Factory Fog Lights Step-By Step DIY - Page 8 - Hyundai Genesis Forum
post #141 of 259 Old 08-10-2011, 03:24 PM
Relay, wire, fuse, terminals
post #142 of 259 Old 08-15-2011, 10:28 AM
WhiteGenCoupe74's Avatar
Originally Posted by MegsCoupe View Post
I had to show off my switch made own harness from the foglights to battery to the relay (all grounded) through the firewall to the dash. Installed this awesome button which matches stock pretty well.
that looks so much better than the toggle switches i like how it looks like factory
WhiteGenCoupe74 is offline
post #143 of 259 Old 08-15-2011, 04:50 PM
2010 3.8 Track AT
rdskill's Avatar
I was looking at OEM foglight switches for other cars.
The one for the Mazda Miata looked like a great one. Had a little fog light symbol even. Just have to find a Miata to see how it would look. lol
2010 Silverstone 3.8L Genesis Coupe Track Auto
Poor Quality Injen STS Exhaust
RC2 Short Air Intake
Foose Wheels - Speed - Black/Machined 19x8.5/19x9.5
Previous Gen...
2011 Tsukuba Red Genesis Coupe 2.0T Base Auto
Deerfield Beach, FL
rdskill is offline
post #144 of 259 Old 08-18-2011, 11:40 AM
debating on having someone do it for me or do it my self i hate messing with electrical
post #145 of 259 Old 08-22-2011, 09:22 PM
icedearth15324's Avatar
I know this is semi-off topic, but how easy is it to change the bulbs on the fog lights? Is it easier if you remove the entire assembly or can you access the bulbs without removing them?
2012 3.8 Grand Touring - Mirabeau Blue
Current Upgrades:
-Ark Grip Exhaust V1
-R2C SRI
-2500k Luminics Halogen Fog Light Bulbs
-LED Kit
-Yellow Lamin-X Fog Light Covers
-DD 4300K/8000K HID Headlights
-Sequence Grill
-Black Wing Badge
-Plastidipped Rims
-Wing Wheel Caps
KDMnation Chicago Chapter
icedearth15324 is offline
post #146 of 259 Old 08-22-2011, 11:06 PM
You would need to take out the phillips headed push pins from the fender liners and bumper meeting point then bend the fender liner down to reach up into the back of the fog light to get to the bulb.
Or take off the bumper.
post #147 of 259 Old 08-22-2011, 11:11 PM
Dang, that sounds like a huge pain. Hopefully my friend will be able to help me.
Current Upgrades:
-R2C SRI
-LED Kit
-Sequence Grill
-Black Wing Badge
-Plastidipped Rims
-Wing Wheel Caps
post #148 of 259 Old 08-26-2011, 12:08 AM
What is happening here?
So I'm pretty nub at this and I have no idea what the fuse box does. If I use the positive lead on the fuse box how will it know what to turn on?
and where are the wires for the foglights in this picture??
also, I wanted to use a switch to turn the foglights on as well and in this picture:
is the battery literally the battery in the car? also what is a fuse holder?? and in the fuse box where am I connecting that wire to? the positive lead? Nothing is making much sense right now... and for some extra.. how is the fuse box protecting the car in any way in that picture? seems like its just hooked up to the battery? what is the functionality of the fuse box?
acslee88 is offline
post #149 of 259 Old 08-26-2011, 12:42 AM
Sounds like you need someone with experience to actually help you do the work.
post #150 of 259 Old 08-26-2011, 09:56 AM
Thanks a ton, waiting to work up the courage to do this.
Submosis is offline
post #151 of 259 Old 08-26-2011, 10:21 AM
but where will I get help?? I don't know any mechanics
buuuut I'm hoping that I'll be able to do this myself... just need some explanation..
acslee88 is offline
post #152 of 259 Old 08-26-2011, 01:53 PM
Well the picture above is the way it needs to be wired. You need good terminals, good crimpers, the right sized wire. Get a relay with a built in diode if you plan to hook the trigger wire up to you existing lights.
post #153 of 259 Old 09-08-2011, 12:05 AM
Great write-up... finished in a couple hours, but thats mostly b/c I'm a perfectionist and all the wires had to be hidden, zip tied, the right connectors and adapters for the wires (I don't splice anything). I ordered the Fog Light Housing from ImportShark, the Harness and 3000K bulbs, and HID Kit from Diode Dynamics, the rocker switch pictured above I found at Radio Shack (of all places). The only glitch I wasn't expecting is that DD wiring harness relay is new, the instruction that come with it and on their site aren't up to date yet. There are 5 wires coming off the relay (2 - for the digital ballasts, 1 - 12VDC, 1 - Ground, and 1 - Switch wire that has a positive and negative lead. I had to actually plug the positive end of the switch wire into the 10A RT Taillight before it would work. I tired to test it before I installed everything just by touching the positive lead off the switch wire to the fuse box under the hood and it wasn't working, took me a little while to figure out the problem, but once solved everything worked great. Another tip, you can cut the extra wires off the light bulbs if your using a wiring harness to do this install.
2011 BLACK 2.0T R-SPEC
NCGenCoupe is offline
post #154 of 259 Old 10-10-2011, 12:08 PM
rrmartin1's Avatar
Why not just buy the actual factory switch?
Robert
2012 2.0T Tsukuba Red
Engine - SAI; Dual Catch Cans; Dress Up Bolts; Redline Heavy MT Fluid;
Interior - Nexus7 Install, Hardmounted Phone Stand
Exterior - Streak Headlights; Rear ARK Wing; Blacked-Out & Sharkfin Removal
Suspension - 2” Lowering Coils
Wheels/Tires - PoweredCoated Wheels; G-MAX 255&275/35ZR19
Electrical - Hardmounted Escort 9500ix & SmartCord; Mr. BrakeSafe Flasher
(I'll try to have pictures of everything in my GenCoup Garage.)
rrmartin1 is offline
post #155 of 259 Old 10-10-2011, 04:01 PM
It does appear the connector is the same for the MFS whether it has fog lamps or not. Probably have to add pins and wiring to it to function .
post #156 of 259 Old 11-15-2011, 06:49 PM
Has anyone bought the factory switch to know if it works for sure, I am thinking about buying it instead of drilling into the dash.
csblack is offline
post #157 of 259 Old 11-22-2011, 09:20 PM
nicwayfarer's Avatar
can i install this?
I have an aftermarket HID and i was just wondering if i can install this fog lights as well? I installed my HID with harness that comes with it from Diode Dynamics. I was gonna buy OEM fog lights and maybe HID again but i want to make it really YELLOW not white HID hehe.
Thanks anyone.
2011 Nord Gray 2.0T A/T
MAGNAFLOW EXHAUST
SUPERLUX TAILS
DAILY DRIVER
nicwayfarer is offline
post #158 of 259 Old 11-23-2011, 02:59 AM
Roosh31's Avatar
One more question on the wiring diagram for the fog lights...in the picture of the actual battery it shows a ground wire; is this just the normal ground that is currently in place?
In other words, do I only need the hot wire connected to the fuse box positive terminal with a fused wire leading to the relay?
Just want to ensure a clean install. Thanks.
Roosh31 is offline
post #159 of 259 Old 12-01-2011, 05:37 AM
RicanGen20T's Avatar
Hey everyone,
I bought this item http://http://www.ebay.com/itm/2010-...item45fd4335f4
Check it out if anyone is interested in seeing the whole fog light, wire and OEM MFS switch.
I haven't installed the MFS yet, but hopefully this weekend it will get done and if gets to risky, I may just look for that relay with a built-in diode to connect it to the low beams or go with the external switch.
Good luck to all.
2010 GC 5sp AT
Present Status:
- HKS Catback Dual Dual Exhaust
- Test pipe
- AEM Cold Air Intake
- Mishimoto Intercooler
- Rebadged
- M&S Grill
- HID Projectors
- Racing Lubricants
- SFR Reflash 1.5
- Tinted windows
- That little special something...
What comes next to reach status of
- Rims
- Wing Spoiler
- Rear deffuser
- Not sure what else...
RicanGen20T is offline
post #160 of 259 Old 12-01-2011, 05:47 AM
That looks like a good setup for those that do not have the factory stuff.
