DIY - Replacing the front wheel well liner - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 03-31-2012, 10:36 PM   #1
Sr. Lifetime Prem. Member
bumboclotgcoupe's Avatar
Location: Los Angeles, California Crenshaw/Jefferson Park
Default DIY - Replacing the front wheel well liner
Here they are, and THANKS!!! STUPID PHOTBUCKET, lol.
Guess I've been the only one to crack one of these. It bothered me to no end for about 7 months and I had finally had enough (as well as got comfortable taking the car apart) so I decided to replace it. This is what it looked like.
This is the new wheel well liner.
Tools
Screws that needed to be removed
This one was missing already
These are the ones under the front bumper cover
Removed screws. You should have a total of 9 of the "push" type that are enclosed in the plastic spreader, the one nut-like one that comes from the screw rod at the top of the fender, the two screws that come from the side (in the fourth pic) and the one screw that actually holds the wheel well liner in and the front bumper cover on.
Once you've removed all the screws, gently pull the liner from the front, inwards towards the inside of the car and downward over the extended screw rod, then gently slide the rest of it out from the rear side of the wheel well. Cracked wheel well liner removed
Putting the new wheel well liner in you have to make sure it tucks behind the fender and that you line it up with the projecting screw rod in the top of the fender. As you can see from the pic, I didn't do this so I had to loosen and tuck; kinda like tucking your shirt in your pant, LOL!
While I had the wheel well liner out, I was going to clean my CAI filter, but the clamp screw was facing the other direction, so guess I'll have to wait to clean it when i take the bumper cover off again and once I do that, I'll turn the clamp around so I can access it from the wheel well liner instead of having to take the bumper cover off.
Finished "product"
Thanks for allowing me to do this!
OG 2010 3.8 Track A/T PA Reflsh*INJEN CAI*ARK GRIP V1 Brnt Tip CBE w/DP*F/R Centric D&S Rtrs*StopTech Pds & SS Brke Lns*Cusco Strt Brace*Pntd Fuse Bx/3800 Engn Cvr*Eibach Pro-St.Coilovrs-S*Eibach Anti-Roll-Kit F/R Swy Bars*Chrome Grill*Prodigy Lip*F/R Wng Emblms & Wheel Caps*R Wndw Spoiler*8K HID Head & Fogs Lghts, Blkd-out & Blu Eyd Cstm Paint by El-Stig*DRL's*Swtchbk Blnkrs*Blu LED Map Lghts/Side Steps w/Dr Jam Lghtng/Cup Hldrs/Dr Hndls*Upgrded Stereo*Escort 9500ci Passport*LED Lic Plte Lghts
bumboclotgcoupe is offline   Reply With Quote Quick reply to this message
Old 04-01-2012, 09:57 AM   #2
1stgengen
ByByCavalier's Avatar
Good job man.
As for replacing the Injen filter, you should be able to remove the headlight and have enough room to get your hand down there.
DIY - Injen CAI (3.8) Filter Replacement = Easy w/lots of pics!
ByByCavalier is offline   Reply With Quote Quick reply to this message
Old 04-01-2012, 06:48 PM   #3
Originally Posted by ByByCavalier View Post
Good job man.
Thanks, and thanks for looking out, gonna try that!
Old 04-02-2012, 06:06 AM   #4
livin life
Iwannagofast23's Avatar
How much was the liner and from where did u get it?
Iwannagofast23 is offline   Reply With Quote Quick reply to this message
Old 04-02-2012, 08:38 AM   #5
Different dealers charge different prices for parts. At my dealer the part retails for $75.00 but I got it for $53.00, but found it at one of my other online auto parts store for $35.00. Here's the link:
US Auto Parts - Catalogs - Coupe,year:2010),AND(universal:1))&Vi=4294958205+4 294962935+1637&y=2010&mk=Hyundai&md=Genesis Coupe
(I don't know why, but you'll have to cut and re-paste the link to get it to go to the right page)
They call it a splash guard, so check the net and see what you come up with!
Old 09-25-2012, 02:27 PM   #6
castor troy's Avatar
bumboclotgcoupe,
Anyway to see the pics? It says they've either been deleted or removed. I myself have a similar situation with a cracked wheel well that I'm tired of looking at, its such an eye sore!
castor troy is offline   Reply With Quote Quick reply to this message
Old 09-25-2012, 04:56 PM   #7
SUN★WORKS
SteveJohns29's Avatar
Originally Posted by castor troy View Post
bumboclotgcoupe,
Check post 1
Sponsored by:
TurboXS / Competition Clutch / GarageLine / Corbeau Seats / ISC Suspension / KDM Racing
475WHP/363wtq
SteveJohns29 is offline   Reply With Quote Quick reply to this message
Old 09-25-2012, 06:51 PM   #8
Jedi Master
cris90's Avatar
BTW guys i bought a cheap ebay knock off, bad idea. it needed to be cut up, drlled and then forced on the fit with no clearance problems. Buy hyundai OEM don't waste time trying to save $20 on knock off.
i'm still ganna have to buy coating cause i'm still mexposing the unprotected body and winterss comming
Fav. JT Quote
cris90 is online now   Reply With Quote Quick reply to this message
Old 09-25-2012, 06:56 PM   #9
Frenchy
cameleon1267's Avatar
awesome just in time to get the sound proof parts installed on the fender next weekend
Beyond Redline Evo X build. 383whp, 362wtq
Originally Posted by Tim@BeyondRedline View Post
I have to be honest my friend....of all the Gencoupe's that I have had the privilege of driving, yours was my favorite. It has inspired some R&D for new products that might be out sometime in the near future.
He's mine! You can't have him! You have SoCal I have NorCal damn you! Yea we got it on lockdown. Hopefully it'll go easy breezy beautiful cat back girl.
cameleon1267 is offline   Reply With Quote Quick reply to this message
Old 09-26-2012, 06:59 AM   #10
Awesome DIY, thanks for getting the pics to show!
Old 09-26-2012, 07:07 AM   #11
Thank you, and you're welcome; but couldn't have done it without Stevejohns29
Last edited by bumboclotgcoupe; 09-26-2012 at 07:08 AM. Reason: forgot to thank him
Old 10-07-2012, 03:10 PM   #12
Default wheel well liner
Thanks for the write up. One observation: isn't the brake disk in the wrong side of the car?
2011gencoupe is offline   Reply With Quote Quick reply to this message
Old 10-07-2012, 05:34 PM   #13
Jedi Master
cris90's Avatar
What do you mean? It's a drill and slotted after market disk, it's supposed to look likwe that
Fav. JT Quote
Old 10-07-2012, 06:14 PM   #14
If you notice when wheel rotates slots and drills will take dust down to the pads, not out, that's why they're not equal for each side.
Old 11-12-2012, 06:43 PM   #15
bklyncoupe's Avatar
my driver-side splash guard almost completely split horizontally....glad I found this tread again...will have to order asap...tks..
bklyncoupe is online now   Reply With Quote Quick reply to this message
Old 01-11-2014, 06:22 AM   #16
bumboclotgcoupe, thank you for the link to US Auto Parts. I'm glad I stumbled onto this thread - just ordered driver and passenger side splash shields - $87 list for $61.
Hank in Austin
2010 Nordschleife Gray 3.8 Track Auto
R2C Intake
CNT catback
Forgestar CF5's
Michelin Pilot Super Sports
BTRcc Post Bolt-Ons Custom Tune
Sarona Polyurethane Grill with M6 Mesh Insert
Hank is offline   Reply With Quote Quick reply to this message
Old 01-11-2014, 08:08 AM   #17
You're welcome; glad to have done something to help contribute to the community!
DIY -- Front Fender Liner Reduction & Undercoating Mod Tufast DIY - Do it Yourself 10 02-20-2014 11:36 AM
Replacing the stock wheel studs evo9ray California 44 05-12-2012 11:50 AM
DIY - Replacing the Brake Lines Tufast DIY - Do it Yourself 4 01-12-2012 11:03 AM
Replacing front bumper the_dynamite Exterior 2008-2012 24 04-27-2011 07:44 AM
Wheel well liner not staying put. Moley Exterior 2008-2012 22 03-16-2011 02:59 AM
Powered by vBulletin® Copyright ©2000 - 2014, vBulletin Solutions, Inc.
