yet. Now I don't need to 'explore' on my own...
MrConclusion is offline   Reply With Quote Quick reply to this message
Old 01-31-2012, 10:12 PM   #19
elementrider87's Avatar
Dude...this is cool lol thank ill do this tomorrow!
BUILT ENGINE
Haltech,PRW Stage 4, Tial EWG, BR twin pump DW300 fuel pump, Aeromotive FPR, Stage 4 clutch, Garrett FMIC, Grimmspeed EBCM, Tomei Poncam/valve springs, Elite Intake Manifold, Mishimoto radiator/hoses, CF snorkel.
On the way: Megan racing transmission/engine mounts
elementrider87 is offline   Reply With Quote Quick reply to this message
Old 02-03-2012, 11:03 AM   #20
ManOnFire's Avatar
2 years... almost to the day.
Cabin filter dk60902 Interior 2008-2012 20 05-14-2012 08:31 AM
Cabin Air Filter ? nathansvt Interior 2008-2012 18 03-10-2012 07:38 AM
Cabin air filter HELP!! subyhau Interior 2008-2012 15 08-05-2011 09:08 AM
where can i get some cabin filter for 2.0? eclee Interior 2008-2012 4 05-10-2011 05:31 AM
Cabin Filter dk60902 Interior 2008-2012 0 09-02-2010 05:06 PM
Powered by vBulletin® Copyright ©2000 - 2014, vBulletin Solutions, Inc.
