DIY~Black Housing Headlights :D - Page 42 - Hyundai Genesis Forum
 2Likes
post #821 of 839 Old 09-29-2014, 04:47 PM
2012BlackGen2.0's Avatar
Quoted: 82 Post(s)
@ Jaymorz I used a fine grit sandpaper, it was 220 and I just scuffed up the housing surface dry then blew the dust off with a hairdryer. I bought a can of Plasticoat primer, any primer would probably work fine though. I used a can of engine enamel since it's heat resistant, 2 coats of primer and 3 coats of paint. I let them dry for about 10 hours before re-assembling, I ordered my halo's from Diode Dynamics so they were the correct size.
I haven't wired them into my headlights yet (ran out of time and it's my next project for when I have a day off) but I would stay away from those clip- connector things. I bought heat-shrink butt connector's to splice in, they have a sealant in them that seeps out after you heat them and keeps moisture out. Plus you can tell if you're fully spliced after you crimp them.
Here's a quick pic I took after work, they've made it through a foggy night and a quick wash so far with no leaks or condensation. And it's windy and rainy right now so my fingers are crossed and I'm hoping for the best. And I absolutely LOVE how it's changed the look of my car, much more menacing than the effect with all that chrome.
2012BlackGen2.0 is offline
post #822 of 839 Old 11-20-2014, 09:37 AM
need help please.
I did a set about 2 years ago but I forgot the sanding stages.
I remember using like 3 different sand paper grade in a combination of dry and wet.
If someone could tell me the grades and the order that would be great.
drop of ice is offline
post #823 of 839 Old 12-12-2014, 08:34 AM
CBux's Avatar
Quoted: 11 Post(s)
Im really wanting to do this to my headlights.
I have access to a heat gun to get the lights opened - should I use that or an oven?
I would really prefer not to ruin my headlights as this is my daily driver so any advise would be great.
CBux is offline
post #824 of 839 Old 12-12-2014, 09:04 AM
Why so serious, Bro?
GenCoupeGeek's Avatar
Quoted: 1199 Post(s)
Oven and heat gun work best. Use the oven to heat the entire light and the heat gun to keep the butyl rubber warm so that it will release properly.
BTRcc Custom Tuned
~Albert Einstein
GenCoupeGeek is offline
post #825 of 839 Old 04-25-2015, 08:13 PM
Orclipse
Orclipse's Avatar
First timer and it took me forever to get it apart.
2012 2.0T White
Orclipse is offline
post #826 of 839 Old 04-26-2015, 04:54 AM
Quoted: 82 Post(s)
^^^ Looks good! The first one I ever took apart took me awhile too, and it was pretty nerve wracking but worth it in the end.
K&N Typhoon Series Short-ram intake
Synapse synchronic blowoff valve
Eibach Sportline lowering springs
OEM Strut tower bar
Superlux taillights
AEM axleback with quad tips
Diode Dynamics SMD Angel Eye Kit (blue led's)
Blacked-out headlight housings
Diode Dynamics acrylic cupholder accent
RMX carbon fiber grille
post #827 of 839 Old 04-26-2015, 11:22 AM
Philly_KDM's Avatar
Quoted: 44 Post(s)
Also my first time. Didn't go near the oven, I just didn't feel like hearing the family complain about smell etc lol so I busted out the heat gun. Surely was a BITCH to open but worked out pretty well.
All black housing/lenses and RGB Angel Eyes + Demon Eyes
Philly_KDM is offline
post #828 of 839 Old 04-26-2015, 11:23 AM
Philly_KDM's Avatar
Quoted: 44 Post(s)
Looks great alongside the carbon fiber hood and white. Well done brother!
post #829 of 839 Old 04-26-2015, 11:57 AM
PeanutButter's Avatar
Quoted: 135 Post(s)
Was going to do this in a couple weeks, from what I have read most people suggest nissan butyl tape to reseal but I have googled and can not seem to find anywhere to order it. Any suggestions or something else to use to get a good reseal?
2010 2.0T Track Bathurst Black SOLD
BTR stage 2 / Treadstone / Tanabe / Prosport / R2C / Synapse / CP-E
2013 Camaro LS Silver Ice Metalic Current
Planned mods/ BR or KW var coils, Ark Catback, R2C intake, HP Tune, throttle body spacer....... eventually super charger or turbo.
PeanutButter is offline
post #830 of 839 Old 04-26-2015, 12:10 PM
Philly_KDM's Avatar
Quoted: 44 Post(s)
I found some on eBay and Amazon for cheap, but actually didn't buy any. You'll find there is a TON of it on our headlights and I actually just reheated what was on there to reseal. Then neatly applied some black RTV silicone around the whole light to make sure it was sealed. No leaks or condensation whatsoever!
post #831 of 839 Old 07-23-2015, 10:43 PM
DreamMachine's Avatar
Screw it. I'm going for it. I'm usually one who gets inpatient but I just had twins so patience is a must and I'm chillin at home so I have nothing but time to do it right. Wish me luck gents.
DreamMachine is offline
post #832 of 839 Old 04-06-2016, 04:38 PM
I started this mod yesterday. Took out the driver side headlight and separated the lens and housing using the heat gun. Took me about 15 minutes and it came apart pretty easily. Started at the pointed part closest to the grill area and pulled it apart. Already painted it matte black with plasti dip. Will be doing halos as well. Will post pictures as soon as I get enough posts haha
2012BlackGen2.0 likes this.
Chad Foster is offline
post #833 of 839 Old 04-10-2016, 01:11 PM
delete
post #834 of 839 Old 04-10-2016, 03:37 PM
Finished my halo blacked out headlights today. Can't wait to be able to post pictures soon.
Kaotiklivin4eva is offline
post #835 of 839 Old 04-10-2016, 05:52 PM
Quoted: 11 Post(s)
ill do this eventually
Jazzsnazz is offline
post #836 of 839 Old 04-18-2016, 04:21 PM
Here is what mine look like.
post #837 of 839 Old 11-13-2016, 10:29 AM
I just did mine over the weekend. I took @FlyRdye DIY Videos and it worked great.. Oven at 250 degrees for 5 minutes, check the light and then let sit about 3 minutes more was perfect to get the seal broken. Plastidipped Matt black with RetroFitSource.com RGB angel Eyes and Importshark 2Way LED audi stripes and clear corners from Dkmoulds. Will post pic later just signed up as new forum user.
Sehrke77 is offline
post #838 of 839 Old 01-13-2017, 05:23 PM
MZ777's Avatar
Quoted: 142 Post(s)
Is it true that the TRS now sells the plate required for retrofitting?
Sent from my ZTE A2017U using Tapatalk
MZ777 is offline
post #839 of 839 Old 02-15-2017, 04:16 PM
MZ777's Avatar
Quoted: 142 Post(s)
Guess not..
MZ777 is offline
